Weight Of PT Wood
Old 03-28-2006, 06:26 AM   #1
Woodcrafter74's Avatar
Rewards Points: 250
Weight Of PT Wood
Anyone have a guide or know a website that lists the general weight of various sized lumber, particularly PT lumber. I know the weight will vary based on moisture content, but I'm looking for ballpark numbers. (Or anyone have a guess at what a 6x6x12' PT weighes)?
Ultimately I'm trying to estimate how much lumber I can throw on my trailer before my truck pukes.
Woodcrafter74 is offline
Old 03-28-2006, 07:09 AM   #2
Teetorbilt's Avatar
Rewards Points: 2,000
Re: Weight Of PT Wood
You can dig around in here; http://www.woodweb.com/knowledge_bas...transport.html
I would think that soaked PT and a green hardwood would be reasonably close in weight.
Another way would be to calculate your total mass, use the kiln dried weight and then add the moisture content.
Albert Einstein
Teetorbilt is offline
Old 03-28-2006, 08:48 AM   #3
RowdyRed94's Avatar
Trade: Residential custom home builder
Rewards Points: 150
We handled a bunch of treated 2x12s a few years back for a large deck. On a bet with my boss, we weighed them before and after a drying period leaned up against the shop. He thought we could significantly reduce their weight by letting them in the sun for a week. Well, no.
They were 12-16 feet long and weighed in at 170-200 lbs. each. They lost about 3-5% of their weight in that week. It was not worth the effort.
Clint - carpenter, coordinator, webmaster
RowdyRed94 is offline
Old 03-28-2006, 09:02 AM   #4
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
I set 2 6x6x12' PT and 1 6x6x14' PT all by myself. So let me tell you HEAVY AS I would not recomend it but I would guess the ones I had to be around 130 - 160 for the 12' I could be more or it could be less... This was about 8 months ago and I try my best to forget that day. I did end up hurting my back setting those posts too.
RobertCDF is offline
Old 03-28-2006, 11:59 AM   #5
Rewards Points: 250
Dang Rowdy, if that's right then a 6x6x16' is going to be about 350lbs. I guess that could be right. I was hoping it was closer to Robert's estimate, but I think he might be a little light. I might just go weigh them myself.
Thanks guys.
Old 03-28-2006, 12:05 PM   #6
carpenter and builder
Nick H's Avatar
Trade: carpenter and builder
Rewards Points: 150
I've just been working out some beam loadings and the figure which is generally used for softwood construction timber is 590 kilograms per cubic metre, which i reckon works out at about 37 lbs per cubic foot. If you work out the volume of your timber member you can calculate the wieght.
Dont give me problems, give me solutions.
Nick H is offline
Old 03-28-2006, 12:35 PM   #7
Rewards Points: 250
Originally Posted by Nick H
...for softwood construction timber...
That wouldn't be for PT though, would it?
Old 03-28-2006, 01:20 PM   #8
RobertCDF's Avatar
If those post are 350 then I am one buff mo fo I am only 5'3" and weigh 140 LBS myself I would bet they dont weigh much more than me.
Old 03-28-2006, 02:37 PM   #9
Nick H's Avatar
Rewards Points: 150
I assume by PT you mean pressure treated, and yes that would be for PT softwood, most of the construction timber we get is stuff like pine/hem-fir/douglas fir etc, and mostly PT. Once dried the PT isnt going to wiegh any more than non PT, (at least I dont think it does).
Like the others, i've picked up a wet 4x2 16' that damn near broke my back and yet have had 9x2 that you could sling around one handed, all depends on moisture content and if your thinking about truck loading then presumably your gonna be picking stuff up from the merchant and we all know how variable that can be. You should do what I do and thats keep piling it on until the truck's just about draggin it ass, LOL.
Nick H is offline
Old 03-28-2006, 03:08 PM   #10
jack of all, master of 1
snapper21's Avatar
Trade: carpenter/roofer
watch your trailer axles. If you can see your tire go out of plumb or the axle bend you probably have too much on it.
snapper21 is offline
Old 03-28-2006, 03:37 PM   #11
Soon to be senile
Shamrock's Avatar
Trade: Remodel and repair
Rewards Points: 150
Geeeez...I really don't want to know how much the damn stuff weighs...I might start reconsidering carrying it any more. Did some 6x6x16's last week and I think I killed some brain cells.
Shamrock is offline
Old 03-29-2006, 08:14 PM   #12
HouseWright
Riversong's Avatar
Trade: Designer/Builder
Rewards Points: 75
"Most of the weight added to treated wood comes from water used to solubilize the preservative components. A freshly treated piece of lumber may contain as much as 4.5 gallons of water per cubic foot or about 38 lbs. per cubic foot. As the wood dries and the water evaporates, only the preservative will remain. Lumber tagged for above-ground use should contain 0.25 pounds preservative per cubic foot and, for ground contact, 0.40 pounds per cubic foot."
treatedwood.com
That means that "green" PT lumber can weigh as much as 3 lbs/bf extra. Since KD SYP weighs about 2.2 lbs/bf, it could weigh as much as 5.2 lbs/bf PT green, and about 3.2 lbs/bf PT air-dried (3.8 lbs/bf for PT timbers).
Which means that Rowdy's 2x12-16 should have tipped the scale at about 102 lbs (not the 200 lbs he claimed unless they were fresh off the treatment plant), and RobertCDF's 6x6-14 should have weighed in at 160 lbs (just what he claimed).
- Robert
Riversong is offline
Old 03-30-2006, 02:57 PM   #13
RowdyRed94's Avatar
Rewards Points: 150
Well, we picked them up and stepped on our bathroom scale. Take it or leave it. If they only weighed 100 lbs we wouldn't have had much to bitch about, would we? ;-)
It was 200. They were juicy, as most PT is.
New kind of Pressure Treated wood karma_carpentry Carpentry 23 08-21-2008 08:06 AM
Pressure Treated Wood rjordan392 Carpentry 4 05-28-2007 01:23 PM
why lowball dirt diggler General Discussion 16 09-09-2006 05:26 PM
Wood people I need your help Floorwizard Flooring 11 05-18-2006 08:07 AM
Really Dark Wood...Primer/Application Q slickshift Painting & Finish Work 13 04-28-2006 03:47 PM
