The Wall Of SHAME!
Old 02-25-2018, 11:18 AM   #6441
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 2,724
Re: The Wall Of SHAME!
Originally Posted by Big Johnson View Post
I think the jack is just used to wedge the 2x4s. No one in their right mind would put a plank on that.
Pretty sure they had a 24' pick on there and another small ladder on the roof with the other ladder bracket. These guys do some crazy stuff around here
NYgutterguy is online now
The Following User Says Thank You to NYgutterguy For This Useful Post:
Big Johnson (02-25-2018)
Old 02-25-2018, 03:07 PM   #6442
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 864
I have seen some pretty dumb stuff in my time, would not put it past someone doing it. A lot of people out there not in their right mind.
Randy Bush is online now
The Following 3 Users Say Thank You to Randy Bush For This Useful Post:
Big Johnson (02-25-2018), Fouthgeneration (02-25-2018), Rio (02-25-2018)
Old 02-26-2018, 04:10 AM   #6443
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 3,872
Originally Posted by NYgutterguy View Post
Came across this the other day at a job. Some sort of ladder stabilizer of something.
Kinda hard to figure out what that's all about .
Not to mention the window sill damage .you can look at those vinyl Windows and they'll get scratched .
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Big Johnson (02-26-2018)
Old 02-26-2018, 05:37 AM   #6444
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,128
Easy to see what they were doing. If you are going to put your ladder jack 6 rungs up from the last place the ladder touches anything then you have to brace the top of the ladder to keep it from kicking out on you.
It's in the OSHA manual... Look it up.
Edit: They have a spotter on the ground just in case anything bad happens. Seems legit to me.
Home Designer Series Software
B.Johnson is offline
The Following User Says Thank You to B.Johnson For This Useful Post:
blacktop (02-26-2018)
Old 02-26-2018, 05:44 AM   #6445
water re-locater
The bottom was actually secured pretty well too but forgot to take a pic of that. OSHA will only show up to investigate an accident where there is a fatality in this area.
Old 02-26-2018, 06:50 AM   #6446
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 2,962
I would have took the two nails out of the end and used them where the 2x4s cross.
Big Johnson is offline
Old 02-26-2018, 07:22 AM   #6447
Drywall Slave
blacktop's Avatar
Its in the OSHA manual . LMAO!
blacktop is offline
Old 02-26-2018, 07:24 AM   #6448
Drywall Slave
blacktop's Avatar
I can't say nothing really...I've rigged up worse than that.
blacktop is offline
The Following 4 Users Say Thank You to blacktop For This Useful Post:
B.Johnson (02-26-2018), Jay hole (02-26-2018), Lettusbee (02-26-2018), sparehair (02-26-2018)
Old 02-26-2018, 07:47 AM   #6449
Drywall Slave
blacktop's Avatar
A few years ago I was working down the street from a drywaller friend of mine. I stopped by at lunch to shoot the chit. It was one of those homes where ,When you walked in the front door . The cathedral went up over the upstairs landing and down the other side to the kitchen . He had three full buckets of mud in the foyer with a walk plank on top of two of the buckets , another walk plank running from the second step of the stairs to the third bucket. With two stages sitting on top of the planks .
Upstairs from the landing to the top of the scaffold,, he had an extension ladder running across with a strip of OSB on top of the rungs .
I said dude! There has got be a better way,!
He said ,, F IT! They wanna build this crazy chit ? We gotta reach it somehow !!
blacktop is offline
Old 02-26-2018, 02:52 PM   #6450
Mordekyle's Avatar
Rewards Points: 3,214
I know someone that has used a 40 foot aluminum extension ladder on top of ladder jacks. With OSB strips, nonetheless.
Mordekyle is online now
Old 02-26-2018, 06:11 PM   #6451
Box Builder
Morning Wood's Avatar
Rewards Points: 8,878
I know someone that put a step ladder on his stage plank that was on extension ladders with ladder brackets. He only broke his leg. Hes back in action though.
Morning Wood is online now
Old 02-26-2018, 08:37 PM   #6452
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,040
I borrowed scaffolding from a drywaller and was appalled at how worn out the plywood on the planks were... Guess I was being picky.
Sent from my Nexus 6P using Tapatalk
Inner10 is online now
Old 02-26-2018, 08:51 PM   #6453
Drywall Slave
blacktop's Avatar
Buy you're own damn scaffold !
Really tho.. my 7 footers are in good shape . But all my 10 footers need the ply replaced . And i have 10 of them. Do you have any idea how hard it is to find 10' ply? I'm kinda waiting to save enough coin to replace them with salt treat .
blacktop is offline
SmallTownGuy (02-26-2018)
Old 02-27-2018, 12:40 AM   #6454
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,209
BlackTop: Menards has 5' x 10' x 3/4" nominal treated plywood for only 100.00$ a sheet, the 5' width allows (3) plank infills per sheet for ~118" x 19.5" aluminum and plywood decking/ composite planking...
https://www.menards.com/main/buildin...452505105.html
I think I'd go with a under deck glue and screw lap splice and save About 50%.
With thousands of miles of salt water coast on the right hand side of Virginia, surely you can find a wood boat lumberyard/ chandler?
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
blacktop (02-27-2018)
Old 02-27-2018, 08:14 PM   #6455
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,738
Damm $100 a sheet?
Windycity is offline
Old 02-28-2018, 10:38 AM   #6456
water re-locater
Another Great design.
The Following 4 Users Say Thank You to NYgutterguy For This Useful Post:
heavy_d (03-01-2018), Rio (02-28-2018), SmallTownGuy (02-28-2018), Xtrememtnbiker (02-28-2018)
Old 02-28-2018, 11:49 AM   #6457
Drywall Slave
blacktop's Avatar
Originally Posted by Windycity View Post
Damm $100 a sheet?
I know .. a new 10' stage plank aluminum is $170 .
I'm thinking of selling all my 10 footers and buy new.
blacktop is offline
Old 02-28-2018, 01:43 PM   #6458
Randy Bush's Avatar
Rewards Points: 864
Boy that is special. See so much dumb stuff done on houses anymore and by guys that should know better.
Sent from my LG-V520 using Tapatalk
The Following User Says Thank You to Randy Bush For This Useful Post:
NYgutterguy (02-28-2018)
Old 02-28-2018, 03:28 PM   #6459
water re-locater
The stuff I see on a daily basis is mind blowing. I'm just the gutter sub and I had to tell the roofers to make sure they put a kick out at least for me.
Old 02-28-2018, 05:56 PM   #6460
Randy Bush's Avatar
Rewards Points: 864
I hear you on that, so many guys here don't even bother with them.
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 18 11-22-2017 07:11 PM
Waterproofing Exterior of Block Wall questions. hevnbnd Masonry 0 11-09-2010 07:42 PM
Furring out wall on top of drywall zesone General Discussion 6 10-27-2010 03:28 PM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 07:01 PM
