The Wall Of SHAME!
Old 09-13-2017, 06:42 PM   #5961
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,224
Re: The Wall Of SHAME!
Originally Posted by SmallTownGuy View Post
There's an event you are entitled to called a "pre-closing walk-through."
You do not have to close until you approve the build.
Read/know your rights.
Nope not here that was the pre walkthrough.
Here it's as long as it's deemed livable by the city or town I'm required to close.
Even asked my lawyer and she said as soon as they can get an occupancy permit from the town I'll be required to close and release funds in full.
It's a ****ed up system here in Ontario
Sent from my XP7700 using Tapatalk
SectorSecurity is online now
Old 09-13-2017, 06:43 PM   #5962
I told them I want the ducts cleaned professionally he goes I'll get a guy to put a shop vac down there for you I said not good enough
Old 09-13-2017, 06:44 PM   #5963
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 4,472
Worse. You guys have a national warranty system.
“I tried being reasonable, I didn’t like it.” – Clint Eastwood
“The worst day working for yourself, is still better than the best day working for someone else!”
..Jim Rohn
SmallTownGuy is online now
Old 09-13-2017, 07:16 PM   #5964
B.Johnson's Avatar
Trade: Builder
Rewards Points: 654
I use a laptop, and I see all attached photos.
Might be something as simple as security settings.
I switched to Chrome and the pictures show up. Firefox crashes all the time now anyway, so I guess I'm overdo to switch.
Home Designer Series Software
B.Johnson is offline
Old 09-13-2017, 08:47 PM   #5965
Yup it's a joke your forced to pay for it and they use it as a ploy to get the builder to do things they should have done the first time.
Can anyone confirm my suspicion this is a cold air return? Not sure why it's in the floor first time I have ever seen this.
Old 09-13-2017, 08:51 PM   #5966
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 15,034
Usually if there is no adjustable direction vanes then it's a return. If you have the ability to change the direction and shut it down, then it's either heat or cooling.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 09-13-2017, 11:17 PM   #5967
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,120
sometimes the framing gets in the way and doesn't leave any option but to put it in the floor. Not a great option tho as it tends to collect all the floor sweepings, toys, etc.
Anthill is offline
Old 09-13-2017, 11:26 PM   #5968
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 1,028
Send a message via Skype™ to jlhaslip
I haven't cut a cold air return in a floor in over 30 years. That's Bull Crap.
jlhaslip is offline
Old 09-13-2017, 11:29 PM   #5969
jlhaslip's Avatar
Went for a walk the other day and just had to take this picture.
Yup, that is plumber`s strap hold the Beam to the Angle Iron support.
And no landing. House is occupied. We need a better inspector, me thinks.
jlhaslip is offline
The Following 8 Users Say Thank You to jlhaslip For This Useful Post:
asevereid (09-14-2017), Dirtywhiteboy (09-15-2017), hdavis (09-14-2017), JAH (09-14-2017), KAP (09-14-2017), Randy Bush (09-14-2017), Rio (09-14-2017), SmallTownGuy (09-14-2017)
Old 09-14-2017, 05:26 AM   #5970
John the Builder
Central vac port. You must be wealthy...
..Jim Rohn
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 09-14-2017, 06:10 AM   #5971
Tom M's Avatar
Rewards Points: 9,050
Probably temporary until they do a footing and bring up the grade for the driveway and walk?????? We can only hope......I see so much shoddy construction it laughable
Tom M is online now
jlhaslip (09-14-2017)
Old 09-14-2017, 08:11 AM   #5972
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 3,418
Maybe they are not done with the job and that was just until they got back to it.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Old 09-14-2017, 08:28 AM   #5973
Radical Basement Dweller
Robie's Avatar
Rewards Points: 14,128
My house was built in '66 and all the returns look like that.
Robie is online now
Old 09-14-2017, 08:36 AM   #5974
This seems like it was caused by laziness or a trade not wanting to do their job.
Beyond the fact the hole is larger then the vent I'm going to bring it up with the builder.
Old 09-14-2017, 10:12 AM   #5975
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,242
That's a new home? I thought it was a remodel...havent put a return in the floor ever on a new build.
Sent from my SM-G920V using Tapatalk
overanalyze is online now
Old 09-14-2017, 02:32 PM   #5976
When your sparky forgets to tie in a cable TV outlet just have him spool some cable and hang it from a vent pipe
Old 09-14-2017, 04:10 PM   #5977
hdavis's Avatar
Rewards Points: 2,007
I've seen that before.
Sux to be you.
hdavis is offline
Old 09-14-2017, 04:18 PM   #5978
Easy fix only took about 10 minutes probably took him longer to spool it then to just run it
Old 09-14-2017, 04:41 PM   #5979
dayexco's Avatar
Rewards Points: 150
somebody should help the plumber...that plex looks nasty. not a pro job, that's for sure
dayexco is online now
Old 09-14-2017, 06:17 PM   #5980
If I had to guess they tried to slap most of this together in 2 weeks or less it screams hack.
Gonna talk to some of the guys and trades Tomorrow I get the feeling this is a GC who is stealing from Peter to pay Paul.
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 9 11-29-2010 01:04 AM
Waterproofing Exterior of Block Wall questions. hevnbnd Masonry 0 11-09-2010 07:42 PM
Furring out wall on top of drywall zesone General Discussion 6 10-27-2010 03:28 PM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 07:01 PM
