Wall Framing Using Pressure Treated Lumber
Old 03-03-2006, 07:43 PM   #1
ChuckEA's Avatar
Trade: handyman
I'm framing out a couple of basement walls and a Contractor's Desk employee at Home Depot said that code requires that any lumber touching concrete must be pressure treated, including the wall studs. I thought just the bottom plate had to be PT. (Yeah, I know , I shoudn't be getting advice from HD employees). What say you guys?
ChuckEA is offline
Old 03-03-2006, 07:57 PM   #2
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
Re: Wall Framing Using Pressure Treated Lumber
Well well well. Hd strikes one on the head. Use pt on your bottom plate and tell the dude to butt a stump when you see him again.
http://www.umass.edu/bmatwt/search/f..._moisture.html
Related for your project search this site and you will find the IRC codes you need.
A+Carpenter is offline
Old 03-03-2006, 08:09 PM   #3
Blackhawk's Avatar
Trade: i am a small remodeling contractor been at this most my life
use pt for the sole plate not for your walls u do that and the walls will be bow city..tell that guy to stick with loading lumber..
Blackhawk is offline
Old 03-03-2006, 08:31 PM   #4
bergenbldr's Avatar
Trade: builder remodelor
Homedepot is correct in that common framing lumber must not be in direct contact with concrete,however your walls studs should not be touching the basementwalls but should be offset enough to allow for plumb/lining the walls and for the rigid foam(celotex tuff-r)that you should be useing to insulate.
bergenbldr is offline
Old 03-03-2006, 10:47 PM   #5
fettycan's Avatar
Trade: roofer
I use a vapor barrier fasten to mudplate right aganst block befor i build wall then keep wall 1/2"away from block and PT bottom plate
fettycan is offline
Old 03-03-2006, 11:23 PM   #6
IHI's Avatar
I have not implemented this yet, but intend to on the next basement remodel. I will install 3/4" polystyrene directly agasint the masonary walls and tape joints. Then build my stud framed walls leaving 1" between foam and backside of studs.
Any opinons on this method other than the added expense?
Either way there should be an air space between the studs and the brick wall to allow air flow inside the wall to disipate mositure build up and help prevent mold build up so PT lumber is not needed if leaving the normally accepted 1" space between block wall and wood wall.
IHI is offline
New kind of Pressure Treated wood karma_carpentry Carpentry 23 08-21-2008 09:06 AM
Pressure Treated Wood rjordan392 Carpentry 4 05-28-2007 02:23 PM
Interior wall framing question carlspackler Framing 4 05-16-2007 08:43 PM
trim coil over pressure treated wood?? Lt.H Windows, Siding and Doors 7 04-14-2006 12:12 AM
