Versa Lam Studs?
Old 02-28-2009, 06:18 PM   #1
kdub1777's Avatar
Trade: Builder
Rewards Points: 75
Versa Lam Studs?
I am starting to see the laminated veneer lumber being used as studs. What is the deal with this stuff?
How does it compare with traditional 2x4s or 2x6s as far as quality, durability, price, etc. compare?
kdub1777 is offline
Old 03-01-2009, 09:04 AM   #2
A big wannabe
Gold Tie's Avatar
Trade: General
Rewards Points: 150
Re: Versa Lam Studs?
Quality - Alot better!!! Straight and strong!!
Durability - Its LVL!!!
Price - Its LVL!!!
Gold Tie is offline
Old 03-01-2009, 09:07 AM   #3
mdshunk's Avatar
Rewards Points: 2,002
I've seen some crazy tall clearstory walls framed with that stuff. That seems like an application where it's pretty much called for.
mdshunk is offline
Old 03-01-2009, 09:16 AM   #4
Rewards Points: 2,000
It's great for kitchens and baths.
Hanging cabinets is soooo much nicer!
neolitic is offline
Old 03-01-2009, 09:20 AM   #5
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,016
I saw a house three years ago framed completely in engineered studs and lumber. Of course, the homeowner owned a lumber yard.
We ripped LVLs down to frame for three 8' pocket doors in a recent master bath remodel. It kept the cages much straighter and made it much easier to trim out the jamb. It was worth the extra cost in that application.
Christopher Wright, CR: President @ WrightWorks, LLC
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 03-01-2009, 09:21 AM   #6
mdshunk's Avatar
I've seen fingerjointed precuts every once in a while. I guess you call them engineered studs too. They're actually cheaper than regular precuts a lot of the time.
mdshunk is offline
Old 03-01-2009, 09:33 AM   #7
AtlRemodeling's Avatar
Trade: Residential Remodeling
Rewards Points: 250
We used to get FJ studs all the time but haven't seen them in a few years. The things we straight as an arrow unlike the crap we see now. I attended a Georgia Pacific training session. While I was there they showed us the detail testing data and they actually had higher compression ratings than standard studs. Not sure why they are not more widely used.
AtlRemodeling is offline
Old 03-01-2009, 09:49 AM   #8
mdshunk's Avatar
I liked the looks of them, but if I drilled a hole right on the joint, I could snap the stud in two. I suppose it's best not to do that. A good many of the fingerjointed precuts had a pre drilled hole in them already; particularly the one's from Canada.
mdshunk is offline
Old 03-01-2009, 10:59 AM   #9
Rewards Points: 250
Was not aware of that problem..thanks for the info.
Old 03-01-2009, 11:07 AM   #10
Kent Whitten's Avatar
Rewards Points: 2,040
The guy I talked to at Ainsworth said the reason why is because they use what they call mill runs. Little chunks left over when they cut the regular studs to length. If you measure the pieces on an FJ stud, they are almost always less than 2'. When we ordered them, we sometimes had no choice, there were none.
Though they have better percentages of staying straight, they are not always great. You can use them only for studs, or vertical applications. I have seen a small percentage where the FJ's are offset, so it can be a slight PITA if you accidentally used one of those in a window or door jamb. Some can easily snap if unbraced, so the best application is exterior walls with ply.
I don't know how many I've grabbed, packed it over to a wall for layout, drop the 2x and it snaps at a glue joints.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 03-01-2009, 01:53 PM   #11
kdub1777's Avatar
Trade: Builder
Rewards Points: 75
What is the price difference from with a lvl 2x4 & 2x6?
kdub1777 is offline
Old 03-01-2009, 02:58 PM   #12
General Contractor
greg24k's Avatar
Rewards Points: 7,256
If you do the whole house it will be costly. Like Neolitic said, use them for walls in the kitchen and bathrooms. They also make a solid corner, I use them if the house has a one or two story bay, saves allot of time for the framer and you have a nice solid straight corner.
greg24k is offline
Old 03-01-2009, 04:48 PM   #13
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
I think 92 5/8 were over $6 ea. Compare to about $2 for wood... I think I would rather pick through and grab the best studs for kitchens and baths
RobertCDF is offline
Old 03-01-2009, 07:06 PM   #14
kdub1777's Avatar
Trade: Builder
Rewards Points: 75
Wow. Pretty big price difference there!
kdub1777 is offline
crown with steel studs? rkaitz Finish Carpentry 23 01-31-2009 03:48 PM
metal studs question REdeveloper Drywall 9 01-05-2009 11:19 AM
Hanging vinyl siding on steel studs. thesidingpro Windows, Siding and Doors 16 12-24-2008 05:38 PM
Grab bars - studs and spec hollow wall anchors jmfrederick Plumbing 5 12-13-2008 12:12 PM
Replacing balloon framed studs Danno6102 Framing 10 08-19-2008 05:24 AM
