Vaulted Ceiling
Old 03-02-2008, 07:18 PM   #1
rakuz66's Avatar
Trade: carpentry
Vaulted Ceiling
If you wanted to build a vaulted ceiling but could not use a ridge beam, could it be done? If you were to use (rafter ties/ceiling joists) spaced every 4 ft at top plate tieing walls together?
rakuz66 is offline
Old 03-02-2008, 07:44 PM   #2
Re: Vaulted Ceiling
Depending on pitch, snow load, and
a dozen or so other things....yes.
neolitic is offline
Old 03-02-2008, 07:46 PM   #3
AtlanticWBConst's Avatar
Re: Vaulted Ceiling
Are you a carpenter, or a Home Owner?
- Build Well -
AtlanticWBConst is offline
Old 03-02-2008, 08:42 PM   #4
rakuz66's Avatar
Trade: carpentry
Re: Vaulted Ceiling
I tried to post a pic, but it said I needed to post 15 or more messages. Anyway, the live load is 60, pitch is 5/12, length from plate to ridge is 13 ft, length of room is 15 ft, 2x8 rafters (24 ctr). Opposite side of house is regular ceiling, so vaulted area is only half of gable( or 13 ft). Basically 15 x13. I used 2x10 ceiling joists on both sides of a rafter in the 15 ft length. So I have 7 rafters in this 15 ft. I placed a 2x10( ceiling joist) on both sides of a rafter every 4 ft spanning the 13 ft and all tied in nice and secure to beam and opposite c.joist. I also have collar ties in upper 1/3.
X= C.J.
O=Rafter
---------------Opposite outside wall---------------
-----------------Beam at 13 ft from wall-------------
Gable XOX O XOX O XOX O XOX Gable
FT 2 4 6 8 10 12 14 15
rakuz66 is offline
Old 03-02-2008, 09:07 PM   #5
Re: Vaulted Ceiling
If I followed you, it sounds like that
should work.
neolitic is offline
Old 03-02-2008, 09:35 PM   #6
rakuz66's Avatar
Trade: carpentry
Re: Vaulted Ceiling
Yeah, I wish I coud post this pic.
rakuz66 is offline
Old 03-02-2008, 09:46 PM   #7
rakuz66's Avatar
Trade: carpentry
Re: Vaulted Ceiling
here you go neo
rakuz66 is offline
Old 03-02-2008, 09:53 PM   #8
Re: Vaulted Ceiling
Looks good to me.
I think I'd sandwich some blocking
between the ties, to keep them
operating as a unit.
On 4 season rooms and screen
porches I've run diagonals between
ties and back up to the rafters just
for the truss "look".
neolitic is offline
Old 03-02-2008, 10:01 PM   #9
rakuz66's Avatar
Trade: carpentry
Re: Vaulted Ceiling
I plan on putting in blocking and boxing them in w/ pine to look like a beam. What do you mean by running diagnols to make it look like a truss?? I don't follow??
rakuz66 is offline
Old 03-02-2008, 11:03 PM   #10
dlcj's Avatar
Trade: home builder carpenter Central Alabama
Re: Vaulted Ceiling
looks like you did a good job but all those beams to me would distract the look of a vaulted ceiling. Neo means put in braces from the ceiling beam up to the rafter on a diagonal to look like a giant truss. It would add strength but i dont think it needs it. I like the idea but on 8' centers. Also i have done a few 12/12 vaulted ceilings with no ridge beam and no ceiling beams or trusses
dlcj is offline
Old 03-03-2008, 07:27 AM   #11
Joe Carola's Avatar
Trade: Framing Contractor
Re: Vaulted Ceiling
X= C.J.
O=Rafter
Why did you do all this first and then come here and ask if it's alright? Why would you not ask how to do something the right way first BEFORE you do it?
What happens if you find out that what you did once it gets inspected it wont work, what will you do then?
Joe Carola
Joe Carola is offline
Old 03-03-2008, 09:29 AM   #12
rakuz66's Avatar
Trade: carpentry
Re: Vaulted Ceiling
Joe, I admit I jumped the gun, but it's too late for looking back. What do you think??
rakuz66 is offline
Old 03-03-2008, 09:32 AM   #13
stp57's Avatar
Trade: carpenter/ handyman
Re: Vaulted Ceiling
Hey rakuz66,
I noticed that you green rocked the whole room. Just curious, what are you using it for? BTW, nice work!
Steve
stp57 is offline
Old 03-03-2008, 09:45 AM   #14
rakuz66's Avatar
Trade: carpentry
Re: Vaulted Ceiling
Thanks. I had all that green rock on hand, so I just used it.
rakuz66 is offline
Old 03-03-2008, 10:19 AM   #15
oldfrt's Avatar
Re: Vaulted Ceiling
Alright,
How did you get full length ceiling joists up next to those rafters?
Were they slid in while the plywood was off?
oldfrt is offline
Old 03-03-2008, 11:39 AM   #16
rakuz66's Avatar
Trade: carpentry
Re: Vaulted Ceiling
Those c.j are 16 ft. They overlap opposite c.j. on top of partition wall( which is not in pic). I slid them in through the windows.
rakuz66 is offline
How to install crown on vaulted ceiling sayoungws Finish Carpentry 3 11-24-2007 11:58 PM
Crown on a vaulted ceiling highlife77 Finish Carpentry 5 08-20-2007 11:40 PM
Barrel vaulted ceiling summertime Framing 10 04-14-2007 05:47 PM
Foam insulation over vaulted ceiling DaveM Roofing 5 01-02-2006 10:39 AM
Vaulted ceiling/no ceiling joists medusa Framing 8 12-22-2005 01:57 PM
