Unregistered
Guest
Posts: n/a
Topping Off Uneven Boxes
Dear anyone who might help,
I have these pyramid looking boxes that are going to have cement poured in them. They are 40 x 40 inches on bottom and 24 x 24 inches on top. There is an open top and bottom. How would I go about chopping off an uneven top. The edges don't all fit exactly right. Some are higher and some are lower. I am trying to figure out how to easily mark it all the way around as well as what to use to cut it with Sincerely, A guy who doesn't know what he is doing |
Unregistered
Guest
Posts: n/a
Re: Topping Off Uneven Boxes
Place the boxes on a level surface, say a sheet of ply or similar. Find the lowest point at the uneven top and level a line across that side of the pyramid. If you measure up both edges to the line, they must be equal. Then just measure up all the edges and place a mark the same measurement as before. Join up all the marks round the pyramid and cut with a sharp hand saw. Buy one especially if neccessary, a hard point saw is fairly cheap now. Start cutting across a corner first towards the middle of the two faces - watching that the saw stays on both lines on each face, do that on all corners.
Finally finish cutting through all faces. Finish with a sharp block plane or medium glass paper. Good luck. |
#3 | |
Unregistered
Guest
Posts: n/a
Re: Topping Off Uneven BoxesQuote:
The above may well work perfectly well, but I'd prefer to use a level to extend the initial mark all round, rather than measure up, then you know it will be right. Regards, NT |
| Coating Boxes.. | Al Taper | Drywall | 20 | 09-08-2007 12:50 PM |
| uneven ceiling coat | 72chevy4x4 | Painting & Finish Work | 16 | 05-21-2007 10:25 PM |
| Cutting out electrical boxes | gman | Finish Carpentry | 23 | 12-26-2006 08:11 PM |
| Cover electrical boxes when spraying? | icfbunt | Painting & Finish Work | 14 | 12-16-2006 02:59 PM |
| THHN in cardboard boxes | mdshunk | Electrical | 8 | 09-12-2006 05:47 AM |
