Top Mounted Hangers Against Fire Rated Plywood, Do Studs And Joists Need To Line Up?
Old 08-20-2006, 09:43 AM   #1
personalt's Avatar
Trade: GC/Developer
I have a three family project where I need to hang to joists off the top of the steel wall rather then pass over the wall.. at the top of the wall I have firerated plywood that the bacl of the top mounted hangers rest againt. has anyone built a wall like that? I am wondering if the plywood will provide enough support or do my joists need to line up with the studs. I have a call into the engineer but he is on vacation this week.
personalt is offline
Old 08-20-2006, 09:54 AM   #2
mdshunk's Avatar
Re: Top Mounted Hangers Against Fire Rated Plywood, Do Studs And Joists Need To Line Up?
Yes, that is a question for an engineer, but it begs a question from me. Why wouldn't you just frame that wall shorter and set the joists on top of it?
mdshunk is offline
Old 08-20-2006, 04:24 PM   #3
personalt's Avatar
Trade: GC/Developer
it has to do with the fire rating. the exterior and load bearing walls need to be continous steel. with double 5/8 sheetrock. the joists can't be on top because in a fire they will burn and floor above will collapse. for interior walls I could go over studs if I added squash blocks but outside must be hung from top of steel. I will have to get ahold of engineers assistant as this is not a common design.
