Timber Frame Cabin
Old 05-16-2006, 11:14 PM   #1
n8sr's Avatar
Trade: home remodeling
Timber Frame Cabin
im building a cabin at our property this year and thinking of timber frame construction.with all the wooded area needed to be cleaned out thre is plenty of lumber.has anyone ever used a portable chainsaw mill
to mill there own lumber or am i better off trying to find a used portable mill
n8sr is offline
Old 05-17-2006, 01:53 AM   #2
reveivl's Avatar
Trade: Renovations
Re: Timber Frame Cabin
Yeah I have. I don't recommend it unless you have no other way to get the trees square. It's noisy, slow and hard work, and difficult to make it accurate in terms of size and square. That being said, it certainly can be done and you'll wind up with a building that you are intimately connected with every surface in it. Keep us posted on your project
reveivl is offline
Old 05-17-2006, 06:41 AM   #3
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
I would advise that once cut and sized to store them in a barn for at least 6 months. A year would be better. This will allow the moisture content to stabilize and the timbers will be preshrunk before you use them. Stack them flat with stickers between every board for good airflow.
Dave.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 05-17-2006, 07:25 AM   #4
joasis's Avatar
There is a sub forum in forestryforum that deals with timber framing, also on the woodweb. I would not use a chainsaw mill, period. A bandmill is a better investment and will hold it's resale value. You can get a mill to do what you want for $3000 new and less used.
joasis is online now
Old 05-17-2006, 09:51 AM   #5
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
yes both work just as good. depends on how hard you want to work
I built houses on the borders of Wyoming and Colorado and we even scaled our own logs. AWESOME STUFF
A+Carpenter is offline
Old 05-17-2006, 02:08 PM   #6
JAL's Avatar
Trade: Electrical
check in the phone book. I have seen portable mills that will cut your wood for about $150 to $200 a thousand board foot.
Look at Baileys-online.com for a saw mill if that is what you are looking for instead.
JAL is offline
Old 06-01-2006, 11:03 PM   #7
n8sr's Avatar
the hard work im really not worried about,the biggest thing was my worry of accuracy of the board cut. time is also not an issue this is a weekend/while im camping kind of a project.would like to have it dried and ready for build by spring 07.biggest reason i was looking at these is for the price difference. any other suggecstions
n8sr is offline
Heating system suggestions for a cabin in UP MI. Flying Monkey HVAC 5 08-22-2007 11:40 AM
Metal or Wood frame? gcajnr21 Carpentry 6 04-20-2007 11:29 PM
Timber frame arch & Iron need sources Oregon_Rob Carpentry 0 07-27-2006 01:03 AM
Hybrid Timber Frame 4powells Framing 3 04-03-2005 01:42 AM
Fancy timber frame entry ideas. Nick Carpentry 2 01-31-2005 12:34 AM
