Trade: carpentry
Suggestions On Design For Wooden Driveway Gate?
i have to build 2 sets of driveway privacy gates made form Redwood.
The owner doesnt want anyone to see strait through them, She lives in a high wind area and there will be alot of wind load on them when they open, They will be on a solar opener. I was thinking about riping the wood to 2x2 alternating on either side that way when you look strait it looks solid but on a angle the wind can flow threw them as they open then picture framing them with 2x6 on all sides to finish it . any suggestions or thoughts maybe pics/ and they have to be 6 1/2 inches thick finished. to fit the existing hinges... |
Palisade Point Const.
Re: Suggestions On Design For Wooden Driveway Gate?
If they have to be 6 1/2" thick, then 2x6 is going to be an inch too narrow for the edges. Ripped down 2x8 might work.
Have you considered 1x angled slats? For bracing, it might work to build the frame, add any bracing inside the frame, and then run the slats or whatever so that it breaks over the bracing. |
Sean
Pretty good article from FHB - you might be able to get some inspiration from it
http://www.finehomebuilding.com/how-...t-to-last.aspx |
Trade: carpentry
I was going to build the frame out of 2x6 then add 1"by 1 1/2 vertical slat's then wrap the out side with 2x6 again that will make 6 1/2 thick. so the center will be 2x6, then 1 inch slats on either side alternating then 2x6 picture framed on either side , does this make sense i wish i could draw it for you...
Maker of fine kindling
6 1/2" is pretty thick. Not sure how wide the gates need to be. Can you offer some more info about the hinging?
Wide gates will need some kind of angle bracing incorporated into them. What if you did something like these but with a crossbuck pattern for the frame. With some 1x or 2x slats placed in a louver pattern. OK these are nothing like what I described but I like picture books. ![]()
Every parent who has walked barefoot into their child's room late at night hates Legos |
#6 | |
General Contractor
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Re: Suggestions On Design For Wooden Driveway Gate?Quote:
I posted some ideas on keeping a Carriage House door light HERE. You might get some thoughts from the drawings.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Bill Everett - St. Petersburg, FL Last edited by Willie T; 10-18-2009 at 10:50 PM. |
Trade: carpentry
Yes they will be heavy the gates are 14 feet wide divided into 2 seperate gates by 6 feet high, yes there will cross bracing involved.
General Contractor
Read about the advantages of using modern methods HERE.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Bill Everett - St. Petersburg, FL |
Builder/Remodeler
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
Trade: carpentry
this is the gates now, i have to keep them close to this as possible but still allow the wind to move through them while they open to lesson the wind load on the openers at the same time keep it private so you cant see strait through them.. the bottom pic you can see that i have to match the 6 1/2 inch hinge..
I wouldn't limit myself to that hinge configuration. That can be changed real fast.
#12 | |
General Contractor
#13 | |
Builder/Remodeler
![]() But his stuff is top notch for quality and longevity. He built a garden gate for me:
Trade: carpentry
The owner does not want to change the hinge. this is why i am stuck with the 6 1/2 thickness.. they actually work really well very strong ..
why not do a board on board enclosure like what is found on dumpster bins. The frame would have to be beefier-I would consider a large piece of aluminum or stainless steel as a crossbuck to keep it from racking after time. I would recommend wider boards, say 8" but with 6" of offset. That is on 8" boards spaced 6" apart on each side of the gate (offset). very simple gate-maybe to simple for what you are looking for.
Trade: Construction
A design suggestion for you -
6x6 redwood for the outer frame, dado a 2" x 2" deep notch on the inside edges, open mortise and tenon connections for corner connections w/ through bolts and glue. Interior panel of 2" actual x10 redwood t&g dadoed on the sides, glue 2x10 panels together. Assemble bottom 6x6 rail w/ both side 6x6s, insert 2x10 paneled section (glue up all edges). Install top 6x6 rail over top of 2x10 section, glue top rail to interior section. You won't have to worry about wind, you will have to worry about weight. Hinges shown should handle a gate built like above, no problem...opener hardware might be another story. How many pounds is the opener arm rated for? I'm just about finished w/ a fence and gate project that I can post pics of to show you what I'm talking about. Obviously, I'm working on a smaller scale (3x6 outer rails, 2" nominal x 6" t&g inner panel, 4' wide by 6' tall) but you'd get the idea. I'll take pics tomorrow ... Mac |
Trade: GC/Remodeling
It sounds like the opener is the problem... Can't handle the wind load when extended..
How about mac's plan, but the 2x 's turned 45 and overlapped ___________ ___________ ////////////// \\\\\\\\\\\\\\\ nice drawing huh
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
#18 | |
Lets call it modify. Trim the 6 1/2" part down and weld the mounting plates back on. I see no reason why that couldn't be sold to them as an improvement. Less weight = longer life. Thats what the doctor says. ![]() Those gates in my pic above are out of 3x cedar. I can't imagine wanting to go heavier than that. Just my opinion, disregard if you want.
#19 |
Trade: carpentry
Thanks guys, i would love to see the pics MAC....
#20 |
Trade: Construction
HO stained them over the weekend, I'm installing them today. Pics tonight.
Mac |
| Home Design Software - i.e. Punch Home & Landscape Design | Panzer5 | Technology | 19 | 12-29-2008 11:09 PM |
| Vinyl fence gate posts | Danno6102 | Decks & Fencing | 6 | 10-20-2008 10:42 PM |
| Gate design | curapa | Decks & Fencing | 39 | 07-09-2008 11:04 AM |
| Free Download: Advanced Energy Design Guide | Ed the Roofer | Roofing | 0 | 02-09-2008 09:01 PM |
