Storm Door Problem
Old 03-06-2007, 04:09 PM   #1
wmerrell's Avatar
Trade: Home Builder/Remodeler
Storm Door Problem
I got roped into installing a storm door for a customer. Storm doors no biggie. I have an issue with this one. I have an entry door with 2 sidelights the same height as the door, and there is a transom light also. The space between the entry door and the storm door will be 1 3/8". I feel that I should fir this out because it looks like the lockset will hit the entry door before it will latch. My problem is that the jamb is one piece with the edges rounded over. I thought that I would simply fir this out with some 1" to get my clearance. I think that this will not give me a nice clean look from the side. I hope I am describing this well enough to get some possible solutions. I thought that using some wood filler of some sort might do the trick. Any ideas?
wmerrell is offline
Old 03-06-2007, 04:20 PM   #2
Tom M's Avatar
Re: Storm Door Problem
I have had this happen as well. I forget the circumstances but the lockset for the storm doors is usually around 39 1/2" from top or bottom. Check if it clears, and if not, position the storm latch so it falls in between the dead bolt and door knob. If the storm is pre-bored and conflicts then your on the right track with some furring just be aware the sweep will become useless if you do too much.
Tom M is offline
Old 03-06-2007, 07:29 PM   #3
wmerrell's Avatar
Thank you. I did not even think to see how far off the threshold I can fur out. I am feeling like a DA on this one. Too much thinking for a storm door.
wmerrell is offline
Old 03-06-2007, 08:30 PM   #4
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
You need to extend the wood between the prehung and the sidelights so it is flush with the top molding. Generally this extension is 2.25" and you can order the door with this done or use 2 layers of 5/4 stock. Rip your first layer at 2" (the same width as the mull) and your second at 1", attach the 2" layer first and then center your second layer to create a 1/2 revel on the sides---this should leave you with 36" for your storm door RO.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 03-08-2007, 10:47 PM   #5
THE FINISHER
lawndart's Avatar
Trade: Finish Carpenter
Send a message via AIM to lawndart
Sometimes, I find that installing the storm door, can be more of a challenge than the exterior door. All types of adjustments, and things to consider, varying by manufacturer, It takes a good deal of time, to learn all the tricks IMO.
lawndart is offline
Old 03-28-2007, 12:45 AM   #6
Terrence's Avatar
Trade: painting and carpentry
I just wanna know exactly how you got "roped in"?
Did you give up your free will?
Suddenly no longer the master of your domain?
{ did she offer s.e.x.} heh
Terrence is offline
Old 03-29-2007, 08:11 PM   #7
devil_121's Avatar
Trade: wood working
My friend I think the manufacturer may provide a stick-on template to show exactly what to do and from where you can do what in the latch set. This is extremely helpful. If one is not provided, determine the height of the latch set, then carefully mark the screw positions with a pencil. If you still having problem with it then why don't you contact them?
cafe style plantation shutters
devil_121 is offline
Old 11-24-2007, 09:06 AM   #8
doordr's Avatar
Trade: Professional Contractor
Hi. You had several pictures of a storm door build out on an entry with sidelights. I was unable to open those pictures for some reason. Could you send me those pictures of the process? ibookem2@comcast.net thanks D
doordr is offline
Old 11-24-2007, 01:12 PM   #9
Insert title
dougchips's Avatar
http://www.contractortalk.com/showth...ht=storm+doors See if you can open them up in this thread, if not send me an e-mail.
Old 11-24-2007, 09:37 PM   #10
doordr's Avatar
Perfect Thanks!!
doordr is offline
Old 12-28-2007, 07:51 AM   #11
Crossgate-Matt's Avatar
Trade: Replacement Windows and Doors. Trim Carpentry and Decks
Thanks alot for the great info. I think that there is no other project that will make you cuss your trade and question your abilities like a storm door.
Crossgate-Matt is offline
Storm Chasers IHI Roofing 68 02-10-2008 03:31 PM
Storm Windows swamppro General Discussion 1 08-17-2007 02:51 PM
Hail Storm After Life Travis Roofing 17 07-29-2007 09:11 AM
Dust Storm Cole Off Topic (Non Trade) 2 02-27-2007 09:56 PM
insurance companies and storm damage mikefromcincy Roofing 4 10-22-2005 05:39 PM
