Trade: Complete exterior shell, pole barns, structure and cosmetics
Steel Beam Replacement
I have a house where the main basement beam is 4 2x6's laying flat on 10' span...needless to say the house has sagged everywhere..So we are pulling it out and replacing is with a steel I beam..The basment height is resticted and therefor i can not place fllor joist on top...I'm curious as to the best way to fasten the new 2x10 floor joists into the web of the beam.? While we are redoing the whole basement ceiling they requested to have a post relocated for a pool table..so the beam is a 12" web 1/2 plate and is 33' long. I've thought of getting the beam with channels welding in it already..
Thanks Ontario,canada |
Trade: Construction
Re: Steel Beam Replacement
What about bolting a 2x10 to the side of the beam and nailing joist hangers to it? Hang your floor joists in the hangers...
Just a stab in the dark - I've never actually done that. Mac |
LVL's are a far better choice for
retro-fit than an I beam. It's easier to slip 2 or three pieces up into the slot where the joist are cut off, and still be tight enough to fasten them. Not to mention just lifting that chunk of iron instead of 2 or 3 LVL's. Never did a retro with hung joist *on steel* for that reason. We did finish one with LVL that someone else started. They got the beam in the basement before they figured out it wouldn't work like they thought. Very expensive scrap iron! Make sure the pads are sized for the load when you move the columns.
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 02-08-2008 at 12:08 PM. Reason: to correct ommission |
Trade: Geotechnical PE
if you can't get lvl's or another wood product to work, what about a saddle hangers with wood filling in the web?
#5 | |
Al Smith
Re: Steel Beam ReplacementQuote:
Sounds complex, and expensive.
Nice solution though. No issues with sub floor sitting on steel? The idiots we followed "planned" to leave the joist long enough to use the bottom flange as a ledger, and "tilt" the freaking 900lb beam into place between them!
Al Smith
actually it wasn't that bad. It was for a job that included an nice vaulted ceiling addition so the cost was built into the addition price. if i recall i only charged them about three grand for that part of the job. which included hand excavation through the slab for two footings and a pair of .250 wall 3 1/2 x 3 1/2 box tube columns. the house had no basement, it was a slab. I think it came in just under a 14 foot span. maybe 13. it was long time ago 17 years at least.. The hard part was finding the steel beam. I called all over the entire state one day to every steel supplier I could find in the yellow pages, I found a huge steel supplier in Bayonne NJ. I don't think they are there anymore. Yes the sub floor rests right on the top flange and the Sheetrock i had to patch a four foot wide strip in the center of the room right against the bottom flange. Luckily the existing sub floor didn't break at a seam right over the flange.
#8 | |
Thanks |
#9 | |
the beam to give you the pattern for the bolt holes. Too many, or too close, and you may wind up weakening the web, and you don't want it to be on you. I guess from the tone, you already bought the steel? Good luck!
#10 | |
Thanks for everyones imput!!! |
Al Smith
be sure to supply the engineer with the existing joist layout. You don't want the bolt hole punch outs to align with your hangars. that would sure be a problem. Also don't slide both 2 x 10s in place along with your i beam or you will not be able to find the holes to drill through. Slide one side first drill it then the other side and drill through your other side. or you could drill all your lumber before you slide it in on a bench. Just don't mix up the sides or ends or put them in upside down.
Captain Obvious aka |
#12 | |
lumber yard/supplier to size some LVL's for you! Give them the span column to column, joist span, # of floors above, roof (bearing or not?), etc. It would be good to have price to price. Plus I swear you will like hoisting 3 or even 4 pieces of1¾" LVL better than that I-beam!
A W Smith it never hurts to hear suggestions.. the floor joists i am re working anyways, on top of the current floor joist they have 2x4's laying flat 16" o/c perpendicular to the 2x6 and 2x4 current floor joists. it is a really weird set up..and kinda scary it is still standing. How'd this ever pass?...but anyways i am going to leave the 2x4s and the sub floor and just put in new 2x10 12' o/c under the sub floor ...
neolitic- It would be nice to get a LVL in there..but i have a restricted height right now..and i was told the LVL for a 20' span 2 story is close to 15" i can not go over 12... So it might come down to a lot of grunt work and swearing when this monster comes in though the basement window |
#14 | ||
That gives me a headache just reading it!Good luck with that mess. Quote:
can be replaced with four 12", or something like. Still not too late to check, and it ain't gonna cost anything to check it out. 2¢ Have fun and let us know how you come out. Pix is always good fun. ![]()
#15 | |
Trade: GC/Carpenter
In the past year, we've done 4 I-beam replacements and bolted 2x on both sides of the beam and joist hangers. Easy.
Trade: Carpentry, Roofing, Framing, Home Improvements
You would have to consult the steel company, but what about drilling holes through the vertical section of the beam and lagging 2x's on either side. Then you could hanger off of those.
I would recommend what someone else had stated and go with LVL's |
#18 |
Trade: Carpentry/ Home Improvements
yep packed beam the way to go. I basically built one but its a lot easier to order it prebuilt. betterheader.com have fun manhandling that steel. had a good friend of mine take a helicopter ride to the hospital due to a helpers lapse in attention. thank god I wasn't on that job or he'd have been out of work for a month and been short one dumba$$ helper....
Alex |
| Updating main beam in century-home: end. | bob_cntrctr | Framing | 8 | 02-07-2008 04:04 PM |
| Steel I beam capacity | IHdonnie | Construction | 13 | 10-21-2006 09:42 PM |
| deck beam sizing and post spacing? | diyerforever | Decks & Fencing | 5 | 05-10-2006 10:58 PM |
| ideas for wood stud wall attachment to steel "I" beam? | durham | Construction | 9 | 05-10-2006 06:45 PM |
| Can I replace a W8x35 x 20 foot steel I beam with... | Ray | General Discussion | 8 | 03-20-2006 03:38 AM |
