Steam Bending
Old 10-14-2009, 07:54 PM   #1
crovello's Avatar
Trade: General contractor
Steam Bending
I have a project with a curved deck and stairs. The decking material is Ipe. I have heard many stories of unsuccessfull glueing of Ipe. I plan on building a steam box so I can try bending the deck boards. The smallest radius I will have to deal with is just over 11' and the larges is nearly 15'. I have two questions.
1) How wide of a board do you think I will be able to bend on edge? The main deck is 3 1/2" but I could be convinced to use narrower strips on the curved steps if need be.
2) Will I get enough steam from a wallpaper steamer rented from HD? I was there yesterday and they have an old rental they are selling for $152. I would buy it if I thought it would generate enough steam.
The house itself has a few curved sections so I milled my own Azek soffit matterial. With just a little heat it sure cuved nicely. I thought I was going to have to buy heating blankets but with such a large radius it did not take much to bend them.
Thank for any advice
crovello is offline
Old 10-14-2009, 08:12 PM   #2
Re: Steam Bending
Since ipe doesn't absorb water,
I'm not sure what kind of result
you can expect.
The generator doesn't have to
produce all that much steam,
you just need to build a chamber
to hold the lumber in the steam.
Put some ends on a pipe,
set it on an incline-generator at
the bottom, door at the top.....
neolitic is offline
Old 10-14-2009, 08:23 PM   #3
crovello's Avatar
Re: Steam Bending
Because Ipe is so dense I would not expect it to work well with steam bending but after doing some research on line I am rethinking this. I have read several atricles about people saying they have had success with steam bending Ipe but I am sure they were not trying to bend 1"x4" on edge. I also found a paper rating different wood on bending properties and Ipe scores well. Big shock to me.
I plan on building a large enough box to steam a dozen 12' boards. I have found many sites with plans on how to build them.
Thanks for your input
crovello is offline
Old 10-14-2009, 08:27 PM   #4
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Re: Steam Bending
I too am surprised by this info! We have tried to glue it with very little success - I think it's too oily!
"Being willing is not enough; we must do". Leonardo da Vinci
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
Old 10-14-2009, 08:38 PM   #5
crovello's Avatar
Re: Steam Bending
One way or the other I am going to give it a shot. I will post results next week after my test bend. I will take a few pictures and if I can figure out how to post them I will.
crovello is offline
Old 10-15-2009, 07:24 AM   #6
jaros bros.'s Avatar
Re: Steam Bending
I know that you have to burn off the parts that will be glued up on ipe because of the oil.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas
jaros bros. is offline
Old 10-15-2009, 07:44 AM   #7
72chevy4x4's Avatar
Re: Steam Bending
Target has a higher volume steamer which was inexpensive (<$40).
72chevy4x4 is offline
Old 10-17-2009, 01:02 PM   #8
crovello's Avatar
Re: Steam Bending
I tried steaming some Ipe on Friday using the steam box I built and a rented wallpaper steamer. The box is large so I can bend 12' boards and the rented steamer just didn't create enough steam. I have modified my lobster steamer and will try again on Monday with a higher volume of steam.
I will let you know how I made out.
crovello is offline
Old 10-17-2009, 02:12 PM   #9
Re: Steam Bending
We'll be here, waiting to hear.
neolitic is offline
Old 10-20-2009, 07:49 PM   #10
crovello's Avatar
Re: Steam Bending
I tried steam bending the Ipe decking on Monday. I had my modified lobster pot and burner connected to the steam box with pex tubing.
The setup sure did create alot of steam. The box is 13'x12"x9". It is made from 3/4" ply and wrapped with 2" rigid insulation. A half asses setup but good enough for a test run. Within 20 minutes the box was 210+ degrees and steam was pouring out of the drain tube. I had several strips of Ipe in the box. 3 1/2" -2 1/2" - 2" and 1 1/2". I let them steam for nearly two hours.
I pulled the narrow strips out first and with some effort they took the shape of the 11' radius. With more effort I may have been able to force the 2 1/2" strip into place but I would not be confident it would stay there. The full size deck board had zero chance of taking any of the radii I had to bend.
Another issue I had was one of the boards came out looking terrible. It had oil coming out of it. It was a sticky mess and could never have been used for the finish product. Since I only tried several boards I don't know what percentage of them would have come out like this.
All in all I was not happy with the results. Also I had no way to tell how much water I had in the pot. I was suprised how easily an aluminum pot can melt I melted a six in hole through the bottom.
Tonight I took some Ipe back to my shop, ripped it to 1 1/4" strips and put it through my shaper to give it a T&G profile. It is a tapered T&G that fits together perfectly and I am hoping to laminate them together. I am wondering if I should have used my finger jointing knifes instead. I have not ready many great threads on gluing Ipe but I really don't want the treads to have several butt joints along their 14' arc.
crovello is offline
GreenBoard vs. DuraRock/Mud walls For A Steam Shower Longghairr General Discussion 19 11-06-2009 12:05 AM
240v steam generator golonaus Electrical 7 01-07-2009 11:39 PM
Bending AZEK Trim hailey Windows, Siding and Doors 5 12-13-2008 05:19 PM
Bending AZEK Trim and Moulding hailey Finish Carpentry 1 12-11-2008 05:54 PM
steam boiler locked out Tom M Plumbing 52 10-10-2008 12:38 AM
