Stairwell Half Wall
Old 07-29-2017, 09:16 PM   #1
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 10,534
Stairwell Half Wall
Looking for suggestions on the best way to build a stiff half wall around this stairwell.
Orange lines indicate ceiling line change from vaulted to flat. Blue lines are strictly halfwall
A&E Exteriors is offline
Old 07-29-2017, 09:27 PM   #2
Texas Wax's Avatar
Rewards Points: 708
Re: Stairwell Half Wall
Notch and let in a dbl2x4or 4x4 like newel posts. Build the wall between.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following 5 Users Say Thank You to Texas Wax For This Useful Post:
hdavis (07-29-2017), Jaws (07-30-2017), jlhaslip (07-29-2017), Justin Rhoades (01-13-2018), pinwheel (07-30-2017)
Old 07-29-2017, 09:28 PM   #3
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,261
If you are unable to tie it into the floor, I would suggest some angle iron and lag bolts.
Easy Gibson
Warren is online now
Old 07-29-2017, 09:37 PM   #4
I could tie into the floor framing around the rim fairly easily with GRK's. My concern there is that I don't really want to cut holes in the ceiling. Would I need to block around the posts being the holes will be right at the perimeter or will such small holes not matter?
Old 07-29-2017, 09:49 PM   #5
Geometrist
Warren's Avatar
Just cut the plywood back enough to allow the blocks to be installed.
Easy Gibson
Old 07-29-2017, 10:05 PM   #6
The more I think about it a 2"x3" hole should be fine right? I mean my my duct vents are 6x10
Old 07-29-2017, 10:08 PM   #7
hdavis's Avatar
Rewards Points: 4,471
There are a few ways to do this. The first question, is do you want to be able to take it down to bring furniture / bulky items up easier?
If you want to take it down and put it up fairly easily, use something like this:
http://www.ljsmith.com/products.aspx...e=9&product=11
Tons of other ways to go. I always liked framing it with blocking and dropping it in.
hdavis is online now
Old 07-29-2017, 10:15 PM   #8
I overlooked it in planning
The Following User Says Thank You to A&E Exteriors For This Useful Post:
hdavis (07-29-2017)
Old 07-29-2017, 10:16 PM   #9
And no, this will be permenant....not removeable
Old 07-29-2017, 10:16 PM   #10
hdavis's Avatar
I must be missing something - cutting holes in ceiling?? Your blocking doesn't have to run down to the ceiling.
I'm not sure why a 2X3 hole in the floor would be a concern, unless you'd be cutting the stairway framing.
In renos, I tend to use the surface mount style - the added work dealing with finished surfaces makes it preferred.
Old 07-29-2017, 10:21 PM   #11
hdavis's Avatar
You just have subfloor down, just open it up enough to put in the blocking you need, and put the same piece of subfloor (minus the post cutout) right back in.
If that won't work with your stair framing, use a surface mount style. Angle iron and base wrap to cover is pretty common.
Old 07-29-2017, 10:37 PM   #12
I think I am gonna roll with the 2ish x 3" hole and call it a day. I think I was thinking decking mentality for something that has a sheetgood floor
The Following 3 Users Say Thank You to A&E Exteriors For This Useful Post:
Californiadecks (07-29-2017), hdavis (07-29-2017), Texas Wax (07-29-2017)
Old 07-29-2017, 11:24 PM   #13
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 68
Send a message via Skype™ to jlhaslip
You only need one or two on each length of wall, not every stud.
jlhaslip is online now
The Following User Says Thank You to jlhaslip For This Useful Post:
A&E Exteriors (07-29-2017)
Old 07-29-2017, 11:30 PM   #14
I know that much! LoL
Old 07-29-2017, 11:58 PM   #15
hdavis's Avatar
Building a half wall, he just needs the posts solid, and pop the bottom plate down to the floor. Maybe past 8' or so he'd need another post just for the stiffness, but a 1X6 cap or double top plate can stiffen it as well.
Old 07-30-2017, 03:41 AM   #16
Hack
asevereid's Avatar
Rewards Points: 206
Just throwing this out there... Could you sheath the interior of the wall with quarter inch ply down through the RO and then rock it with quarter inch drywall?
Wouldn't that stiffen if up plenty?
The last knee wall I framed up was with a double 2x post beside a rim joist through the floor, but it still had a bit of wobble to it. Nothing dangerous, but enough to bug me.
Sent from my Gravity 5 LTE using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 07-30-2017, 07:09 PM   #17
Pretty damn stiff
The Following 2 Users Say Thank You to A&E Exteriors For This Useful Post:
Californiadecks (07-31-2017), hdavis (07-30-2017)
Old 07-30-2017, 07:18 PM   #18
jlhaslip's Avatar
Rewards Points: 68
that's what she said.
- anon
lol
A&E Exteriors (07-30-2017)
Old 08-06-2017, 09:54 PM   #19
Rewards Points: 746
I've thought about trying these if all else fails. We've used them on decks and they work well. Maybe just cut the subfloor back to hide the base?
Timuhler is offline
The Following User Says Thank You to Timuhler For This Useful Post:
A&E Exteriors (08-07-2017)
Old 01-09-2018, 11:26 AM   #20
arrowguy's Avatar
Trade: Windows, awnings, security doors
Rewards Points: 4
don't forget to post any updates or follow ups is/when you got em!
Jeff
Arrow Window
arrowguy is offline
Grading & base InterCounty Masonry 8 06-11-2013 11:11 PM
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 11:56 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 07:17 AM
Have Questions Regarding erection of Exterior Block wall rxotik Masonry 1 09-10-2012 11:42 PM
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 05:57 PM
