Stair Tread Notch/picture Frame
Old 09-02-2017, 09:26 PM   #1
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,161
Came across this image online and was wondering who has done this and how does it hold up?
I'm in PA with cold winters and hot summers, so I'm not sure if this concept would even work in my climate.
For those that have notched and covered the edge like this, how's it done?
Stair tread notch/picture frame-img_9497.jpg
philcav7 is offline
The Following User Says Thank You to philcav7 For This Useful Post:
A&E Exteriors (09-02-2017)
Old 09-02-2017, 10:08 PM   #2
Talking Head
EthanB's Avatar
Rewards Points: 14
Re: Stair Tread Notch/picture Frame
Heh. That's my picture.
That was actually the first deck where I did my returns like that. I don't like the extra 1.5" scab on the bottom of the fascia but the HO asked for it after the fact and didn't care about the seam. The returns have been holding up well. I think the oldest one I've checked on recently was 4 years old.
I'd cut the returns on a tablesaw and miter saw and cut the front treads with a circ. saw from the back so I could over cut them a bit to get a clean joint. In the pic I only used one screw in the front tread but on later projects I would use 2. I put a little PL Premium on the joint for composite and PVC cement on PVC.
It's important to predrill the holes for the cortex screw and use a forstner for the plug. If you don't predrill the screw hole it will just spin out and not countersink and, on composite boards, if you don't drill a hole for the plug it will mushroom pretty badly.
On the rear tread I would oversize the hole in the return a fair bit so that the head would just catch to allow for some movement in the tread board. Just snug the cortex up enough to hold the return tight to the tread board. Predrill the plug hole first or you're going to have a hard time lining it up.
Our weather in RI is pretty much identical to yours so I think it would work for you.
Planer.....
EthanB is offline
The Following 5 Users Say Thank You to EthanB For This Useful Post:
A&E Exteriors (09-03-2017), B.Johnson (09-03-2017), Rio (09-03-2017), TBM (09-05-2017), Tom M (09-03-2017)
Old 09-03-2017, 10:47 AM   #3
philcav7's Avatar
Small world.
Does any adjustment for cool weather install need to be considered? I think I'm going to try this on encapsulated azek in a few weeks.
I was considering using a jig and router to cut the front board and finish of the inside of the angle with a jig saw. I will be testing some mock ups.
Thanks.
philcav7 is offline
Old 09-03-2017, 12:25 PM   #4
Talking Head
EthanB's Avatar
Rewards Points: 14
Small world.
Thanks.
Letting the screw to the back tread board float a bit seems to do the trick.
You could do it with a router if you have a lot to do or you're not comfortable freehanding miters. I never got around to making a jig and the circ saw went pretty quick but I did say I was going to make a jig every time I finished doing a run with this detail. I just figured out how far to overcut on the back side to get right up to the line on the front and marked it on my layout. It varies because of the saw and the board thickness. Any remaining little bit I cleaned up with a chisel.
Planer.....
EthanB is offline
Trim frame before or after putting up attic ladder Spencer Finish Carpentry 26 08-03-2016 11:46 AM
Contractor body build for my '54 Chevy 1-1/2 ton mehtwo Vehicles 300 11-08-2014 02:01 PM
Help! No-Bore Concealed hinge on Face frame, overlay cabinet with 1/2" thick doors! RDBD Kitchens & Baths 18 11-11-2013 11:58 AM
Should we frame flooring joists? DavidReid1985 Flooring 2 10-05-2012 11:31 PM
Commercial Door Frame Installation Help kenscott88 Windows, Siding and Doors 9 02-09-2011 04:34 PM
