Stair Designer
Old 03-10-2004, 09:31 PM   #1
General Contractor
hatchet's Avatar
Stair Designer
In light of the stair framing post I thought I would throw together a quick excel file to figure stair risers and treads. It has an image there that shows what each of the dimensions are. It was put together really quick so it might have some bugs.. let me know if you find any.
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 03-10-2004, 09:32 PM   #2
General Contractor
hatchet's Avatar
Re: Stair Designer
Oh.. and I did it a little backwards.. the instructions are at the bottom
Rich
hatchet is offline
Old 10-03-2008, 06:33 PM   #3
dokuhaku's Avatar
Trade: floorcovering
Re: Stair Designer
Still have that excel document? I would be interested in seeing it.
Thanks,
Phil
dokuhaku is offline
Old 10-05-2008, 01:58 PM   #4
General Contractor
hatchet's Avatar
Re: Stair Designer
Sorry about that. When I moved servers I didn't put that file back up.
This designer was really meant for my use - and when I decided to put it up here I added some very basic instructions. It could be difficult to understand what it's saying - so do look at the formulas before taking any output as gospel. It sets initial riser height at 7.25" - if you want something different you can edit the formula in C9 changing 7.25 to something else.
Let me know if you have any questions or even if you want me to modify/create something for your use.
Rich
hatchet is offline
Old 10-05-2008, 02:40 PM   #5
PA woodbutcher's Avatar
Re: Stair Designer
Thats a slick little formula you got there thanks. Have always done my own (without a construction master). Been doing them since I was about 14-15 years old. That can be a real time saver.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 10-08-2008, 01:19 PM   #6
General Contractor
hatchet's Avatar
Re: Stair Designer
Thanks.. it does work pretty good. The crew likes it because it prints everything on one page that they can take to the jobsite without having to figure it out on the spot. I made them all do it long hand for several stairs before I gave them this though.
Rich
hatchet is offline
Old 10-12-2008, 10:28 AM   #7
dokuhaku's Avatar
Thumbs up
Re: Stair Designer
I appreciate you posting that!
dokuhaku is offline
Old 10-12-2008, 11:33 AM   #8
A big wannabe
Gold Tie's Avatar
Trade: Framing, decks, trim, Remodels, ground up.
Re: Stair Designer
That's pretty cool! The only thing I see missing is the use of a toe kick. I see the bottom riser adjustment for tread thickness, but no top tread adjust for toe kick thickness.
Gold Tie is offline
Old 10-12-2008, 01:21 PM   #9
General Contractor
hatchet's Avatar
Re: Stair Designer
Very true Gold Tie.. I have never really worried about that in the program as I just take care of it in the field.. but I could tie in another couple fields for upper level flooring thickness so there is a check from subfloor to first tread adjustment. If I get the time I'll post another one with changes.
Rich
hatchet is offline
Old 01-17-2009, 09:01 PM   #10
deckspec
deckspec's Avatar
Trade: deck contractor
Re: Stair Designer
would also be handy to make a chart of common heights
paul
http://www.deckspecialists.com/
deckspec is offline
Old 01-18-2009, 08:14 AM   #11
j.m.s.'s Avatar
Re: Stair Designer
Thanks, I do it with calculator usually, but I always like to check my answers with another method. Does anyone have an estimator for Xcel? I wish I was more proficient with excel, than I would come up with my own.
Joe
A Constitution of Government once changed from Freedom, can never be restored. Liberty, once lost, is lost forever. (John Adams)
http://jmsconst.110mb.com
j.m.s. is offline
Stair Jig RISENRUN Tools & Equipment 7 02-08-2010 08:30 PM
determining exact tangent point for stair fittings troubleseeker Finish Carpentry 3 04-19-2007 08:05 AM
1/4" stair nose stangit92 Flooring 3 01-14-2007 08:09 AM
hello from virginia stair guy bosco1970 Introductions 3 07-04-2006 09:25 PM
5% to the Interior Designer? sage Construction 9 01-13-2006 08:10 PM
