#21 |
Repair/Remodeling Tech.
Trade: Repair and Remodeling Services
Re: Spindle Spacing
Wouldn't be too hard to make a calculator in excel to do this for you. Of course to use it on the job you'd have to have a laptop, or someone at home to call. Maybe I'll see what I can come up with.
BTW, before I start, do we all agree that 4" is the magical number? I'm not a deck man by trade, all I know is what I (think) I've read. Or I suppose it could be made to look at a certain cell that would have the maximum by code in the user's area.(user input)...hmmmmmmm Last edited by jproffer; 07-26-2005 at 12:38 AM. |
#22 |
Trade: Renovations
Re: Spindle Spacing
Here in Canada the magic number is 100mm which translates to 3.94 inches and I seem to recall, from the time when the code was written in the units that we all actually use, it used to be 3-15/16". The wording is that a sphere of that size may not pass through, so it actually has to be smaller of course. Rich.
#23 |
Re: Spindle Spacing
OK, if I can get the attachment to work, here's a first draft. You can input the total space allowed and use any units you like, as long as you keep the units the same throughout obviously. There are comments that should answer and questions, but remember this is just a first draft with limited testing. Comments? Problems? 2nd Draft is awaiting you deck pros
OK, now that I've figured out how to zip the thing, here goes again. Last edited by jproffer; 07-27-2005 at 08:04 PM. |
#24 |
Re: Spindle Spacing
BTW, does anyone know of a zip utility that's not winzip, it's only free for 21 days and seems kinda handy, but not handy enough to pay for
#25 |
Re: Spindle Spacing
UPDATED ATTACHMENT:
Found out today it had a slight flaw in the calculations, where it could give a decimal for the number of spindles...lol. OOOPS, it's corrected now though, let me know how, and if, it works. Last edited by jproffer; 07-27-2005 at 08:04 PM. |
#26 |
Trade: Work
Re: Spindle Spacing
heres the crazy formula...probably not intended for outside decks, but could work.....got it from another guy from another forum...
#27 |
Trade: Work
Re: Spindle Spacing
And here is the dumbed down version...FOR EXAMPLE:
Distance between posts 4'3'' Width of baluster 1½" Width of Preferred spacing 3½" 4'3" - 3½"(width of preferred spacing) = 3'11½" 1½" (width of baluster) + 3½" (width of preferred spacing) = 5" 3'11½" ÷ 5 = 9½ increase to whole number 10 1½" x 10 = 1"3" 4'3" - 1'3" = 3' 3' ÷ 11 (total number of spacings) = 3 11/64" 10 balusters and 11 equal spacings of 3 11/64". Set your dividers to 4 43/64" *Courtesy of DBC (my last two posts) My thoughts...seems workable, but my tape doesnt read in 64ths...haha. Later Gents. |
#28 |
Re: Spindle Spacing
OK, here's the third revision, based on the method described by old 27, thanks old
Jim P. Last edited by jproffer; 07-27-2005 at 08:09 PM. |
#29 |
Trade: builder remodelor
Re: Spindle Spacing
For 1 1/2" spindles i layout on 5 inch centers giving a 3 1/2 inch center space. Laying this out on a furring strip makes it easy to transfer the layout to your railings,also makes it easy to see how end spaces will work out .
#30 |
Re: Spindle Spacing
Laying out on 5" centers is ok as long as that happens to work out evenly at the ends, which you said
Jim P. |
#31 | |
Re: Spindle SpacingQuote:
Keep the 'old-timer' remarks comin', - - we wear them like a badge. Oh, yeah, - - and the 'dinosaur' accusations. Did I remember (what with my 'alzheimers' and all) to mention that T R Construction stands for T. Rex?? Did you go to college?? Is that where you aquired your B.S.??
http://www.tr-built.com |
#32 |
Re: Spindle Spacing
With the layout stick method its easy to determine if a center space or center baluster works best, i find keeping the o.c.spacing the same greatly simplfys the layout process and keeping the end spaces the same is not realy necessary.I usally go with a smaller end space.
#33 |
Re: Spindle Spacing
Makes a lot of sense, Berg.
#34 |
Trade: carpenter
Re: Spindle Spacing
wow lot of replies.heres how i do it. consider your code no more than 4" in my area.
i estimate how many in the run add their widths subtract that from the run then divide that bythe spaces and you have the open space between.for example 52" lets say 10 balusters thats 15 subtract from 52 = 37 divided 11 =3.36 |
#35 |
Trade: general contractor - SFR
Re: Spindle Spacing
Here's a simple way to space your spindles with little math. Use a small piece of 2x4 to space between spindles at 3.5". When you get to the end with about 2 or 3 to go, just divvy it up equally with the remaining distance. No one will ever notice the difference so long as you're still under 4". You can also use the 2x4 on the other side (top or bottom), just be sure to check yourself occasionally for plumb. For simple decks, I add a nail to the 2x4 scrap to hang it on the bottom rail.
#36 |
Re: Spindle Spacing
I think you mean MAYBE an UNTRAINED eye wouldn't notice it.
Personally, - - I'd pick that out right away. From any distance. Without looking for it.
#37 | |
Deck Designer/Builder
Also, what do you do for the other sections? Repeat your random spacing method? For me, the importance of using a consistant spacer block is that not all sections of railing are exactly the same on the entire deck. So, having all balusters/spindles spaced the same is important for the over all finished look of the deck. |
#38 | |
I completely agree, - - and in actuality, - - with a little fore-thought, - - the design/location/distance of the posts can be spaced in 'multiples' of desired spindle-spacing just by 'dimensioning' the overall deck-size an inch or two either way. Any very-slight variation will still be at the ends.
#39 |
Re: Spindle Spacing
Just like to metion that alot of the newer composite railing systems utilize a pre-bored rail or spacer , so altering baluster spaceing is not realy an option.This goes back to the odd even or center space, center baluster method .
#40 |
Re: Spindle Spacing
True, - - but the post-location layout, - - before the actual physical work even starts, - - can still pre-determine a perfectly symmetrical look.
Better planning = less remedy/concessions.
http://www.tr-built.com Last edited by Tom R; 08-20-2005 at 12:05 PM. |
| Metal stud spacing? | CM Mann | Commercial Construction | 17 | 09-19-2007 01:58 AM |
| purlin spacing for metal roofing | 72chevy4x4 | Construction | 1 | 01-30-2007 06:20 PM |
| Truss spacing | ryan80 | Roofing | 2 | 10-20-2006 09:42 PM |
| Nail Spacing | mms | Finish Carpentry | 6 | 04-28-2006 09:14 AM |
| Spacing for rails on deck. codes | keithguts | Decks & Fencing | 22 | 01-25-2006 09:49 PM |
