Special Vix Drill
hey guys i was wondering if any of you ever heard of a vix drill that actually drills all 4 hinge holes for a hardwood door at one time. The company i work for heard about it and has been trying to find it for a while because we are going to put in a few hundred hardwood doors. I believe they said it was a special drill that did it or just a special bit. All help is appreciated.
Carpenter
Re: Special Vix Drill
The vix drill bits simply center the hole for hinge installation. They cost about $10-$15 each. Try this http://www.woodcraft.com/family.aspx?FamilyID=2022.
#3 | |
Insert title
Trade: Doors-Windows-Decks
Re: Special Vix DrillQuote:
California Proposition 65 Attention California Residents: California's Proposition 65 entitles California consumers to special warnings for products that contain chemicals known to the state of California to cause cancer and birth defects or other reproductive harm if those products expose consumers to such chemicals above certain threshold levels. We care about our customers' safety and hope that the information below helps with your buying decisions. The general Proposition 65 notice is as follows: WARNING: This product contains chemicals known to the State of California to cause cancer and birth defects or other reproductive harm. In addition, there are specific warnings for the following specific products: Tools Electrical Cords Buffing Compounds & Finishing Products
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
Did a little searching and found nothing about vix gang drills.
Trade: Remodeling / Carpentry
Neither did I.
Search "prehung door machines" on the internet. A lot of companies come up that sell equip for building door units. Most of the equip is higher dollar but there were also some that had air operated hand tools that feed screws for hinges and work tables that stand up, rotate etc to gain production time among other items. Just looking at the pictures you may be able to get some pointers to save time. A lot of these items are most likely $500-$2000. |
I've seen some gang drill presses, but never heard anything about a gang vix bit. I'm wondering how it would figure different placements. I would suppose that it would be....adjustable.
Cancer? Everything causes cancer in CA.
Go to a local lumber yard or two that has a door shop. Watch how they do it and ask the lead guy some questions.
The last one I saw was fairly simple I recall. Just a few air operated slides, routers, feeder table. The guy threw about 2-3 levers and screwed the hinges with an air driver trying to keep up with the machine. He may have had a hand held center punch device to align over the hinge holes but I'm not sure. At this point I'd call the hinge mfg's tech folks or regional sales reps. They go around to all the shops and see how it's done. Stanley, Baldwin, theres one other ? |
#8 | |
The Deck Guy
Is that the same operation that sets the mortises too deep or shallow, drills the holes off center, and puts the hinge screws in crooked? If it is, then my local distributor (Reeb) must have the same machine.
That's exactly what I was thinking!
Professional
Trade: Finish Carpentry
Does it really take that much longer to drill four holes with one self-centering/Vix bit?
#11 | |
Mod / ArchiBuilder
Maybe seconds, nothing more.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Trade: Finish Carpentry,Doors,Windows
cstools dot com has just what your looking for. This one shop I worked for had one. They would have the shop rat pre drill doors while still on the pallet!
Trade: carpentry
I found it under amazon tools norfield industries. over $300
#14 | |
Al Smith
holy ganole. You too? I just hung a door Thursday and couldn't figure out why it was hinge sprung. (push the door closed w/no hardware it pops open slightly) No jamb contact with door and no jamb stop binding. jamb square to the the wall face with equivalent sliding shims in both directions. then I noticed the top and bottom hinge leafs were angled out of the door hinge mortise. Yup REEB . guess one out of three hinge mortises are not bad. |
Carpenter/fencing
Yea if doors get any worse(if its posible),i'm just going to do all the mortising myself.You would think it takes longer but with all the time you spend making the ****z doors work it will end up being faster. Not to mention i've even had some doors delaminate from the garbarge wood and cardboard structure. Raised panel masonite doors also around humidity,not good.Not too long ago i've refurbish some old raised panel doug fir doors,what a pleasure to work on a real door (about 40-50 years old).Joints still tighter than a bulls azz.
Learning without thought is labor lost; thought without learning is perilous. |
| Witch Drill Is better? | Morry | Tools & Equipment | 16 | 08-09-2007 04:14 AM |
| Dewalt 36V Drill Too much torque? | GregS | Tools & Equipment | 11 | 05-07-2007 03:47 PM |
| dewalt drill broken?? | fast pasquale | Tools & Equipment | 5 | 03-30-2007 04:13 PM |
| Looking to buy new home, special foundation..?etc | Knyte260 | General Discussion | 7 | 11-21-2006 12:56 AM |
| milwaukee hole hawg or ridgid r7130 drill?? | ko_jun | Electrical | 10 | 07-28-2006 11:54 AM |
