Trade: hardwood railings
Spacing Different Sized Spindles
I have a railing job that uses a combination of wood and metal spindles. The spindle size is different, 1.5" for the wood and 0.5" for the metal ones. Is there an easy way of figuring out how to make the spaces between the spindles uniform, or is it all trial and error. Any help would be great, thanx.
Re: Spacing Different Sized Spindles
Spacing between centerlines of spindles would be your desired spacing between spindles plus 1 inch. Example- 2" spacing between spindles would mean 3" between spindle centerlines.
Very quick and rough sketch with accurate spacing. Last edited by Dustball; 09-21-2007 at 08:39 PM. |
Trade: Squirrel Handler
Depending how big the spacing is going to be, if you are trying to get it to code using the minimum, take one of each size (or 3 or 4 etc. if it's a pattern) and measure them as one unit and use the "unit" to figure out how many you need and the spacing.
Some people climb mountains. I take out the trash. But we both do it for the same reason. Last edited by mickeyco; 09-21-2007 at 08:51 PM. |
#4 | |
Carpenter/fencing
Re: Spacing Different Sized SpindlesQuote:
3/4" + 1/4" + 4" = 5" centers
Learning without thought is labor lost; thought without learning is perilous. Last edited by nywoodwizard; 09-21-2007 at 09:09 PM. |
thanx for all the help, I think I'll study it up some more with some books. Thanks.
Trade: Carpentry/ Framing
To evenly distribute space in a given section use the following:
Take total amount of space in section (ex: 4' section) Subtract amount of space used up by the railing material (5 @ 1.5 + 5@ .5= 10") Divide by the number of spaces (10 spindles leaves 11 spaces) 4'-10" / 11 = 3 7/16" space |
| Metal stud spacing? | CM Mann | Commercial Construction | 17 | 09-19-2007 01:58 AM |
| How do you know when a central area unit is sized right? | SuperiorBuilt | HVAC | 30 | 09-13-2007 05:48 PM |
| purlin spacing for metal roofing | 72chevy4x4 | Construction | 1 | 01-30-2007 06:20 PM |
| Truss spacing | ryan80 | Roofing | 2 | 10-20-2006 09:42 PM |
| Nail Spacing | mms | Finish Carpentry | 6 | 04-28-2006 09:14 AM |
