Sistering Joists
Old 01-29-2011, 08:00 AM   #1
jimmyb21's Avatar
Trade: Plumbing & remodeling
Sistering Joists
Mornin', My house is built using 2 x 8 joists with an approximate span of 12 1/2 feet spaced 16" oc. This is fine but there seems to be a lot of deflection, when I walk around on the 1st floor, I can hear things rattle. I was thinking about sistering maybe every other joist but I won't be able to sister the entire length. My question is, Do you guys think this would do anything or be worth the effort? Thanks in advance for helping out a dumb plumber
jimmyb21 is offline
Old 01-29-2011, 09:32 AM   #2
General Contractor
greg24k's Avatar
Rewards Points: 7,256
Re: Sistering Joists
What are you better at...being dumb or being a plumber?
Read what you wrote again...you already answered your own question
greg24k is offline
ScipioAfricanus (01-29-2011)
Old 01-29-2011, 09:45 AM   #3
jimmyb21's Avatar
You know the old saying, aint nothin dumber than a plumber but for the record, I'm a better at being a plumber I know that adding anything to the joists in theory would stiffen them, but I wasn't sure if it would do enough to be worth it (money & especially time wise) Thanks Greg
jimmyb21 is offline
Old 01-29-2011, 04:54 PM   #4
3bar's Avatar
Trade: carpenter
Rewards Points: 460
sister 2x10's next to your joists, and notch the ends if you're going over a beam or plate. add bridging blocks if you dont have any.
or run a beam and posts down the middle of the span.
3bar is offline
The Following 2 Users Say Thank You to 3bar For This Useful Post:
aptpupil (01-31-2011), SAW.co (01-29-2011)
Old 01-29-2011, 09:02 PM   #5
robert c1's Avatar
Trade: remodeler/gc
Rewards Points: 288
Based on the information provided I can tell you with absolute surety that yes you should sister every other joist part way. It will be well worth the effort.
GIGO
robert c1 is offline
Old 01-29-2011, 09:29 PM   #6
WOOLBRIGHT'S CARPENTRY
carpenter87's Avatar
Trade: Framing,siding ,gutters, interior trim,
I agree there robert c1
carpenter87 is offline
Old 01-29-2011, 10:10 PM   #7
TRADE CRAFTSMAN.
SAW.co's Avatar
Trade: general contractor
Agreed post & beam is your best option.
SAW.co is offline
Old 01-29-2011, 10:29 PM   #8
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 1,044
Yup, the specs. you provided on the floor joist span is right at the limit for #2 DF 16" O.C. x 8".
You could try solid 2 x 8 blocking at 48" intervals, this would spread the weight distribution to other joists.
Or just sister on some 8s. from about 6" short of both sides, (don't have to go on top of plates), then 16d nails two of 12" O.C.
Or a girder underneath spanning across the joists.
Lots of options.
Andy.
ScipioAfricanus is online now
Old 01-30-2011, 09:13 AM   #9
jimmyb21's Avatar
Thanks everyone, yep, it is right at the limit. Everything in this house was built to minimum code. Some stuff below minimum lol.
When I remodeled the kitchen, I discovered the stack for my master bath had only siding on top of it. In order for them to fit the 3" line in a 2 x 4 wall, they had to stuff it in there & cut the sheathing away, no insulation.
Also, to support the water lines for both upstairs baths they just added some nails to the joists, driven in at a 45, kind of like a cradle, & just laid the pipe on top, m copper none the lest...
Makes me run through a bunch of emotions everytime I have to open a wall
Thanks again, time to go get wood
Jimmy
jimmyb21 is offline
Old 01-30-2011, 09:26 AM   #10
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,342
I would rip some 3/4" plywood and sister both sides with that.
-Dennis
WarriorWithWood is offline
Old 01-30-2011, 09:45 AM   #11
Level 27 Contractor
Bastien1337's Avatar
Trade: Renovation
My thoughts as well, plywood in rips along both sides screw and glue will help with deflection alot, it will give some strength but it is mainly there for the deflection.
Because the veneers of the plywood cross they have more compression and tension strength. Just look at the engineered wood I joist.
doing this should help alot
Sebastian
Check out my gallery here http://on.fb.me/I2XylV
Check out my blog here http://sebastianbethke1337.wordpress.com/
Bastien1337 is offline
Old 01-30-2011, 10:29 AM   #12
Willy is's Avatar
Trade: residential restoration
Rewards Points: 250
The floors very possibly have some sag in them. If you first remove some of the sag with a temporary beam and posts, and THEN install the 3/4 plywood (possibly w/ construction adhesive) you'll have an even better repair.
If a person was laminating the joists this way would it make sense to stagger the laps?
Willy
Willy is is offline
Old 01-30-2011, 12:02 PM   #13
Level 27 Contractor
Trade: Renovation
Willy
from opposing sides of the joist I would say absolutely, helping the joists not to "break" in those areas. always stagger, it will always help, even if minimally.
Sebastian
Old 01-30-2011, 12:23 PM   #14
Willy is's Avatar
Rewards Points: 250
I agree, but I posed it as a question since in doing so one side might be composed of 2 strips of Plywood and the opposing side would have 3.......an extra joint, but to my thinking it would lack that stress riser.
It also seemed to me that if the surface connecting to the floor was glued it may quiet the floor. The ends where plywood ends abutt may as well also be tight and glued.
My question would be what type of fastener would be best to use and what frequency?
I think I would clamp and hammer things tight, then staple to hold and then follow with something like an 8 or 10 sinker. I'm thinking that if glue was used all you would want would be to connect the ply to the joist on each side. IF you used a 16 penny through all pieces wouldn't it tend to drive the opposing sheet away from the joist?
As other people mentioned a beam across the center would work well, but in a low ceiling it could be a problem.
Willy
Edit; before you decide what to do run a string line across your floor and measure the amount of sag you presently have.
Last edited by Willy is; 01-30-2011 at 12:29 PM. Reason: new additional thought, not worth a post
Willy is is offline
Old 01-30-2011, 12:25 PM   #15
Valuster's Avatar
Trade: carpentry
solid staggered crossbridging would help if none exists.
in addition, you could possibly run a 2x6 strongback perpindicular (fastened with structural screws).
Valuster is offline
Old 01-30-2011, 12:31 PM   #16
Level 27 Contractor
Trade: Renovation
Willy
I personally would use 1 1/2" - 2" screws on 3/4" ply. It wouldnt come through the other side. Tied in with glue it would suck it flat and I would use a nailing schedule similar to regular doubling. (2x8: 4 screws ever 12-16")
I dont think the number of joints matters so much as long as you span as long as you can between them. Realistically in a 12' run, 2 8' pieces spaced dead center on opposing sides of the joist would take the bulk of the deflection out. You probably wouldnt need to hit that last 2' sections near the ends of the joist because that is not where its greatest deflection occurs anyways.
Sebastian
Old 01-30-2011, 12:34 PM   #17
Level 27 Contractor
Trade: Renovation
In terms of the joist sag, there might not be much you can, if there are tiles on the floor above or cabinets, it could throw those out of wack, you might have to just strengthen them in place.
Sebastian
Old 01-30-2011, 12:40 PM   #18
Willy is's Avatar
Rewards Points: 250
Good thoughts and advice.
I've seen some good sags in floors and just thought I would bring up that the amount of sag could determine the method of repair.
Willy
Willy is is offline
Old 01-30-2011, 08:37 PM   #19
TRADE CRAFTSMAN.
SAW.co's Avatar
Agreed, A vary good idea. Fast, cheap & would work vary well.
SAW.co is offline
Old 01-31-2011, 03:17 AM   #20
3bar's Avatar
Trade: carpenter
Rewards Points: 460
plywood ripped at 7 1/4" is not going to provide much strength.
better off to double up the joists, even better with 2x10's if possible.
3bar is offline
Sistering Sagging Floor Joists.... AllGoNoShow Construction 22 02-25-2011 03:37 PM
Joists Replacement While Maintaining Fire Escape Access? Lovegasoline General Discussion 17 11-19-2010 01:06 PM
sistering joists... how to seal the top edge. s. donato Decks & Fencing 6 01-26-2009 08:21 AM
Replacing joists in rowhouse Philly Dude Framing 3 10-16-2008 05:24 PM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 05:52 AM
