Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry
Old 07-30-2009, 07:14 PM   #1
Think it Draw it Build it
wallmaxx's Avatar
Trade: WA STATE GC Specialized in Structural Framing
SIPS - design / frame help request
I am trying to take a sketch of a future ICF + SIPS home for a builder up here and design plans for him.
SIPS is new for me. I have been scouring the net for typ. sections and the like. I will number my questions for easier and ordered responses...I do that because at WallMaxx...we care
1. Anyone have any good links they might share?
I will be documenting this into a "beginner's how-to" tutorial. (We used to call them SOPs back in the day)
I am seeing some pictures that show it will have a typical framed or truss roof under it.
2. So these panels are not self supporting?
3. If I design a sufficient roof system for our snow load requirements up here, does SIPS just lay on top of that? (Starting to get into the engineer's business - I know?) I just need to get as accurate a drawing produced before this goes in for engineering. I try to not participate in the garbage in garbage out philosophy.
4. My preference would be to frame the roof with built-up timbers 4' o.c. so that most of the ceilings could be exposed, sloped wood or something nice.
Comments - suggestions? PS, I have the stair tutorial almost converted from PC - powerpoint
to
MAC - Keynote and as a quicktime video
...once I get a good narration track recorded - look out.
WallMaxx, Inc.
Think it. Draw it. Build it.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars..
>>>>>libertas<<<<<
wallmaxx is offline   Reply With Quote
Old 07-30-2009, 07:31 PM   #2
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
I did a house that had SIPS on the walls. You must be talking about the roof.
The one I did had a conventional truss roof.
knucklehead is offline   Reply With Quote
Old 07-30-2009, 07:38 PM   #3
wallmaxx's Avatar
Whoops - sorry for not explaining. ICF walls - SIPS roof.
WallMaxx, Inc.
>>>>>libertas<<<<<
Old 07-30-2009, 07:45 PM   #4
tomstruble's Avatar
Trade: siding
ive done them on a timber peg and yes they are self supporting ,not sure of the span the sip company can help you with that
we use these i belive
http://www.winterpanel.com/
tomstruble is offline   Reply With Quote
The Following User Says Thank You to tomstruble For This Useful Post:
wallmaxx (07-30-2009)
Old 07-30-2009, 07:58 PM   #5
Who are you getting the panels from?
Get a hold of the guys at Premier Building Systems in Fife, WA.
Also look at their website and their technical library where they have details downloadable in PDF and DWG formats.
http://www.pbssips.com/
And yes they can be self supporting, just depends on the span and complexity.
Kgmz is offline   Reply With Quote
The Following User Says Thank You to Kgmz For This Useful Post:
Old 07-30-2009, 08:00 PM   #6
tomstruble's Avatar
Trade: siding
the winter panels up to 8'
Old 07-30-2009, 08:08 PM   #7
Trade: Green Products, Energy Auditing and Services
Are you trying to get a builder to design a roof using SIPs? The better solution is to find a SIPs manufacturer that you want to work with and have them design it to fit your walls. They have the software and the experience and most will do it for free. If you need a panel company I am sure you will get plenty of suggestions here or go to the SIPs association and check their directory www.sips.org (if the url doesn't show go to sips dot org. Personally we use Extreme
dhall is offline   Reply With Quote
The Following User Says Thank You to dhall For This Useful Post:
Old 07-30-2009, 08:10 PM   #8
wallmaxx's Avatar
THANK YOU!!
THANK YOU!!
THANK YOU!!
That is the best link so far. They even supply .dwg files.
I will keep a running documentary of this process for anyone who might care.
Thanks again.
WallMaxx, Inc.
>>>>>libertas<<<<<
Old 07-30-2009, 08:15 PM   #9
wallmaxx's Avatar
Yes...they will design it. I have been tasked with getting the permit level prints drawn. Since I am step one, I want them to be as complete as possible. I would never assume the liability of designing this. It would be like me drawing out trusses.
If I can get the right data, however, I will propose a stick built roof system underneath the SIPS that I will design within the parameters of the rafter tables in the 2006 IBC / IRC. So far, I am still allowed to go that far.
Man...this is what I love about this site. Y'all helpin a brother out.
Thanks again.
WallMaxx, Inc.
>>>>>libertas<<<<<
Old 07-30-2009, 08:16 PM   #10
These guys even have roof panels made with I-joists that can span 20' to 24'. Also standard dimensional lumber roof panels that will span up to 20'.
Old 07-30-2009, 08:27 PM   #11
wallmaxx's Avatar
Awesome!
WallMaxx, Inc.
>>>>>libertas<<<<<
Old 07-30-2009, 11:02 PM   #12
Never lost a battle.
ScipioAfricanus's Avatar
Trade: General contractor, designer, drafter.
You might try this place, http://www.enercept.com/enercept_sip...truction_guide
Lots of good info but I see that you have lots of good info already.
Andy.
www.draftinginoc.com
ScipioAfricanus is offline   Reply With Quote
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
wallmaxx (07-31-2009)
Old 07-30-2009, 11:26 PM   #13
My bad - we use Enercept not extreme. They take care of everything for us. When I started doing sips I just ordered the panels and did it all myself which is a great way to learn how to do them but now that I know everything LOL I go with the most important thing I learned. Let them draw it and cut the panels.
As far as doing a stick frame under the roof panels I know people that do that which is fine but I figure why spend the time and money when I all I have to do is swing a beam in place and set the panels. Plus my customers like being able to have an open ceiling if they want it.
I will say this though, the panels are pretty simple to work with but it makes a big difference to have the right tools. I started out cutting both sides of the panel and then running a sawzall through the foam but now I have the saws to cut it all in one pass. Which I seldom have to use because I have them cut. You will need a foam cutter though for the thickness of the panel you are using for cutting out space for splines etc as there is always something that needs to be adjusted. And you will want to get a foam gun and tank to do your joints. And most important is get some good lifting hooks if you are doing roof panels. I made my own and I keep thinking about manufacturing them but I am sure your panel supplier will either have them or can tell you where to get them. We keep talking about setting up a supply business for sips tools and equipment, maybe next year.
If you have any questions you need answers on you can call or email me and I will be happy to help. I will see if my info is in the profile. If not just say something and I will get them to you.
Face frame hinging basics Gus Dering Finish Carpentry 5 04-07-2009 07:38 PM
Pre hung exterior door composite frame rayh78 Carpentry 6 01-27-2009 04:14 PM
Design Presentation - Going to Virtual fakie99 Marketing & Sales 6 01-22-2009 08:21 AM
Home Design Software - i.e. Punch Home & Landscape Design Panzer5 Technology 19 12-29-2008 11:09 PM
Free Download: Advanced Energy Design Guide Ed the Roofer Roofing 0 02-09-2008 09:01 PM
