Siding To Brick Wainscoting - Carpentry - Contractor Talk
Old 09-29-2017, 09:49 PM   #1
P.R.O. Fessional
Chipfo's Avatar
Rewards Points: 200
I see it fairly often on a brick wainscoting where the siding is sitting on a piece of wood cut at an angle, or a water table and the flashing is under the wood water table. Should there also be, or instead of, flashing behind the siding on top of the water table? Or just no water table at all?
**Edited to add - It may have to have the wood water table if the siding isn't thick enough to reach the brick.**
Any case, I may be replacing the rotted wood and siding in such a scenario, thing is he probably wants to replace just the bad stuff and not all of it.
Below is a picture of one of the worst spots, first thing I will do is cut out all of Einstein's work. But in a case where all of it had to be replaced, how would you do it?
How would you do it if just sections needed replacing? (which will probably be the case here)
I've cut this board three times and it's still too short!
Chipfo is offline
Old 09-29-2017, 10:00 PM   #2
Renaissance Man
superseal's Avatar
Rewards Points: 5,634
Re: Siding To Brick Wainscoting
The brick veneer would need base through wall flashing/weeps as well below the brick sill. Anything on top of that gets flashed over the sill. I wouldn't butt the siding tight...leave an airspace/capillary break to thwart off rot.
supersealconstruction.com
superseal is online now
The Following 2 Users Say Thank You to superseal For This Useful Post:
Chipfo (09-30-2017), Tom Struble (09-29-2017)
Old 09-30-2017, 11:59 AM   #3
P.R.O. Fessional
Chipfo's Avatar
Rewards Points: 200
Ideally yes, but that brick was put up in the 40's and I am not going to take off 2 or 3 rows of brick to flash it. I believe I will do something like my drawing below unless anyone has a better idea.
Chipfo is offline
Old 09-30-2017, 02:27 PM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
there is a pvc water table you can use there,with the vertical panel you show you would need to rip off the vertical leg
Siding to brick wainscoting-0707161033.jpg   Siding to brick wainscoting-0710161837.jpg
Tom Struble is offline
Old 09-30-2017, 03:03 PM   #5
Renaissance Man
superseal's Avatar
Sorry, I thought you meant from scratch...your retrofit looks fine.
The Following User Says Thank You to superseal For This Useful Post:
Chipfo (09-30-2017)
Old 09-30-2017, 07:31 PM   #6
P.R.O. Fessional
Chipfo's Avatar
Rewards Points: 200
I kind of figured Thanks for looking at my diagram.
Cool, thanks. I will try to talk him into doing it all, it is a garage/shop. Even the stuff that isn't rotted yet is probably well on the way with that silicone sealing the wood to brick holding water in (Hence "Einstein" in my first picture lol)
Chipfo is offline
The Following User Says Thank You to Chipfo For This Useful Post:
Tom Struble (10-01-2017)
Chicago Cut Brick Veneer Installation sokoleoko Masonry Picture Post 6 05-28-2015 02:50 AM
Adding a keystone to brick arches post-construction marphtwo Masonry 24 04-15-2013 06:04 AM
Vinyl siding/ stain saga SwiftRes Windows, Siding and Doors 5 10-01-2012 09:26 PM
something for the masonry department dakzaag Masonry 2 05-08-2009 09:23 PM
Adding a Brick Ledge to a Michigan Home bajafx4 Masonry 3 01-23-2009 07:19 PM
