Screwing Down Deck Boards
Old 02-26-2006, 10:06 AM   #1
General Contractor
JPV123's Avatar
Trade: Class "A" Contractor with "BLD" Classification
I know the pros and cons of screwing vs nailing down decking. But would you say a "Higher End" deck/screened porch that is on a more expensive custom built home should be screwed down and not nailed down? We are replacing decking and building a screen porch. The decking that we are replacing is nailed down. I'm thinking I should screw down the new decking to make it a nicer job. Thanks
JPV123 is offline
Old 02-26-2006, 10:44 AM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Screwing Down Deck Boards
I would think any decking should be screwed down.
Mike Finley is offline
Old 02-26-2006, 11:41 AM   #3
General Contractor
JPV123's Avatar
Would you leave a gap using pressure treated lumber. I find the lumber shrinks so in a few months a natural gap will appear. I've seen newly installed pressure treated decks with gaps and 6months to a year later they have huge spaces between them.
JPV123 is offline
Old 02-26-2006, 12:08 PM   #4
slowsol's Avatar
Trade: General Contracting
I always screw down and usually butt the lumber right next to the eachother. Like you said, the lumber will dry and their will be an 1/8'' gap between every plank. The only exception is if I get PT that is really dry (rarely to never) or I am using composite.
slowsol is offline
Old 02-26-2006, 01:10 PM   #5
Steve Unkie's Avatar
Trade: REMODELING CONTRACTOR
I always use screws and do leave a gap between boards. The gap is determined by: how wet my decking is, is it the wet time of year or the dry season,
gap it so that it may be a tight 1/8 in winter to 3/8 in summer.
That's what I do anyway.
Steve Unkie.
Steve Unkie is offline
Old 02-26-2006, 04:25 PM   #6
Custom Builder
Glasshousebltr's Avatar
Screw....Gap.......Uh....rutt row, did I type a boo boo.
Bob
Bob
Glasshousebltr is offline
Old 02-26-2006, 06:38 PM   #7
Joe Carola's Avatar
Trade: Framing Contractor
I'm just curious as to why since you think it's a better job, why not screw a deck down on any job high end or low end? Your job should be nice no matter what the cost of the house you are working at is.
Joe Carola
Joe Carola is offline
Old 02-26-2006, 07:00 PM   #8
Deck Designer/Builder
DecksEtc's Avatar
Screw down - always.
Leave gaps - I always put the boards tight to each other - I've never gotten PT or cedar dry enough from the lumber yard to have to leave gaps.
DecksEtc is offline
Old 02-26-2006, 07:06 PM   #9
specwood's Avatar
I agree with the general consensus here.
Screw the deck. The expansion and contraction of deck boards will inevitably loosen any nails over time making for a squeaky deck.
Keep the deck boards tight on installation for wood decks. They will dry and then you will have all the gap you need.
specwood is offline
Old 02-26-2006, 07:23 PM   #10
RobertCDF's Avatar
Trade: Custom deck builder
PT tight as can be (bowrench) and screw every deck no matter what never use nails for the decking surface.
RobertCDF is online now
Old 02-26-2006, 07:28 PM   #11
General Contractor
JPV123's Avatar
The reason I think it's a better job is because I see a lot of "builder" decks that are nailed down, spaced way to wide and not cupped correctly. I sell the fact that I build a better deck than these builder decks. I always screw down my decking with no gap when using pressure treated lumber. The reason I'm asking is a customer wanted us to "match" an existing part which was nailed down. The spacing question was something my partner had questioned me on and I just wanted to get other opinions on it.
JPV123 is offline
Old 02-26-2006, 09:14 PM   #12
General Contractor
nadonailer's Avatar
Always screw, and butt the boards...
"History does not long entrust the care of freedom to the weak or the timid”.
Dwight D. Eisenhower
nadonailer is offline
Old 02-26-2006, 10:56 PM   #13
Finish Carpenter
Bukemdano's Avatar
Trade: Finish carpentry
A lot of framing contractors around here (MI) just include the deck in the framing package and just slap the deck boards on with nails. I cut the framer out and build the decks myself. Agree with the everyone else. If it is (PT) there is no gap.
Bukemdano is offline
Old 02-27-2006, 01:06 AM   #14
Custom Builder
He said screw and butt.
Bob
Bob
Old 02-27-2006, 01:30 AM   #15
So no-one else leaves any gap between pt boards. I'm in Wa. state where it rains all winter, seems to me that if I buy my lumber from an inside lumber yard in the summer, and install it with no gap,then when the rainy season comes and the decking expands, there will be no gap=no drainage and possible buckling.
I think I'll continue to leave some gap, but now I will pay attention to see if what you guys say is so for my part of the country.
Steve Unkie.
Old 02-27-2006, 08:27 AM   #16
Rambone's Avatar
Trade: Home Improvement Contractor
If you looking for a premo job use the under the board fastening system I use it on high end decks you will see no screw holes at all every thing it done from under the deck as you build.
Rambone is offline
Old 02-27-2006, 09:32 AM   #17
Woodcrafter74's Avatar
Originally Posted by Rambone
...use the under the board fastening system...
THE under-the-board fastening system? There's a lot of them, which do you use?
Woodcrafter74 is offline
Old 02-27-2006, 09:32 AM   #18
IHI's Avatar
Tore out too many decks when I was younger than were nailed to ever think about doing that on my own stuff...not possible to have a long term deck with minimal maintenance.
I've only build one wood deck using the gap method and that was because I finally tired of arguing over it with the homeowner so we did it his way. I was back a few years later for another aspect and looked at the deck and laughed...what started being spaced with a 16d nail between planks turned into 3/8"-1/2" gaps between boards and some large enough to stick your fingers upto your knuckles.
IHI is offline
Old 02-27-2006, 09:43 AM   #19
Rambone's Avatar
The ones my supplier carriers are TIGER CLAW AND DECK MASTER!!
I use them mainly on TREX but they can be used on any material.
Rambone is offline
Old 02-27-2006, 10:05 AM   #20
Okay, I'm hijacking this thread somewhat, but I think JPV got his question answered about whether to screw or not to screw.
Rambone,
Have you ever had any problems with either or those fastening systems. I haven't tried the Tiger Claw on composites, but I'm thinking that mashing large prongs into the side of a composite board just isn't right???
And on the Deck Master system, I talked with a rep recently and asked him how much of an increase in installation labor they estimate their system causes--since it's all underneath. He said $3 sq/ft. I just laughed, I don't see that product being worth that type of labor increase.
What's your experience been?
Correect Deck ?'s Robert and others IHI Decks & Fencing 9 05-21-2008 10:45 PM
How to cut off deck boards jeclarke Decks & Fencing 5 07-09-2007 03:34 PM
Remove Deck Boards Tool Joe Wood Decks & Fencing 6 06-24-2007 11:55 AM
Cedar Deck Prep Problems Larman Painting & Finish Work 2 05-04-2007 05:31 PM
