SC Railing Height Code?
Old 07-27-2010, 03:09 PM   #1
turboimpala's Avatar
The railing for the stairs in my house is too high and is not parallel to the steps (ranges from 38" - 41" from nose of tread).
Does anyone know the South Carolina building code for handrail height in stairwells?
Thanks!
turboimpala is offline
Old 07-27-2010, 03:29 PM   #2
LEVELBEST's Avatar
Trade: Contractor, Trim Dude, and Custom Cabinet Maker
Rewards Points: 250
Re: SC Railing Height Code?
Lay a level across several treads, on the slope, and it should, by code, be anywhere from 30-38 inches from the BOTTOM of that level(the front of the tread) plumbed to the TOP of the handrail. I set mine at 34".
Level Best, LLC(Custom Cabinets and Wood Products). Level Best Home Builders, LLC(Custom Homes and Remodeling).
LEVELBEST is offline
Old 07-27-2010, 03:32 PM   #3
That's exactly how I measured it so I'll lower it to 34".
Thanks dude!
Old 08-01-2010, 10:41 AM   #4
woodman53's Avatar
Trade: building contractor
S.C. code is 36 for stairs and 42 in. for balconies no less than 36 in. in stairs or it will not pass
woodman53 is offline
Old 08-01-2010, 12:14 PM   #5
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Rewards Points: 1,000
California code has handrail between 34"-38" finish, and balcony 42"above finish. I think this is pretty standard nation wide
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
Old 08-01-2010, 02:17 PM   #6
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
thats the national building code.
chris klee is offline
Old 08-01-2010, 02:26 PM   #7
chief pencil holder
Scribbles's Avatar
Good to know thanks I only work in Cal and Nevada, codes are reciprocal here.
Old 08-02-2010, 01:37 AM   #8
LEVELBEST's Avatar
Rewards Points: 250
LOL! I don't know where you build, but that isn't true.
Section R311.5.6.1
Handrail height, measured vertically from the sloped plane adjoining the tread nosing, or finished surface of ramp
slope, shall be not less than 30 inches and not more than 38 inches (965 mm).
Table R402.2
Trust me, they are much more strict on commercial than they are residential, and I do both. I have done 40+ houses and numerous commercial jobs in just in the last 4 years and this is the code here. I know this well because I had to make some rails at a church meet code recently, and had to make SURE they were right.
Old 08-02-2010, 01:50 AM   #9
LEVELBEST's Avatar
Rewards Points: 250
"Modification: The minimum height for handrails for stairs and ramps was reduced from 34
inches to 30 inches.
The modified section now reads: “Handrail height, measured vertically from the sloped
plane adjoining the tread nosing, or finished surface of ramp slope, shall be not less than
30 inches and not more than 38 inches (965 mm).”
Reason: To be consistent with prior editions of the code and prior construction practices in
South Carolina.
Note: Continued modification IRC 2003 08."
panel height code LBT CON Electrical 10 09-13-2010 01:13 AM
Commercial stair railing height PA woodbutcher Decks & Fencing 0 06-21-2010 05:13 AM
Deck Railing height? hammersoo Decks & Fencing 12 05-14-2007 08:16 PM
2 questions - one code, one structural karma_carpentry Decks & Fencing 5 09-10-2006 01:55 PM
