Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry
Old 02-19-2007, 08:23 PM   #1
sawing old flooring
sorry for the cryptic title-I've found some 2.5" thick pine flooring and considering sawing in half (band saw), then dress the edges to make flooring. The question is when sawing 80 year old pine lumber, milling and installing as flooring, will the 'inside' look similar to the 'outside'? I'm anticipating installing and sanding in place, then finishing, but would hate to run into odd color patterns due to the milling done on he wood.
any advice?
72chevy4x4 is offline   Reply With Quote
Old 02-20-2007, 07:20 PM   #2
pro
Casework King's Avatar
Trade: good old fashioned woodworking/custom cabinetry/frame to finish/everything
use the fresh sides of the halves
Yeah here's an Idea, cut ONE in half.... plane and sand the aged side as well as the fresh cut. Then perform a stain/finish test. I'm sure you'll find very little if any discrepancy in the lumber. If everythhing looks uniform fly with the rest of 'em. Or you could just sit and think for a minute and use the two fresh sides from the halves, just don't put 'em near eachother when installing....... and if your talkin' about tongue and groovin' pine I wouldn't bother a soft wood like pine is not very forgiving with climate changes.
Casework King is offline   Reply With Quote
Old 02-23-2007, 08:40 PM   #3
Why not just use both freshly cut interior faces for the finish side, then there cannot be any problems. Either way, I don't see a problem because the sanding cuts will be deep enough to remove the top aged surface. Hope you have a band saw up to the task. Resawing has brought many a band saw to it's knees, especially old long leaf southern yellow pine, with it's high resin content.
troubleseeker is offline   Reply With Quote
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 12:41 PM
Way's to pick up flooring jobs.. GridRunnerFloor Flooring 8 07-26-2006 08:53 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
Laminate Flooring Gina Flooring 9 04-27-2004 11:06 PM
