Sanding Belts In The Florida Heat?
Old 07-09-2007, 05:09 PM   #1
Remodeler
MinConst's Avatar
I've had a hard time with belts for my belt sander. I put a new one on and it lasts about three minutes. The first one was on my sander for awhile but fairly new. The second was a Makita just taken out of the package. The sander is kept in my trailer and the new belt was in my garage. It gets hot in both places. They fail at the seam. Is there a brand that stands up to the heat?
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 07-17-2007, 09:20 AM   #2
Abrasive Dan's Avatar
Trade: Finishing/Abrasives
Re: Sanding Belts In The Florida Heat?
The humidity has a big affect on the life of belts, and heat doesn't help
either, however, if the belts are breaking at the joint, that is a separate issue.
Although extended excessive heat can dry out the glue and tape
causing the belts to break, there also could be a bad lot of belts. First question I'd ask, are they butt (tape) joint, or a lap joint?
Abrasive Dan is offline
Ceramic Additives Nathan Painting & Finish Work 42 02-02-2010 04:13 PM
Tricks to sizing a heat pump Danno6102 HVAC 1 06-28-2007 06:05 PM
Drywall Sanding Sponges? Abrasive Dan Drywall 6 06-14-2007 05:35 PM
heat pump help!?!!! maxkd HVAC 1 11-10-2006 08:57 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 04:38 PM
