Roof Top Walkways
Old 07-29-2017, 01:13 PM   #1
electricguy's Avatar
Trade: Electrical Contractor
Rewards Points: 26
Roof Top Walkways
I have an opportunity to quote replacing the walkways on a commercial building roof . Looking for ideas what to quote as it is a different logistics that I am used too, We will quote demolition of the old walkways and haul way.
There will be 600 ft of walk way to replace made from 2x6 pressure treated lumber and screwed together. Existing walkway is 2 ft wide but would like to also quote 3 ft walkway or 1 meter wide.
I would like to use a professional looking quote form also.
TIA
Roof top walkways-liquor-distrubution.jpg   Roof top walkways-liquor-distrubution-1.jpg
Doug
electricguy is offline
Old 07-29-2017, 01:24 PM   #2
Rewards Points: 26
Re: Roof Top Walkways
I would like to quote 65.00/ hour 4 guys 3 days
Not sure if that would be enough time
Doug
Old 07-30-2017, 04:42 AM   #3
VinylHanger's Avatar
Rewards Points: 7,048
Then quote it for more. Quote it for how much it is going to take to do the job.
How would we know. You could have slugs and take three weeks, or high speed low drag guys and do it in three days. How fast are your guys?
I know I would charge more on a commercial job, but don't know what the rate in your area is. Maybe less, maybe more. No way for us to know.
VinylHanger is online now
Old 07-31-2017, 12:20 AM   #4
Rewards Points: 26
I suppose not a common thing to replace , I am looking at manufactured aluminum ones
Doug
Old 07-31-2017, 01:30 AM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 18
You would be best to check the warranty on the roofing material and see what is accepted and/or recommended.
This type of job is often best done by a roofer just for warranty liability issues.
griz is offline
electricguy (07-31-2017)
Old 07-31-2017, 02:44 PM   #6
Rewards Points: 26
Thanks I am questioning if there is something we should put down to protect the roof membrane it is a tar and gravel roof. I have had to put down high density Styrofoam and roof felt when placeing non penetrating roof mounts for satellite dishes
Doug
Flat roof drain to municipal sewer - winter freeze? bob_cntrctr Plumbing 10 05-17-2013 03:28 PM
Roof repair, what to do? offshorehs Roofing 15 02-19-2012 11:25 PM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
