Right Tilt Table Saw
Old 08-22-2009, 06:11 PM   #1
KentWhitten's Avatar
The very first big boy tool I bought when I was a young 'un was a Delta 10" contractor saw. I was too green to realize it was a right tilt saw and I barely use the thing except for straight rips. Angles I don't even bother since it angles into the fence.
WTF do I do with this thing? There isn't some bizarre chance that there's a kit to change this to left tilt is there? I figure I am stuck trying to get rid of it. Maybe I just don't see how I could possibly use this table saw to my advantage. Any suggestions? Or takers?
Salmon Falls Cabinetry
KentWhitten is offline
Old 08-22-2009, 07:15 PM   #2
S Winklepleck's Avatar
Re: Right Tilt Table Saw
put the fence on the other side of the blade?
-Steve
"I need the skilsaw." ... "Why did you bring me the drill box?" "It says S.A.W. on it." "Those are my initials."
S Winklepleck is offline
Old 08-22-2009, 07:32 PM   #3
LRG WoodCrafting
Leo G's Avatar
Like winkle said, put the fence on the other side. You can always get an extension on the fence rails and move it over so you can take full advantage of the full left wing. The advantage of the right tile is that the scale reads true when you are doing the angles. If you set the saw to 12" the board will be 12" from the fence referenced side to the point. With a left tilt say you actually have to take the measurement, and board thickness comes into play.
There is no conversion kit. I have both, I have a right tilt Jet and a left tilt Delta. Both have there uses.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 08-22-2009, 08:31 PM   #4
lavrans's Avatar
Trade: General Contractor, Woodworker
A good thing to do with Right Tilts is to either cut the angle, then cut to width or cut to width and then cut the angle. If the miter needs to be accurate it's a bit easier to get a good cut this way. You don't have problems with the extra wood cupping or warping into the fence & forcing the wood away, etc. The one thing you need to do is have a sacrificial fence set up so you can bury the blade into it so the blade is just at or below the top of the board so you're creating a good knife edge, but not cutting away the horizontal face of the board. Also, the fence needs to be lifted off the table high enough that the off-cut won't be captured and turned into a little missile.
Once you get the technique it really works nicely. You can also set up a featherboard to help hold the piece to the table right at the cut area, something you can't do otherwise.
lavrans is offline
Old 08-22-2009, 08:47 PM   #5
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
There is always this trick.
http://www.contractortalk.com/f13/be...utorial-56493/
Gus Dering is offline
Old 08-22-2009, 10:12 PM   #6
I like that Gus, thanks for that. I haven't seemed to get the hang of the blade tilting right. It seems odd to me. Maybe I just need to go use it some more and give it a chance. I've barely used it in 20+ years, it's almost in new condition.
Old 08-22-2009, 10:43 PM   #7
lavrans's Avatar
Nice photo essay! That's exactly what I was talking about. Guy who taught that to me learned it from some cabinetmakers who specialized in veneer work who needed very precise joinery.
lavrans is offline
Table Saw Millwork Thread basswood Finish Carpentry 41 10-18-2009 11:46 AM
Trestle table folding foot? Environments Finish Carpentry 6 08-06-2009 11:20 PM
Craftsman Table Saw? Kastoria Tools & Equipment 7 06-11-2009 07:44 PM
Replacement fence for Porter Cable 698 router table Panzer5 Carpentry 4 04-10-2009 11:47 AM
parts for dial n angle tapco saw table LMS CONST. Tools & Equipment 0 10-27-2008 10:36 PM
