Replacing Exterior Window Sill
Old 11-19-2009, 07:32 AM   #1
jradziew's Avatar
Trade: Handyman/ Carpenter
I have replaced quite a few sills without removing the window, but all of them were single windows. I have a customer with a double window. Full header no window pocket. Has anyone removed the sill and what can I expect under the center of the two windows. The sill is on the edge of filling the rot or replacing the sill.
jradziew is offline
Old 11-19-2009, 10:09 AM   #2
Tom Struble's Avatar
Trade: siding
Re: Replacing Exterior Window Sill
depends on what type/ how old the window
but if youve done many singles you must kind of know whats there,
probably a rotten rough sill too
you could screw a board across the window to help keep every thing in position
Tom Struble is offline
Old 11-19-2009, 04:37 PM   #3
Is it the whole sill, or just the nose?
They are often separate, but not easy
to tell with 100 years of paint and caulk.
neolitic is offline
Old 11-19-2009, 06:06 PM   #4
jradziew's Avatar
No nose full sill
jradziew is offline
Old 11-19-2009, 06:21 PM   #5
Originally Posted by jradziew View Post
No nose full sill
Too bad.
neolitic is offline
Old 11-19-2009, 06:53 PM   #6
PA woodbutcher's Avatar
Never can tell. I've opened them up and found them rotten to the foundation....Good time to ask what is on it for siding and interior walls. Sometimes the preverbial can of worms. Other times simply the sill is gone. Depends on how long they waited to get it fixed
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Squint/mitred sill set out jason shannon Masonry 16 10-17-2009 04:27 PM
pricing for replacing top boards on a deck growie Decks & Fencing 27 06-02-2009 10:50 AM
Replacing rotted rim joist on a gable Tom M Framing 7 04-10-2009 07:58 PM
Replacing a door sill DaHammer Carpentry 11 10-06-2008 12:17 AM
Replacing double window w slider 1st time dvlscapes Carpentry 5 09-03-2008 02:26 PM
