Replacing Double Window W Slider 1st Time
Old 08-28-2008, 11:16 AM   #1
dvlscapes's Avatar
Trade: Construction / Landscaping
Ok, may be doing our first french door install. Well It may actually be a slider because of limited inswing space. I would install an outswing to the new patio we will be constructing but I heard bad things about them.
More specifically there is a double window, 6' wide we will be removing and replacing with the door. There is also a single 3' door we will be replacing with a new window. 1 electrical outlet to move and probably no plumbing in the way. (I have experience doing plumbing and electrical if need be) The interior is drywall and the exterior is vinyl siding.
Questions:
If the house has standard 8' ceilings there is virtually no chance of having to do header work and pull a permit, right?
I feel I have a pretty firm grasp on the material costs for a job like this but the labor I am really in the dark on. Anybody have a ballpark time est to help me?
My best guess would be 3 days w 2 guys to remove the existing double window, install the new door, trim work and cleanup. I figure the door to window conversion would be another 2 days with two men. I will probably add on another half day for misc stuff since this is our first one. How does this sound? Too many hours, too few?
dvlscapes is offline
Old 08-28-2008, 11:27 AM   #2
Patrick's Avatar
Re: Replacing Double Window W Slider 1st Time
sounds like a one day job for everything altogether unless you have to paint.
We always pull permits for our work
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 08-28-2008, 12:24 PM   #3
Meetre's Avatar
Depends. Is the window header height the right height for you door? same for the door to window swap. have you pulled the trim and checked the height to make sure? are you doing the trim and fixing siding? how about drywall? you have to move the outlet you said, and the patch under the new window. are you painting or staining materials? doing the finishing before with touch-ups or everything finished after install. are you SURE there is nothing funky in the walls you may run into? how good are you at patching in vinyl siding? maybe a picture would help. could be a day, could be a week.
Meetre is offline
Old 08-28-2008, 06:55 PM   #4
BuriedHammer's Avatar
Trade: Building/Remodeling
Originally Posted by dvlscapes View Post
If the house has standard 8' ceilings there is virtually no chance of having to do header work ...
Probably correct.
... and pull a permit, right?
I would check with your local building department on that one.
I think you're okay with this estimate since you don't know 100% what you will run into.
The way I would approach this: Figure it like you did, 5 days+ just to cover your ... er... contingencies. But, on your quote, DO NOT INDICATE "days x $$$/day = $$$." Just give a flat price. Then, if Patrick is right and you slam it in one day, you and your boy are in fat city....
BuriedHammer is offline
Old 08-28-2008, 07:55 PM   #5
DavidC
DavidC's Avatar
On the permit your best bet is to ask the AHJ in your area. Here you'd be ok if you don't alter the framing to make the opening bigger. Window to smaller window or door to smaller door, no permit. But window to door means you will remove (alter) the sill framing at least. Permit required.
I would figure 2 man days each opening and throw in an extra for safety. (The estimator might disagree) So my quote would be for 5 man days and I would have two men working. One for each opening and each would help the other with the lifting.
And I agree with BuriedHammer, one bottom line price that includes everything. Don't forget that you recoup your overhead by marking up.
Good Luck
Thanks for not asking how much.
www.CookContractingLLC.com
DavidC is offline
Old 09-03-2008, 02:26 PM   #6
dvlscapes's Avatar
Ok thanks for all the imput. I will base my est on 5 days with 2 men and maybe tak on a couple hundred for misc stuff which I know I will be runnning into. By the way he wants to go with a slider now...I figure If anything they are easier to install.
Estimating Exterior window and door painting nolanco Painting & Finish Work 1 08-23-2008 11:53 AM
Pick Up Artists Guide To Sealing The Deal. Close That Sale! Ed the Roofer Marketing & Sales 5 02-16-2008 12:58 PM
Header required over window in gable end of dormer? edfogel51 Carpentry 18 01-05-2006 01:53 AM
Window condensation PipeGuy HVAC 6 11-08-2005 09:18 AM
Window leaks...Hmmm wonder why! pitterpat Windows, Siding and Doors 9 10-29-2005 05:27 AM
