Replacing Corner Boards On Tudor Style Home
Need to replace some rotten corner boards on a Tudor style home such as in the picture. Can they just be pried out and replaced, or does the stucco make it more complicated.
Re: Replacing Corner Boards On Tudor Style Home
They can be pried out and replaced. Score the sides with your knife to avoid pulling chunks of piant, caulk and possibly stucco.
I like Green things
Easy does it, should come out of there with few issues.
Trade: siding
is it real stucco or hardi type panel?
Trade: Skyhook operator
I've done work on similar homes, and hate to say it, but you won't know until you do it. Do you know what year the house was built?
Id say 1920's
Everyone one of those I've worked on (by that I mean 2) the stucco was done after the casing / fascia so the pieces I removed just came out with little of an issue and left a nice little pocket to fit back in.
Like the guy said, score the edge and remove any caulking before you take it out. You might not want to just rip it out as well, but use a cat's paw to remove existing fasteners to prevent mishaps and breaking off stucco. On the 2 I did I had to plane down 2x material to get the reviles right because they used true milled lumber back then. Last edited by Super-Mike; 01-06-2009 at 11:33 PM. |
#9 | |
Re: Replacing Corner Boards On Tudor Style HomeQuote:
i had pretty much the same experience with the 3 that i have had to do in the past few years. but don't forget to ask your self why did it rot? i used a composite lumber back then to replace it with. and also had to mill it to fit.
BSA Renovations - Restoration and Renovation Specialists serving New Jersey's Bergen County. Bergen County's Premier Home Maintenance Provider. |
May not be necessary, but I have usually
made a "relief cut" with a masonry blade in a grinder. I wear a belt and suspenders too.
Chief Toilet Mover
Trade: Bathroom Remodeling
Sounds like a good place for an addendum on the work order or contract out-lining exactly what your stated price covers and doesn't. Do that and you get to write a change order or you roll the dice on how much the stucco repairs are going to cost you and come out of the profits of the job.
Trade: Remodeling 30+ yrs
If you run into a problem board, I run my saw up the middle at a 45 to the depth of the board, then pry it put without putting stress on the stucco.
I'm replacing with azek, Its on an gable dormer of a 3rd floor attic, so it wont be super noticeable. Its just the bottom of it thats rotting because the second layer of roofing that was installed a few years ago touches the bottom of the board.
He had one other project he asked us to look at but we declined, I wish I took a picture... Get this He hired a guy two years ago to add a second floor out door balcony. 4' off the house, 12' wide. Framed with 2x6 just nailed into the side of the house through the stucco and the only support is 4 2x4's at a 45 degree angle under this thing toenailed into the wall. The owner cant imagine why the handrails are pulling away from the house. I refused to even walk onto it. He said he doesn't want columns or support posts, so I said no way.
Trade: siding
that dont even work for bay windows
| Black marks left by inside corner applicator | AARC Drywall | Drywall | 5 | 10-04-2008 09:41 AM |
| Transfer Switches Home use | Bubbles | Electrical | 6 | 09-20-2008 03:07 PM |
| Home Staging | Any Season | General Discussion | 3 | 09-13-2008 09:34 AM |
| Set up at a Home Show Today... | Max10 | General Discussion | 16 | 10-18-2006 04:03 PM |
