Replacing 18' Railings
Old 02-18-2018, 07:20 PM   #1
mike_h's Avatar
Trade: Handyman
Rewards Points: 6
This is my first post so hello to everyone on here.
I'm hoping to get some advice from the more experienced carpenters on this forum.
I have a client who wants to replace the railings on this staircase. (attached photos)
The railings are over 18' long and he wants it to remain one solid piece of wood so I'm wondering where the best place to source a quality piece of lumber would be. I was thinking a 2x8 would be best with another piece attached to the top as a handrail of sorts.
The customer was also hoping to salvage the 2x2s but I'm not sure if that's possible. It seems like once the railing was removed they would all fall off for the most part.
Any other foreseen issues / advice would be greatly appreciated.
Thanks and I'm happy to be a part of the forum,
Mike
Replacing 18' Railings-20180218_153755.jpg   Replacing 18' Railings-20180218_153728.jpg   Replacing 18' Railings-20180218_153748.jpg
mike_h is offline
Old 02-18-2018, 07:25 PM   #2
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 404
Re: Replacing 18' Railings
If it were me, I'd install an intermediate post (4x4) half-way down. BUT, you can get 20' 2x8 if you want to replace it as is.
I'd use the opportunity to replace the rails altogether.
Lunicy is offline
Old 02-18-2018, 07:31 PM   #3
mike_h's Avatar
Trade: Handyman
Rewards Points: 6
I forgot to mention that the customer wants it to be one solid piece.
mike_h is offline
Old 02-18-2018, 07:41 PM   #4
Southbluff's Avatar
Rewards Points: 68
In this circumstance, if I couldn't get the length needed, I think I would get 12' lengths, then use a router to make a long half lap joint. The joint would be cut into the face of the board. Not the edge. Glue with your choice of exterior wood glues, plus several countersunk screws. From the pics I dont think the deck warrants milling the railing.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Southbluff is offline
Old 02-18-2018, 08:17 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,063
Any good lumberyard should be able to get you 24' 2x material, even if they don't normally stock it.
I wouldn't be optimistic about being able to re-use the balusters and have them look decent. Old paint, varying levels of integrity, damage done while removing them, time taken to clean them up...
What's shown in those pics doesn't meet code as a graspable handrail.
Tinstaafl is offline
Old 02-18-2018, 10:40 PM   #6
rblakes1's Avatar
Rewards Points: 1,472
Any idea how old that set up is? Looks like it's going to be as can of worms where you try to just remove the railing, but the spindles are old so they start breaking, then they pull out of the rotted stringers.
Make sure it's clear in your contract what is and isn't included.
I also thought I remembered hearing somewhere that wood railings could go max 10', maybe one of the deck guys can chime in
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
Old 02-18-2018, 10:51 PM   #7
Mordekyle's Avatar
Rewards Points: 3,300
I replaced a 10' section last week
I snipped a 1 x 2 to length and butted it under the rail, shooting an 18 gauge brad into each picket to maintain spacing.
Some of the screws came out; the rest were snipped with the recip.
I copied the old rail onto the new prepainted piece. The 1 x 2 held it while I installed it and refastened the pickets.
Mordekyle is online now
Old 02-19-2018, 12:15 AM   #8
GC/carpenter
Californiadecks's Avatar
Rewards Points: 8,506
Can you up sale him the whole enchilada. Attaching new railing on dalapidated stairs doesn't make safety sense nor financial sense. Imo.
Mike.
_______________
Californiadecks is online now
The Following User Says Thank You to Californiadecks For This Useful Post:
parkers5150 (02-21-2018)
Old 02-21-2018, 06:04 PM   #9
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,102
Mike.
_______________
putting a dress on an old and tired pig
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following User Says Thank You to parkers5150 For This Useful Post:
Californiadecks (02-21-2018)
Old 02-21-2018, 06:47 PM   #10
Designer/Contractor
Rio's Avatar
Rewards Points: 1,832
Make sure the new railings onto the old pickets will pass the 200 lb concentrated load requirement per the IRC.............
Rio is offline
The Following User Says Thank You to Rio For This Useful Post:
Old 02-21-2018, 10:09 PM   #11
GC/carpenter
And the balusters need to withstand 50 lbs per square foot throughout the entire infill.
Mike.
_______________
Rio (02-22-2018)
Wood railings on top of a brick wall fayton23 Decks & Fencing 9 01-18-2017 08:16 AM
Replacing subfloors 1swatcop1 Framing 5 04-03-2013 09:27 PM
Replacing chemical injector small part? arc3822 Pressure Washing 0 04-01-2013 06:02 PM
Replacing double window w slider 1st time dvlscapes Carpentry 9 03-28-2012 10:49 PM
Protecting Metal Railings Kastoria Painting & Finish Work 0 05-24-2010 06:57 PM
