Repairing Azek
Old 05-24-2011, 10:08 PM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 8,614
Repairing Azek
I dropped a board and it took a chunk out of a piece of water table cap that is Azek. What is the best approach to repair this stuff? I use epoxy and bondo on wood, but not sure about the Azek. thanks, Nick.
Morning Wood is offline
Old 05-24-2011, 10:39 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
Re: Repairing Azek
you can use those fillers on azek too
Tom Struble is offline
Old 05-24-2011, 10:50 PM   #3
Box Builder
Re: Repairing Azek
Thanks Tom. The epoxy will stick to it? Usually west system doesn't stick to plastic. Although Azek is some other kind of plastic.
Old 05-24-2011, 11:08 PM   #4
Trade: siding
Rewards Points: 4
Re: Repairing Azek
bond and fill has epoxy filler for pvc but you can use the stuff you use for wood too,or you can use a multimaster and carve out the bad peice and glue in a new section
loneframer (05-24-2011)
Old 05-25-2011, 06:01 AM   #5
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Re: Repairing Azek
cut it out and replace IMO
TBFGhost is offline
Old 05-25-2011, 06:07 AM   #6
Box Builder
Re: Repairing Azek
Too much work to cut out and replace. Aluminum flashing vycor mitered corner etc. Filling it will be the approach I take. Should be fine its in the back of the house. Plus it's my house, so I'll have to live with it.
Old 05-25-2011, 08:24 AM   #7
Working
Cole82's Avatar
Rewards Points: 2,276
Send a message via AIM to Cole82
Re: Repairing Azek
Did it crush/dent or did it take a chunk out? If it's a chunk then you can just take pvc glue and glue it back in.
Cole
The boss of awesome
Cole82 is offline
Old 05-25-2011, 07:14 PM   #8
Trade: siding
Rewards Points: 4
Re: Repairing Azek
thats another reason why it's best to paint pvc,makes it much easier to repair
hailey (06-14-2011)
Old 05-25-2011, 10:16 PM   #9
Finish Carpenter
TBFGhost's Avatar
Re: Repairing Azek
If it is dented, use a heat gun, you can take out dents and dings. Azek has a memory.
TBFGhost is offline
Old 05-26-2011, 06:19 PM   #10
Box Builder
Re: Repairing Azek
Its worst case scenario. Dented and took a chunk out, and sort of deformed the area around the chunk. I'm going to try bondo and see what happens. Already had one coat of paint on it. I was going to repair it today and my dad said: why don't you wait till we finish siding... That isn't a good sign.
Old 05-28-2011, 09:53 PM   #11
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 5,314
Re: Repairing Azek
If it's what I'm picturing, I'd definitely say cut it out with a multimaster and patch in like Tom said.
The Azek brand PVC glue is pretty good and will get a good solid hold. I've patched in pieces with it.
Easy Gibson is online now
Azek Exterior Door Surround on Brick Wall CookeCarpentry Carpentry 36 10-01-2009 09:25 PM
Question about Azek for loneframer, worldllc or others mact60 General Discussion 63 06-23-2009 08:07 PM
Bending AZEK Trim hailey Windows, Siding and Doors 5 12-13-2008 05:19 PM
Bending AZEK Trim and Moulding hailey Finish Carpentry 1 12-11-2008 05:54 PM
Azek Panels Marc DeLorenzo Remodeling 4 11-14-2008 07:37 AM
