Trade: painter
Removing Ceiling Fan
I am removing ceiling fan and need to patch the hole. What is the best thing to use? Is there any patch kits out there?
Thanks, |
Insert title
Trade: Doors-Windows-Decks
Re: Removing Ceiling Fan
http://www.thatdrywallguy.com/ This guy has some great classes on patching. I think that the depot sells his book, you might be able to read the parts that would help you while waiting in line. I am not sure if his web-site goes into much detail, check it out.
Check out www.jlclive.com he has a few free classes that fill up and are worth the trip. I went to one a couple of years ago and he had people come up and kick holes in drywall and repaired them during the 1 hour class.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
Professional Remodeler
Are you removing the electrical box? if not get a round blank deco cover to fit the screw width (3" or 4") Not the ones for a round junction box, they are nicer looking and made for just that purpose. Home Despot and bLowes sells them.
If the box is coming out, I generally take a piece of 1/2" or 3/4" plywood about twice as long as the hole and not quite as wide, put a drywall screw in the middle of the face of the board leaving 3/4" or so sticking out. Manuver the board up into the hole with the screw sticking down, center the board over the hole, and drive a couple screws through the ceiling into each end of the plywood, pulling down on the screw you centered in the board to keep it from moving. Then, cut a piece of scrap drywall the same thickness as the existing ceiling to fill the hole and screw it to the plywood. (take the 'hold-down' screw out first Two or three coats of EZ-20 feathered out and sanded, and once you paint it you will never know it was there.
-Mike- Falcon Contracting Residential - Commercial
Trade: Squirrel Handler
Excellent point, you CANNOT permanently cover(like with plaster) or hide the box, there has to be access.
These Arlington blanks are super-slick. No exposed screws, and they look great, in my opinion. They are textured slightly, to accept paint.
Trade: Home Remodeler
I always install a smoke detector when you have a junction box that can not be covered. You can send reminders 2 times a year to remind customer to check . This also shows you care about your customers safety. There can never be enough smoke detectors in a home.
Steve |
#7 | |
Re: Removing Ceiling FanQuote:
Seems like an okay idea to me. I'd worry about the AFCI protection requirement if this is in a bedroom. Seems like the battery type detector probably isn't listed as a blank canopy for a box, but a hardwired/battery detector is certainly intended to be used on a box.
#9 | |
That's kind of what I was wondering about and also the possibility of the power being switched.
#11 | |
#12 | |
Honestly, I thought that the guy who said that he puts smokes over blanked off boxes was pulling our proverbial legs, but it's hard to say. Most of the rest of the world would blank it off. |
Bust the box out, screw a small piece of wood spanning the hole, then cut a piece of drywall to fill the hole. Tape it and you're done...
Celtic's #1 Fan
Trade: electrical
Re: Removing Ceiling Fan |
Electro-Mech. Contr.
Trade: Mechanical Contractor
| removing ceiling texture | i_plant_art | Drywall | 27 | 10-30-2008 02:45 AM |
| Vertically installed suspended ceiling | Maplehead | Remodeling | 13 | 03-29-2007 10:06 PM |
| tips for cutting into a ceiling / wall corner | Zeebo | Painting & Finish Work | 30 | 11-30-2006 09:36 PM |
| Removing popcorn on a high pitch ceiling | AAPaint | Painting & Finish Work | 22 | 02-02-2006 09:53 AM |
