Razing A Garage
Old 08-15-2009, 06:03 PM   #1
ARTSBEST's Avatar
Trade: LANDSCAPER
Razing A Garage
Two car garage must go. What's the best way to raze one? I don't want to reverse the building process when it was built by starting at the top removing the roof then the walls etc., etc. I'd rather just push it down. But how? Cut every other wall stud on opposite side of where we're going to push it with back hoe or start on top and push down? We can't torch it for there are telephone wires nearby.
ARTSBEST is offline
Old 08-15-2009, 06:06 PM   #2
Yard Boi
HusqyPro's Avatar
Trade: Landscaping
Re: Razing A Garage
Rent a mini-ex with a thumb to pull it apart and load it in dumpsters or dump trucks.
Use your backhoe to push/pull it apart, then use the loader to load it into dumpsters or trucks.
Rent a bulldozer and push it over.
In short take something with a diesel engine and hydraulic atachments and have fun. Beat it apart.
Bob's Lawn & Landscape
When You Want The Best
Serving the LC Valley & Moscow-Pullman
HusqyPro is offline
The Following User Says Thank You to HusqyPro For This Useful Post:
XanadooLTD (08-15-2009)
Old 08-15-2009, 06:08 PM   #3
BCConstruction's Avatar
Trade: Construction
Re: Razing A Garage
Hey artsbest are you the same artsbest on the ford forums?
BCConstruction is offline
Old 08-15-2009, 06:15 PM   #4
pizalm's Avatar
Re: Razing A Garage
Like Husqypro said, use a hoe with a thumb and knock it down and load it up. Rent one or pay someone to do it.
pizalm is offline
Old 08-15-2009, 06:42 PM   #5
master of none's Avatar
Trade: carpenter
Re: Razing A Garage
I watched a guy demo a garage one time. He slid a dumpster right into the stall and just went to town with a backhoe.... Tore it down and loaded it up in one step.... Thought it was pretty clever.... It was just one stall you might need two dumpsters....
Abandon the search for truth settle for a good fantasy
master of none is offline
Old 08-15-2009, 07:20 PM   #6
GitSum's Avatar
Re: Razing A Garage
Contact your local fire department and see if they would like to burn it down for training
GitSum is offline
The Following User Says Thank You to GitSum For This Useful Post:
carpentershane (08-16-2009)
Old 08-15-2009, 08:15 PM   #7
cleveman's Avatar
Trade: custom home building
Re: Razing A Garage
Everything is going wireless now. Just torch it and send a bill to the telephone company for removing their old copper lines.
This is the only way to go. Be a man. Step up and do it.
cleveman is offline
The Following User Says Thank You to cleveman For This Useful Post:
davitk (08-15-2009)
Old 08-15-2009, 08:35 PM   #8
robert c1's Avatar
Trade: remodeler/gc
Re: Razing A Garage
You don't need/want to remove 2x4's, just remove whatever is resisting racking forces on the two sides you want to fold. Set up some temp bracing then take out the t1-11, sheathing, let in bracing, whatever. then push or pull it over.
robert c1 is online now
Old 08-15-2009, 08:49 PM   #9
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
Re: Razing A Garage
KABOOM!
"Your problem does not constitute an emergency on my part"
CScalf is offline
Old 08-15-2009, 09:09 PM   #10
Trailer park boy
shanekw1's Avatar
Re: Razing A Garage
Buy some whiskey and some sledgehammers then invite 10 of your rowdiest friends.
shanekw1 is offline
Old 08-15-2009, 09:14 PM   #11
Warren's Avatar
Trade: framing/remodeling
Re: Razing A Garage
We moved a two car garage once to a new foundation using a crane. I wonder if you could strategically rig something, hook it to a crane, and rip it inside out. Maybe grab the door header, lift it, raise it up maybe 40 feet, and drop it??
Warren is offline
Old 08-15-2009, 09:16 PM   #12
CScalf's Avatar
Re: Razing A Garage
you and that damned whiskey...
CScalf is offline
Old 08-15-2009, 09:48 PM   #13
Trailer park boy
shanekw1's Avatar
Re: Razing A Garage
I've never tried what i suggested, but I'm sure it would be fun.
shanekw1 is offline
Old 08-16-2009, 09:49 PM   #14
ARTSBEST's Avatar
Trade: LANDSCAPER
Re: Razing A Garage
Yes, I'm the same guy over at Ford.
ARTSBEST is offline
Old 08-16-2009, 09:59 PM   #15
Trade: Construction
Re: Razing A Garage
Hey man must have been you with that name. Bsimmer3000
Old 08-17-2009, 11:09 PM   #16
ARTSBEST's Avatar
Trade: LANDSCAPER
Re: Razing A Garage
No. I believe he's an ex-military person. I never was in the military.
ARTSBEST is offline
Pole Barn Garage mrmike Carpentry 26 10-28-2009 08:29 PM
garage guru's Nath Construction 17 04-18-2009 11:01 PM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 02:25 PM
Custom Garage Doors Just-In-Time Carpentry 23 12-08-2008 11:04 PM
Excavate garage floor my only option? EDHC Excavation & Site Work 1 12-03-2008 05:16 PM
