Trade: Landscaping
Radiant Barrier And Housewrap???
I have a question about the Solarboard OSB and housewrap. If you use the Solarboard for side sheathing, can you put housewrap on top of that and it still be effective? Doesn't it require at least a 3/4" gap, say between the brick to be effective. Does the housewrap affect its function? While typing this, I thought of the Solarboard used for roof decking with shingles next to it and it still works. So I may have answered my own question but would like some input.
Thanks, CB |
Re: Radiant Barrier And Housewrap???
try posting this question in the construction forum for more responses
Hope I am not too late. I am not sure you answered your own question .... let me explain. On the Foil Backed OSB I just had installed, the instructions written on the foil indicated that if it was installed on the roof, the foil side should go down. If installed on the walls, the foil side should be facing out.
So I would welcome any comments as I am not sure why on roofing applications the foil side should be facing down - but that's what the instructions indicated. |
Home Repair Specialist.co
Trade: carpentry
My guess is so you dont put holes in it when you are roofing ?--Dont realy know
Professional
Trade: Finish Carpentry
How to Install SOLAR BOARD® on Exterior Walls
You do need an air space!
Trade: mech.
Hmmmmmmm
Doug
yes it needs to breath..ahhhhhhhh..so many installs done improperly create a haven for mold and rot......
Trade: siding
you mean the 3/4'' air space is so it can ''breath''?how exactly does a piece of osb breath?
Tom |
Custom Builder
Your better off using regular osb and then foil faced foam over. About the same cost and you get a thermal break as well as the benifits of the foil. You still need a drainage plain and theres all kinds of thoughts on where that should be when using foam.
Where are you located? The foil face might do you more harm then good. |
Trade: siding
the 3/4 air space is for the radiant aspect of the panel to work like it's supposed to,i would bet in a brick type application the manufacturer would say to tape the seams with a foil tape,putting a house wrap over an aluminium overlay seems redundant
whether it's a good product or not for that application i don't know
Tom |
#13 | |
Trade: siding
Re: Radiant Barrier And Housewrap???Quote:
if your saying drainage and convective drying i would agree with you,but just saying breathing or airflow can be misleading,air can bring in the same moisture your trying to keep out
Tom |
#14 | |
Insulation(NIA Certified)
Trade: Insulation blown-in/Batt (Crawl-space Specialist)
“Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.” |
Trade: siding
Re: Radiant Barrier And Housewrap??? ttthhhanks!
Tom |
Trade: siding
Re: Radiant Barrier And Housewrap???![]()
Tom |
#18 |
Custom Builder
Putting wrap over foil insulation is redundant. Putting wrap on with radiant sheathing has to be done. The sheathing is not a vapor barrier. So in this case I would say the vapor barrier has to go under the sheathing so it does not mess with the radiant properties of the board.
I almost framed a house with all radiant osb. The rep from GP was going to be invloved and all. It fell through so I never got to ask about the vapor barrier and other questions I had. ![]() I used foil foam when I built my house. I put osb drain wrap then the foam with foil tape. On my addition I exnayed the foil foam and am just using dow blue board. The foil does more harm than good here as we have way more heating days than cooling days. I want that winter sun to warm the house. If I lived in the southern US Id go foil wrapped. |
#19 | |
Doug
This is what makes climate controlled sealed crawlspaces a big hit here for those who can afford to do it. |
| Radiant Barrier and Housewrap? | Charles Bagley | Construction | 0 | 02-17-2007 02:19 PM |
