Question: Binding Doors
I have a door question:
I have an older house (built in the 1940s). The door jambs are steel, from a company called Kewanee Door Frames. Because they are steel and fixed, when I began replaceing doors, I decided to get slabs and mortise/bore them myself. All had been going well until I got to a closet where the door binds, and I can't figure out why. Usually I can trial and error when I don't know what I'm doing, but I just can't get this one to stop binding. Suggestions? I was also going to post a few pictures of my remodel to see if any of the experts could come up with a solution for a couple other finishing details. |
Re: Question: Binding Doors
A door should have a 1/8" gap on its opening side, this should be easy to see and trim. Did you maybe set the hinges too deep and are binding on the frame?
#3 | |
Re: Question: Binding DoorsQuote:
I thought that might be the case, and I reset the hinges as mush as possible in the frame, but it is metal, so more than about 1/16" is not possible left to right. I made that small move by using a wall anchor and a smaller screw. A bit Rube Goldberg, but I figured I would do that to determine if that was the case. The frame it is steel, and is tied in to the wall with metal tabs. When I have put in the doors, on most of them, I have just followed the predrilled holes on the frame, and mortised the hinges on the door. As for the depth of the mortise, I tried shimming the frame and door mortises as well, but it still seems to bind. I am at a loss. I am no carpenter, by any stretch of the imagination, but I have not been this unable to fix a problem. |
Priced In
Trade: Exiled For Life
One word BONDO. When I work on older homes and a budget less that a this old house episode. Bondo. A carpenters best kept secret.
Have you also thought about shaving the doors down ? Last edited by JustaFramer; 02-11-2005 at 11:59 AM. |
General Contractor
Try shimming the barrel side of the hinge. Cardboard pressed down will work - or drywall shims.
does your door blank have a bow in it try removing the middle hinge to see if it works better or any one hinge at a time sounds like its pre stressed.
I second the use of bondo. It is used quite a bit in the commercial carpentry trade. They do much more metal work then woodwork these days anyway...
#8 | |
Priced In
| What to use on sandblasted security doors? | Dorman Painting | Painting & Finish Work | 3 | 08-07-2007 06:24 AM |
| Question for you drywall guys and prehung doors | carlspackler | Drywall | 4 | 11-30-2006 08:33 AM |
