Porch Baluster Spacing
Old 12-22-2008, 11:58 AM   #41
BuiltByMAC's Avatar
Trade: Construction
Re: Porch Baluster Spacing
Burby, the common name for that style of handrail is "Chippendale" - not to be confused w/ the guys in Vegas!
Here's a question - did you half lap the 2x2s that make up the center "X" or is one totally solid and the other in 2 parts?
Mac
BuiltByMAC is offline
Old 12-22-2008, 12:12 PM   #42
Burby's Avatar
Trade: Remodel / repairs / Certified Mold inspector, Remediator
Send a message via AIM to Burby
Mac
hahaha, no confusion about the two, the chippendale x is half lapped, glued & a 1 1/4 SS screw
All the typical chippendale rail sections around here are that, regardless of the width of each section. That is the problem she was having in deciding on, the chippendale or typical vertical pickets. So I combined the 2, 1 for looks, 2nd for speed in building. As soon as one goes beyond the point of a 45 degree angle, you have different angles for each section and to many I have seen done as that look like crap. Combining both adds to the looks and sure does simplify construction.
You can precut all your pcs and just build build build
Proud to help make a house your Home
Never judge another by one's own intelligence
Burby is offline
Old 12-22-2008, 12:29 PM   #43
BuiltByMAC's Avatar
Trade: Construction
Nice info, man! A good way to do that type of project... more uniform look, production cut all the angled pieces - faster, better, prettier, stronger.
Mac
Old 12-22-2008, 03:35 PM   #44
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
Originally Posted by Burby View Post
From the H/O going round & round on wanting a different design than all others.
After we talked for an hour or so after she had spent days trying to come up with something different, I came home made a sample rail section, emailed her the pic & reply was "I love it, let's use that design"
here is the pick I sent her. Once approved I premade all the sections, including prime & 1 finish coat to allow spray painting the sections, prior to delivery & install. Worked great
Ahh creative, now the house paint just needs a new color I'll have to keep that design in mind. Looks like it would be fun to build.
KennMacMoragh is offline
Old 12-22-2008, 09:37 PM   #45
forsmant's Avatar
Trade: General Contracting, Remodeling
I measure the distance between posts and divide by 4". I then round that number up to the nearest whole number. I lay that number of balusters together and get the total measurement of balusters. I subtract that number from the number between posts and then divide the result by open spaces, which is one more than balusters. This will make the gaps all the same between each post but not necessarily from one section to another. The difference is negligible and will only be seen if measured.
forsmant is offline
How to level out a concrete porch? ProVolley9 Masonry 17 08-27-2008 09:09 PM
Porch Staining Issue winndesign Painting & Finish Work 6 07-19-2007 09:30 AM
Paint your Porch? Chris G Off Topic (Non Trade) 1 01-31-2007 02:08 PM
How would you frame this porch rebuild? karma_carpentry Framing 10 04-08-2006 07:45 PM
stone over painted porch Gordo Masonry 5 03-21-2006 10:52 PM
