06-16-2006, 06:21 PM
#1
Trade:
Cabinetmaker
Porch baluster spacing
I'm putting a railing around a porch on an old home. I'm using newel posts, centered between the columns. I'm wondering the proper way to space the balisters on a balistrade where one might be 8' long and the other 7' long.
The porch railing will consist of 9 balistrades and all the columns are not the same distance apart.
How do you space the balisters so they look uniform?
06-16-2006, 06:30 PM
#2
Remodeling Contractor
Trade:
I'm in CT and code is 4" center to center, So I would have to make it work around the building code.
"Man is a tool-using animal. Without tools he is nothing, with tools he is all."
Thomas Carlyle (1795-1881)
06-16-2006, 07:16 PM
#3
Trade:
Cabinetmaker
Here, it's 3 7/8...so just commit to the spacing and play with the ends?
06-16-2006, 07:30 PM
#4
Trade:
Roofing, siding, framing
no more than 4" space in MI
06-16-2006, 07:35 PM
#5
Master Craftsman
Trade:
Rustic interior woodwork
I wonder who measured to decide that a baby's head is bigger than 4"
06-16-2006, 08:00 PM
#6
Trade:
Good question Dave.....
06-16-2006, 08:35 PM
#7
Trade:
Carpentry
I like to adjust the spacing so the ends are the same as the others--I think it looks better.
Someone posted a baluster spacing calculator on here some time back. Just plug in your overall distance, baluster width, spacing and whaallaaa.
Even with the calculator it's still a good idea to start from the center and measure out.
For some reason I can't attach the file, so if you need, I can e-mail it to you.
06-16-2006, 08:50 PM
#8
Trade:
Cabinetmaker
Thanks! I searched and found this calculator...it'll be handy.
http://www.virginiarailingandgates.c...icketspace.asp
I want the end spacing to match up also...that is what is perplexing. If one distance is 37" and the other is 38"...how do you configure the balusters to remain evenly spaced?
The calculator should do the trick.
06-17-2006, 12:14 AM
#9
Charitable animal
Trade:
decks
This is only good if you have an odd# of balusters in that particular segment, If you have an even # you will have to measure out from the center half the spacing.
1/2 spaces on segment ends:
post to post (inside 2 inside)=x
# of balusters=y
baluster spacing=z
y= x/(z+one baluster width), round to nearest whole #
z=x/y
take 1/2 of z and divide in half, this is your first and last space between baluster and post.
even spacing entire segment:
(x+one baluster width)/z=#of equal spaces
(x+one baluster width)/# of equal spaces=z
butt your tape to post or post mark and go, baluster goes on side of mark that your butting
this is no different than figuring stairs, just think of the baluster spacing as the rise and the baluster itself as tread thickness
hope this helps
06-17-2006, 06:39 AM
#10
Trade:
post spacing
Robie if you are only replacing the the guard rail you wouldn't need a building permit, then you can build the rail to the design when the porch / house was built . if you want to follow todays code yes the 4 inch rule is a fact --but if the porch is 30 inches or less to the ground you don't need a guard rail
06-17-2006, 10:26 AM
#11
Trade:
General Contractor
Robie, I usually try and have even spacing within each section, and if the spacing between sections differs too much I might cheat one or two balusters at the posts.
Problem is how to find the equal spacing! I used to have a hard time figuring it out until I started using this method, imagining a baluster buried in each post, and dividing the OC measurement until I was within the 4" max gap rule.
01-08-2008, 11:16 AM
#12
Trade:
Home & Building Inspector, Energy Rater, Remodeler
Deck Railing
Deck rails are now required to be higher, and balustrade gaps narrower because humans have become taller, but their heads have become smaller. ( kidding ) 4" center to center is rule of thumb, a 4" ball should not be able to pass through any gap
01-08-2008, 11:40 AM
#13
Trade:
Building and Remodeling
Just ask any women that has pushed one out...she'll tell you...
01-18-2008, 05:05 PM
#14
Trade:
remodeling contractor, SE Mass.
I like to keep the baluster spacing consistent,section to section, so I just use the number of balusters and weather one is centered on the section or a space is centered on the section, I make a story pole and work off the centerline of the rail sections to get the end baluster spacing what I want.
Phil
01-18-2008, 06:01 PM
#15
Trade:
General Contractor
I am going to use 72 1/2" as an example
72 1/2" / 5" (whatever ballester spacing may be) = 14 1/2 (round this number up to 15 and this is the number of ballesters)
72 1/2" / 15 = 4 13/16" spacing
I ussually do a layout on either the top or bottom rail to make sure my numbers work
01-18-2008, 06:53 PM
#16
LRG WoodCrafting
Trade:
Professional Sawdust Producer
Close, code is no bigger than a 4" space between balusters. The inspector will show up with a 4" ball and it can't fit through any balusters.
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Originally Posted by HusqyPro
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
01-20-2008, 11:40 AM
#17
Trade:
I use a 2x4 for spacing, pull center and plumb it. For decks around me it is 3 1/2".
Thanks
01-21-2008, 09:51 PM
#18
Trade:
Remodeling & Decks
I've never seen a dude show up with a ball, but in one town near me, the inspectors will take a tape to EVERY baluster. I just stand there and laugh at them. If you must be that critical, go to three random places and measure.
I get PO'd when inspectors criticize what is clearly above average work that exceeds code just because they have to say something negative. I just framed a deck that is probably the tightest deck frame this guy will ever see and he actually told the HO to make sure the riser heights were consistent because "the bottom riser is already one inch shorter than the other ones" (the 5/4 treads were not on yet). What a stupid thing to say. He made my HO question me for doing something that a lot of guys F-up. He should've said, "Oh...your contractor knows what he's doing."
Rant over. Sorry.
I've always wondered why anyone would settle for being an inspector when they could make much more money building things instead.
01-21-2008, 10:40 PM
#19
Trade:
Carpenter
A lot of inspectors are contractors that couldn't hack it (or should I say that could 'only' hack it) . . .
01-21-2008, 10:45 PM
#20
ContractorTalk Flunkie
Trade:
Remodeling and Renovation Contractor
TRUE, TRUE, TRUE
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
