Pole Barn Trusses - Page 2 - Carpentry - Contractor Talk
Pole Barn Trusses
Old 08-13-2017, 10:57 AM   #21
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 12,154
Re: Pole Barn Trusses
Originally Posted by Joasis View Post
Do you see something I don't?
Except for the wave in alignment, I don't see a real problem, and if this is in fact a barn, and purlins will be nailed down, and metal screwed down, it is structurally fine. Looks like he even used the metal spacers between trusses that are all the rage now. Blocking looks good.
If it were a home and you were decking the roof, then yes...I would fix it before I decked it because we all know it will show through and could be a problem later.
For $6.80 a run I love the truss spacers and wont set trusses without them.
We also deck barns daily around here
A&E Exteriors is offline
Old 08-13-2017, 11:13 AM   #22
Joasis's Avatar
Rewards Points: 2,916
Originally Posted by A&E Exteriors View Post
Dude, have you ever in your life seen a professional carpenter use a 4' level to plane truss tails while setting?
No None of this is the end of the world nor will it ever be noticeable after the roof is decked, but still.....come on setting trusses with a 4' level? Come on..this guy is a DIYer
Dude...what if you were not taught the correct way to do something, and then were ambitious enough to head out and get some work on your own?
I did my first ICF in 1981...and there wasn't a forum of top notch pro's to give me any advice. I was self taught doing stuff that no one even knew may or may not work. I was 20 years old, on my own, and while I framed homes for a builder, I cannot really say I had any good teaching. It was all by the seat of my pants.
Again, I have seen far worse from guys who claim to be way better.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following 2 Users Say Thank You to Joasis For This Useful Post:
sparehair (08-14-2017), VinylHanger (08-14-2017)
Old 08-13-2017, 11:15 AM   #23
What I am saying is this guy is not a pro and shouldn't even be posting here
Old 08-13-2017, 11:19 AM   #24
Agreed
Old 08-13-2017, 11:38 AM   #25
Joasis's Avatar
You guys may be right about him being a pro...maybe, after he builds this, he will do another. We don't know.
In 1997, I was working in engineering for a steel building manufacturer....I would have never guessed my son and I would be erecting 1 few hundred thousand feet of steel every year in addition to my home building. And my point is a lot of experienced steel erectors would die before they offer you any of the tips or tricks of the trade.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
A&E Exteriors (08-13-2017), Dirtywhiteboy (08-13-2017)
Old 08-13-2017, 04:28 PM   #26
hdavis's Avatar
Rewards Points: 3,925
If you're getting paid, you're a pro. You may be an inexperienced pro if it's your first one.
I haven't even touched a truss in years - nothing but small cut roofs.
hdavis is offline
Old 08-13-2017, 04:36 PM   #27
Dirtywhiteboy's Avatar
Rewards Points: 8,494
Originally Posted by slowsol View Post
The beam that his tails are sitting on.
The heel nails to the wall.
and tap them over so the heels are perfect.
We nail the facisha to the tails.
Dirtywhiteboy is online now
Old 08-13-2017, 04:38 PM   #28
Old 08-13-2017, 04:45 PM   #29
slowsol's Avatar
Rewards Points: 2,234
That is one way to do it. I doubt it's the case when he's got trusses 2' oc. There would be a pole every 2'. I'd guess he has a beam or girder spanning the poles that the trusses are sitting on.
-John
slowsol is offline
Old 08-13-2017, 04:54 PM   #30
Now I have never built a pole barn because here and in Florida we NEVER put wood in the ground but from what I've seem on the forums the poles are around 8 feet apart and a beam or double 2x6 on top or bolted to the top Even tho I have never done one I could build one like I was a pro because I've seen it done so many times by my online friends.
Old 08-13-2017, 05:56 PM   #31
Joasis's Avatar
I order trusses quite often, and I always tell them to let the tails "run wild", or untrimmed. We chalk them and cut them in place for an exact fit.
9 times out of 10, I am installing a metal roof anyway, so to make a simple explanation. We may not even run a fascia board, but have the eave trim made so it is over the topm meaning rafter plus decking, and down the fascia side, and return in to a hem, or sometimes all the way to the reveal for brick.
Tell you boys something I learned on my own pretty much. You can take the fine carpentry rule book and use it to prop up a coffee table as far as I am concerned. I will work outside the box when it suits me, with no apology to anyone. Now we all follow the basics in the trade, but there are dozens of ways to skin cats and their kinfolks.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
The Following 4 Users Say Thank You to Joasis For This Useful Post:
A&E Exteriors (08-14-2017), griz (08-13-2017), overanalyze (08-13-2017), ScipioAfricanus (08-13-2017)
Old 08-13-2017, 07:22 PM   #32
Tghomeservice's Avatar
Rewards Points: 22
Hello Everyone, thanks for your comments. The decision is that we will be cutting nails and adjusting to a string. I appreciate everything all of you said. Tyler Gettings
Tghomeservice is offline
The Following 6 Users Say Thank You to Tghomeservice For This Useful Post:
hdavis (08-13-2017), Joasis (08-13-2017), Justin Rhoades (08-14-2017), overanalyze (08-13-2017), ScipioAfricanus (08-13-2017), sparehair (08-14-2017)
Old 08-13-2017, 07:24 PM   #33
Fire up the BBQ
griz's Avatar
Rewards Points: 3,660
Good call....
be careful when you cut those nails to leave the trusses tied together...
domino effect on trusses is WAY ugly....
griz is online now
Old 08-13-2017, 08:05 PM   #34
Joasis's Avatar
Cut one truss at a time. And in the future, use the long screws to drive from the top down, or plate up. Toe nailing is a passe with all the great fasteners we have now.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
The Following User Says Thank You to Joasis For This Useful Post:
hdavis (08-13-2017)
Old 08-13-2017, 08:11 PM   #35
Fire up the BBQ
griz's Avatar
Simpson Truss Screws work well and may be code compliant in your area.
griz is online now
Old 08-13-2017, 08:19 PM   #36
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,224
We still toe nail on set day and then follow up with Simpson ties or screws later.
Sent from my SM-G920V using Tapatalk
overanalyze is offline
The Following 6 Users Say Thank You to overanalyze For This Useful Post:
A&E Exteriors (08-14-2017), Dirtywhiteboy (08-13-2017), griz (08-13-2017), jhark123 (08-13-2017), Justin Rhoades (08-14-2017), Warren (08-13-2017)
Old 08-13-2017, 09:33 PM   #37
I have never not cut the tails. I cut the hips to length on the ground and set a nail in the end to hook the string on. Heck I even run a string on the body of the hip. We put fascia board on most roofs but old Hawaiian style has no fascia. We will hold the fascia up as needed for tile or metal. All our fascia is exposed so it is finish, 45 corners and gnats ass joints. Most all of our over hangs are left open but not all. This house got a Board & baton soffit with 3/8 LP smartside. Those are O`hia post,, don't know what they are call on mainland.
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
hdavis (08-14-2017), Joasis (08-14-2017)
Old 09-03-2017, 05:03 PM   #38
Rewards Points: 22
Thanks Everyone for the input.
Old 09-05-2017, 10:49 AM   #39
Fishindude's Avatar
Trade: Industrial
Rewards Points: 486
Making a big deal out of a minor deal.
Do a nice straight job with the metal sheeting and ridge and you will never see this.
Fishindude is offline
garage addition: part pole barn lewisthepilgrim Framing 6 04-11-2013 09:03 AM
Concrete Slab breaking up in Barn Dustincoc General Discussion 7 02-14-2013 07:44 PM
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 09:51 PM
Whats it cost to put up a 3000sq ft Pole Barn? CarrPainting General Discussion 18 11-15-2012 08:47 PM
warping barn door fix artinall Windows, Siding and Doors 6 06-09-2012 08:19 AM
