Pole Barn Garage
Old 05-23-2009, 10:47 AM   #21
jaros bros.'s Avatar
Re: Pole Barn Garage
A router and a homemade jig work good for cutting out your notches, preferable a plunge base so that you can do it in a few passes if necessary. Also, living where you are you should know that you shouldn't put any wood close to the ground. The best construction method would be pouring frost walls up at least 16" out of the ground. Everything up there rots because of the snow and moist conditions when it is at ground level and the pt will even soak up water and moisture and transfer it.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas
jaros bros. is offline
Old 05-23-2009, 11:22 AM   #22
HSConstruction's Avatar
Good point, if you use PT make sure it is rated for ground contact.The posts are but most framing lumber is not.
HSConstruction is offline
Old 05-29-2009, 05:08 PM   #23
cabletite's Avatar
Trade: Home Anchoring
Mike.....don't forget tiedowns. You are in a high wind region so make sure your roof and truss are tied to the foundation. My company offers an excellent and economical method which you can review at my website. (check profile) You could use 8-12 and keep it secure from the high winds.
cabletite is offline
Old 05-29-2009, 05:37 PM   #24
Worm Drive's Avatar
Trade: carpenter
I built a 30'x40' last year. I told the local lumber yard what I wanted and they printed up a material list and the plans. The plans along with a property survey were enough for the building inspector.
The plans called for 6x6 corners with 4x6s 8' oc in between. I switched to all 6x6s. Also, tarred the bottom of the 6x6s up to 12" above grade. The truss carrier is a double 2x12, one on each side of the 6x6s with trusses 4'oc. Code didn't call for the carrier to be notched.
As 72Chevy4x4 said, go with a 2x12 skirt board. I used a 2x8, as per the plans and regret it. If I had used a 2x12, I could have kept the board and batten siding that much further above grade.
Worm Drive is offline
Old 05-30-2009, 05:34 PM   #25
mrmike's Avatar
Trade: Electrical & Carpentry
WormDrive,
Thanks for the great tip on tarring the bottoms like that !! I definatly will do it ! My truss carriers are 2 x 10 & they are requiring me to notch both sides. Gotta do what they tell ya even though there will never be any snow load on it with a 12/12 pitch & metal roof.
Anyhow I got my Holes dug & 12" sauna tubes installed & a concrete mix footer at the bottom of the hole below the frost line that they required. Did it today with my stepson's help ,as the weekends is when I do my own personal work! God, When is it gonna end ?? I guess I just keep myself too occupied ! Gotta get some fishing & golf in one of these damn days!!!!!!!!!
Hey Thanks Again- I really appreciate it-we all need some help
mrmike is offline
Old 10-28-2009, 03:13 PM   #26
doorrepairsac's Avatar
Trade: Garage doors, openers and garage door repair
If you need any help with the garage door selection let me know i would be glad to give you some input.
Garage Door Repair Pros - Garage doors, openers and garage spring repair at 2105 15th Ave Sacramento, CA 95822 916-282-4720
Garage Door Repair
doorrepairsac is offline
Old 10-28-2009, 08:29 PM   #27
smeagol's Avatar
Trade: new construction and remodeling
we always housewrap the outside the stripping to protect insulation from wind wash.
smeagol is offline
Single pole vs. double pole thermostat dforeid Electrical 2 10-23-2008 10:42 PM
Steel pole barn pricing. DeanV Painting & Finish Work 6 06-22-2007 09:34 PM
32 x 50 Pole Barn foundation pad question... Big_Ben Excavation & Site Work 7 05-15-2007 11:58 PM
Pole Barn Feeder sparkysteve Electrical 4 10-21-2006 08:57 PM
Concrete floor in a pole barn thinkncabin Masonry 3 03-31-2006 06:45 PM
