Pocket Door That Also Swings...???
Old 07-09-2007, 04:24 PM   #1
RISENRUN's Avatar
Trade: STAIRS AND DOORS
I was just called by a customer that is looking for a pocket door that would also swing..???? I can picture it and have figured out a way it would work but I was wondering if there is any hardware ??
RISENRUN is offline
Old 07-09-2007, 04:33 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Re: Pocket Door That Also Swings...???
Why! What would be the point?
mickeyco is offline
Old 07-09-2007, 04:44 PM   #3
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
A pocket door rides higher than the stop moldings. You would have to create something to lower the door and at the same time release the top rollers and while a pivot device engages to pivot the door...................... yeah it could be done but as Mickey said "what's the point" ?
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 07-09-2007, 04:46 PM   #4
Insert title
dougchips's Avatar
I forgot about the "hinge side stop moldings" they would have to move because the door is wider than the opening. Also the bottom guides might be in the way when it pivots.
Old 07-09-2007, 04:47 PM   #5
mickeyco's Avatar
Maybe he want's to be the only guy in town to have one.
mickeyco is offline
Old 07-09-2007, 04:54 PM   #6
Insert title
dougchips's Avatar
He might also be insterested in a sink that has the water coming from the drain and existing into the faucet.
Old 07-09-2007, 05:36 PM   #7
mickeyco's Avatar
Just thought of something, is this for an entertainment system, if it is, they do make hardware for that.
http://www.rockler.com/product.cfm?page=35&cookietest=1
mickeyco is offline
Old 07-09-2007, 05:39 PM   #8
mickeyco's Avatar
Another one:
http://www.rockler.com/product.cfm?page=16420
mickeyco is offline
Old 07-09-2007, 10:06 PM   #9
Palisade Point Const.
TempestV's Avatar
This idea exists- my Grampa's old house had it. Unfortunitly it was a long time ago that I saw it, and I don't remember how it worked. Perhaps my dad will remember.
the entertainment center doors wouldn't be heavy duty enough, but you could use the idea, along with some heavy duty drawer slides to get a similar setup.
The only other way I can see doing something like that would be to hang some kind of frame off the pocket door rollers, that would have a vertical bar coming down that you could hinge your door to. perhaps then you could get a doorknob that would run a bolt into the upper frame to hold the door shut.
Well, I guess I really forgot about how my Grampa's house- turns out that they don't swing
also, any hinges to hold the door would have to be some kind of hidden hinge, so that nothing hangs out to catch on the slot for the pocket door.
TempestV is offline
Old 07-11-2007, 06:19 AM   #10
dadswrx's Avatar
Trade: trim carpenter
I just installed two of these in a laundry closet in a townhome. The HO believed that the existing bifolds were not in keeping with the value of the home, plus, the hallway was so narrow that you could not walk by the open bifolds with a load of laundry.
The hinges are shown on page 810 of hafele (dot) com's sliding roller shutter catalog. (Sorry, not enough posts to post the link). The HO was able to find two for ~$925 each. I mounted 33 x 80 inch solid pine doors on them.
Once you figure it out, they were not too bad to install. They slide beautifully as well.
Gary Katz also did an article on these a few years ago...
Mike
dadswrx is offline
Old 07-13-2007, 08:59 AM   #11
RISENRUN's Avatar
Thanks For All The Information
RISENRUN is offline
Old 07-21-2007, 10:55 AM   #12
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
Mike
Page 810 - It's about $1100.
http://www.hafele.com/us/external/ca...rs/795-810.pdf
In_Mexifornia is offline
Bosch 10.8 volt Pocket Driver highlife77 Tools & Equipment 3 04-11-2007 06:57 PM
pocket pc/smartphone Bone Saw Technology 11 02-07-2007 07:30 PM
bosch pocket driver drill Mike604 Tools & Equipment 11 10-09-2006 09:58 PM
