Priced In
Trade: Exiled For Life
Plumb Bobs
I was curious what kind of plumb bob set ups do you guys use?
I have two one I consider my finish set and the other to be a mud set up that can take a beating. The finish set up is the Tajima 14 oz 6 second stabilization bob and plastic reel with a 14 ft. whip. The other is a 16oz brass bob with mullens tools metal case. A lot of string in the reel. Been eyeing the 25 oz and 48 oz brass bob for windy conditions. |
Re: Plumb Bobs
I ain't no carpenter, but I use the Rack-A-Teers laser plumb bob for laying out lighting. I just measure off the lighting plan on the floor, and shoot a dot up to the ceiling (often sloped) for each fixture or can with the laser plumb bob. About 100 bucks.
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Plumb Bobs
I probably use one once or twice a year so mine is some cheap thing with a wad of string all knoted up. Still works as long as they don't change gravity, put it ain't pretty.
Professional Remodeler
Re: Plumb Bobs
Same here, except I got tired of spending 10 minutes unwading the string so I bought a chalkline, cut the hook off, and added the plumb bob. Works like a charm, no more wadded string, now it only takes 10 minutes to find it in the truck. I generally use a PLS5 laser for locating overhead points just a MD stated. Lay it out on the floor and transfer points.
-Mike- Falcon Contracting Residential - Commercial
#5 | |
The Grand Wazoo
Re: Plumb BobsQuote:
I use my Hilti laser far more than I use a plumb bob.
#6 | |
Chief Toilet Mover
I don't have trouble finding stuff, so the chalk line idea is a winner!
Re: Plumb Bobs
I have never really had the need for one to be honest. I remember needing to have one for voc school back in the mid 80's
#8 | |
Fentoozler
![]() ![]() For you guys still using Robert(as he likes to be referred to)...here he is: ![]() ![]() http://www.studiosl.com/html/plumb_b...___robert.html
Re: Plumb Bobs
You musta taken the picture during the winter, Barbara look a little cold...
#10 | |
Fentoozler
Priced In
Re: Plumb Bobs
ole' plumb barbara.
Laser's are no good when pouring 16' concrete hand set panel walls. |
#12 | |
Re: Plumb Bobs
I keep a few PB's around but I've found I can drop a nail head first and come within an eigth in 8' in most cases. Like if I had to dig a deck post and the deck was built, Drop a nail and dig... Drop 2 to double check, and a third if you still don't believe it.
Electro-Mech. Contr.
Trade: Mechanical Contractor
Re: Plumb Bobs
I have a couple, the one I use most is a 16oz brass attached to a chalk line reel.
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It |
Trade: Custom deck builder
Re: Plumb Bobs
I use a plumb it level. Extendable level... mine goes to 17'
I'm a Mac
Trade: ICF Construction
Re: Plumb Bobs
I still use a plumb bob for forming tall walls, But I am going out tomorrow to find the plumb Barbara, that's the tool I need
Chris |
Trade: Ca Contractor
Re: Plumb Bobs
for plumbing walls use a extenta level, for pick up,rack walls ect, use a pls if your using a plumb blob your way behind and look like an idiot when some-one like me sees you fuc ing with a plumb bob
#18 |
Palisade Point Const.
Re: Plumb Bobs
Cheap simple weight, Chalk box, and 50lbs test braided fishing line- simple, but it works.
I've been eying the one that uses a 50bmg shell and bullet for a weight- that looks like a winner. |
#19 |
Trade: Commercial GC
Re: Plumb Bobs
I have a cheap 16oz. I got tired of the tangled string line and bought a retractable target string line like surveyors use. It's lightweight and the string line is super thin so it doesn't catch the wind like normal string line does.
Just had a steel erector on site that had a 10lb. plumb bob that some machinist friend made for the foreman. He said he has used it in 20-25 mph winds before on 30 ft. columns and it didn't move a bit. |
| Don't read this is you are easily depressed! | Mike Finley | Business | 55 | 02-28-2009 05:32 PM |
| hanging doors | wink | Finish Carpentry | 34 | 09-15-2007 02:53 PM |
| anyone remember plumb doctor? | alwysbencrzy | General Discussion | 3 | 11-04-2006 12:51 PM |
| Kitchen Utility Cabinet & Plumb Crazy Wall | LI Hardwood Guy | General Discussion | 11 | 04-21-2005 06:29 AM |
