Trade: General Construction
OSB Hangerboard For Stair Stringer?
I just have a simple question. Will OSB work just fine as a hangerboard for stair stringers?
I am fairly new to stairbuilding. I have done several with the guidance a carpenter who knew what he was doing but now I am on my own. How do you guys usually attach your stringers. The stairs I am currently doing has a non loadbearing wall at the end. The I joists will be running parallel with this wall. I was thinking of installing an I joist flush with the 2x4. I would then nail my stringers to the hangerboard. And then nail the hangerboard to the top and bottom of the I joist and also to the top plate. What would you guys do? |
Trade: New home construction
Re: OSB Hangerboard For Stair Stringer?
In a nutshell, no, absolutely not. Never use OSB to hang your stringers. Always use plywood if you need a hanger board. And glue and screw everthing!
Priced In
Trade: Exiled For Life
3/4" OSB will work just fine. Personally I like to use cs16 strapping.
Trade: home improvement
I've used it a bunch of times.. never any problems..after 15 years of framing
SAGE
Trade: Remodeler and Finish Carpenter
I never used or use OSB in this apllication but the framers seem to feel very comfortable with it, Honestly its never really been a thought for me, What does your building dep. have to say about it? Good question?
-Lead from the front, or dont lead at all- |
Charitable animal
Trade: decks
not sure what your particular application is, but why not just do what you described using 2x and losing that thickness from your top plumb cut, I am assuming you are talking about building a prefabbed stair and setting it in place??? got pix?
#7 | |
SAGE
Re: OSB Hangerboard For Stair Stringer?Quote:
Thanks for the input. I'm still not sure exactly what I am going to do.
#9 | |
Priced In
Wrong. The reason you cut 3/4" off the last run is because of the thickness of the toe kicks. If 5/4" was used then you would cut 1" off Pure value here.
#10 | |
SAGE
By the way Justa, I'm bored with you. The only real value in your post is that it once again shows how small a person you really are. Keep coming with the digs. Yawn-Stretch.
-Lead from the front, or dont lead at all- Last edited by sage; 03-09-2006 at 08:07 AM. |
#11 | |
Sarcasm while you wait.
Trade: builder of things
Trade: Custom deck builder
We NEVER used just the nailer board. We were REQUIRED to use FHA18 straps. We would nail them to the microllam that the staircase would hang off of. Then we would set the stairs and nail off the nailer board then we would nail off the straps to the stringers. I use the same straps for my deck stairs.
I always did it like Robert, (with the straps), probably because I live in the same county as Robert.
#14 | |
Priced In
Even if a block is flush mounted it would have to be cut more than 3/4" more like 1 1/2" Your still wrong. With todays standards that is hackish. the jacks should be strapped as Robert and I have both stated or some other Simpson metal attachment. Plus a thrust block on the bottom run
Priced In
And Logical you are not smart enough to flame.
Yes I edited it so the grammar police will stop bringing a man down. Last edited by JustaFramer; 03-10-2006 at 10:55 PM. |
#16 | |
SAGE
-Lead from the front, or dont lead at all- Last edited by sage; 03-10-2006 at 07:57 AM. |
#17 | |
I may or may not be as smart as a framer but my post (flame?) regarding your post was 100% correct. You were confused. Take a lesson from V.P. Chaney. When you do or say something really stupid, stop talking and lay low for a few months. |
#18 | |
Priced In
If it is so elementary then write a tutorial on the proper way to cut stairs. |
#19 | |
Priced In
whoopy |
#20 | |
Priced In
You have been called out. |
