Newly Installed Deck Blowing Like A Horn With The Wind
Old 08-11-2010, 10:08 AM   #1
geospec's Avatar
Trade: general contractor
Recently we installed a new TREX deck with grooved planks with stainless steel connector clips. One week later after the completion of the deck, our client is complaining about the whistling sound created by the wind coming under the deck on windy days. I went to the jobsite to access this situation on a windy day and found the problem to be very real. With the right speed of the wind blowing, the deck is blowing like a horn from a ship. With my engineering background, I can only think that this is caused by the grooved on both edges of the newly design planks. Looking from the cross section of the planks, one can envisioned the shape of a horn on both edges with the planks separation.
We spoke to TREX technical about this issue and technical told us that this is the first time they heard of this problem.
How can we solve this 24 hours annoying problem? Any help will be greatly appreciated.
geospec is offline
Old 08-11-2010, 10:29 AM   #2
SC sawdaddy's Avatar
Rewards Points: 1,018
Re: Newly Installed Deck Blowing Like A Horn With The Wind
Lattice around the bottom of the deck?
I've installed screen wire to the bottom of the joists before to keep mosquitoes from coming up through the cracks in a screened in deck (at the customers request.) I dont know if it was worth the trouble for the mosquitoes but it may give enough resistants to cut the whistling.
No, you cant hold my hammer. Where is yours?
SC sawdaddy is offline
Old 08-11-2010, 10:48 AM   #3
dave_dj1's Avatar
Rewards Points: 812
try running a piece of trex perpednicular to the decking, underneath kind of like a snow fence?
dave_dj1 is offline
Old 08-11-2010, 10:51 AM   #4
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,900
Possibly need to try an air curtain around the underside of the perimeter of the deck. Try a temporary one first out of any material 6" - 12" wide with temp rigid attachments.
Wind / air movement noise is addressed by changing its direction sometimes more than once.
Maybe need a air curtain perp to the boards every 6' - 8' to break up the air movement.
We Fix Houses is online now
Old 08-11-2010, 11:08 AM   #5
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,740
Sounds to me like your site has certain wind conditions that contribute to this. It may be as simple as adding a skirt to the deck to break up the wind path. Or, you can plant a hedge. You may want to get a few pieces of plywood or OSB and stand them up in certain places to see if it has an effect. It could also be from the way the railing breaks the wind flow. Pics might be helpful.
Rustbucket is offline
Old 08-11-2010, 11:22 AM   #6
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 1,394
Wow that is Strange..... You might want to add this to the Under deck.
http://www.insideoutunderdeckdrainage.com/install.html
Let us know how this plays out.
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty"
- Thomas Jefferson-
http://www.savingtherepublic.com/Main.html
Snobnd is online now
Old 08-07-2017, 07:06 PM   #7
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Originally Posted by dmangan View Post
lets solve this together!
Well it was almost 7 years ago... Not sure if it's been solved or not. I've experienced this too, just depends on which way the wind is blowing.
RobertCDF is offline
Deck works Mellissam Construction Picture Post 49 08-11-2010 03:13 AM
Whats The most expensive deck you've built deck king Decks & Fencing 96 07-10-2010 09:02 PM
2nd Flr DECK over living space royceGC Construction 14 01-10-2010 11:06 AM
Looking for deck and fence builder - Chicago west suburb Green_2 Help Wanted or Looking For Work 0 09-07-2008 06:34 AM
