New Floor In Shed
Old 11-01-2007, 06:45 PM   #1
SHORTGUN's Avatar
Trade: Concrete
New Floor In Shed
I just had a shed built and they put down Single Flooring O C
I would like to know how I can finish it without having spinals that can get into your feet or hands?
I would like to Stain the floor if all possible, I need to put some kind of sealer on it to stop the wood from coming up. By the way this looks like OSB Board. Hope that this will help you understand what I am talking about.
Yes this will get traffic on it.
Any ideals or comments will be welcome on how to finish the floor.
SHORTGUN is offline
Old 11-02-2007, 08:20 AM   #2
Danno6102's Avatar
Trade: Deck Builder
Re: New Floor In Shed
A good wood sealer would probably be your best bet.
As a side note, if your trade is concrete, why didn't you pour a slab for them to build it on?
Danno6102 is offline
Old 11-02-2007, 02:12 PM   #3
RYANINMICHIGAN's Avatar
Trade: builder of stuff, real nice stuff
Why did they use OSB? I only use pressure treated Ply. You could cover it with 1/4 ply sand the seams and finish as desired.
RYANINMICHIGAN is offline
Old 11-02-2007, 03:53 PM   #4
SHORTGUN's Avatar
Trade: Concrete
Can you get 1/4 inch pressure treated Ply?
This sounds like the way to go.
SHORTGUN is offline
Old 11-02-2007, 03:54 PM   #5
SHORTGUN's Avatar
Trade: Concrete
Our taxes would go up.
SHORTGUN is offline
Old 11-03-2007, 02:36 PM   #6
I don't think you can. I was talking about normal plywood then paint with a good floor paint. How much water do you expect it to see? I use PT cause alot of my customers stroe snowmobiles and fourwheelers that will have melting snow on them
Old 11-03-2007, 06:50 PM   #7
SHORTGUN's Avatar
Trade: Concrete
I don't think you can. I was talking about normal plywood then paint with a good floor paint. How much water do you expect it to see? I use PT cause allot of my customers stroe snowmobiles and fourwheelers that will have melting snow on them
Not a hole allot of snow, thats why I was going to stain the floor since stain will penetrate into the would better than paint.
SHORTGUN is offline
Old 11-03-2007, 08:58 PM   #8
Carpenter/fencing
nywoodwizard's Avatar
How about stain and then a nice coat of polyurethane ? That OSB is eventually going the chip up a bit , stain or not. An epoxy garage floor paint would probably be something to consider also.
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 11-04-2007, 06:19 AM   #9
wink's Avatar
Trade: carpentry
the guys in the painting forum might have some other recomendations, might try there
wink is offline
Old 11-04-2007, 07:16 AM   #10
SHORTGUN's Avatar
Trade: Concrete
I have to agree with you on this 100% ,when it chips there goes your floor and a lot of hard work and money.
I feel if I go with 1/4 inch plywood and stain and treat it will last for a long time.
Whats your throught on this?
SHORTGUN is offline
Old 11-04-2007, 09:24 AM   #11
I'd just put down 1/2 or 3/8 CDX with SS square drive, and replace it when its worn out. Maybe 5years, maybe 20, depends on the use. KISS
neolitic is offline
Old 11-04-2007, 06:32 PM   #12
SHORTGUN's Avatar
Trade: Concrete
Not sure what CDX is, Can you explain what it is?
SHORTGUN is offline
Old 11-04-2007, 07:29 PM   #13
C grade face veneer
D grade back veneer
X for exterior glue
Oh, plywood is what it is.
neolitic is offline
Old 11-26-2007, 07:51 PM   #14
C grade face veneer
D grade back veneer
X for exterior glue
OP 11/01/07
Any of this sound familiar?
neolitic is offline
Old 11-26-2007, 11:25 PM   #15
Mbskye's Avatar
Trade: Contracting/Carpentry
Send a message via MSN to Mbskye Send a message via Yahoo to Mbskye
This is just plain silly, I cant believe this whole thread is still being entertained.... Yes its familiar, almost just like his one about bcx ply. The only thing sadder than the redundancy of these questions is that fact that I wasted another 10 minutes of my life reading these 2 threads. By the way, who uses OSB for a floor in anything? I think id cover it with a nice sheet of MDF..... That will last in a shed
"Some days, it just isn't worth chewing off the restraints."
" Second place, is the first loser."
Mbskye is offline
Old 12-03-2007, 09:46 PM   #16
Griffino's Avatar
Trade: General Contracting
just use a penetrating deck sealer, unless your bringing in wet stuff daily and soaking the floor.........
Ventilation would be my concern after that, otherwise you'd be looking at bigger problems like mold, mildew, and dryrot
Remember it's only a shed, it's ok if things brown up a bit.
Griffino is offline
Old 12-04-2007, 11:40 PM   #17
72chevy4x4's Avatar
it seems all of your posts have been about your house-are you really into concrete or just a DIY'er?
72chevy4x4 is offline
Base for NEW SHED SHORTGUN Carpentry 8 07-02-2007 12:13 AM
Running line to shed 72chevy4x4 Electrical 24 03-31-2007 12:05 PM
Ideas for venting a shed roof.... kermmonk Roofing 5 08-16-2006 09:40 PM
Shed..apply for variance or not? jranaudo General Discussion 18 08-11-2006 12:00 PM
Shed roof ventilation maj Construction 8 03-31-2006 12:45 PM
