Trade: general
Never Have I Seen This...very Confused
A new house with over 300 screw pops, built near another new house a near identical floor plan with 0 screw pops. These houses had:
same soil conditions came concrete guy same engineering same truss company different framer different weather conditions before dry in different sheet rocker Has anyone seen this before and if so did you get to the bottom of it? |
Mod / ArchiBuilder
Re: Never Have I Seen This...very Confused
300 Screw Pops!!!!!!
![]() Did you inspect the sheet rockers work?
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Trade: general
yeah he was my regular guy. I quit using him after that job. His quality is actually superior to anything I have seen but it is nigh impossible to get him out there when he says he will be out there so I had to quit using him. I called him and asked if he had ever seen anything like that and he said he thought there must be something else going on.
I tend to agree. Last edited by pkp; 10-10-2007 at 11:57 AM. |
Three Rivers Services LLC
You have to love the 'Track Home Blues".
I've run into it many years back when I was a Super for a devlopement Co. in California. After back and fourth finger pointing, it was finalized by blaming the shipment of "Wet Drywall". Ended up tearing it all down and re-sheeting the house. luckily it was still un-occupied. |
Mod / ArchiBuilder
The only other thing it could be would be lumber shrinkage because of the different weather conditions.
Have you checked the wood with a moisture meter? Oh and one more thing, is the drywall nailed tight to the framing?
Trade: general
never checked it with a moisture meter. The sheetrock was nailed on the 4 corners, and then screwed, 6" in the perimeter and 12" in the field, (which was glaringly obvious just by looking at the screw pops) as per code. Yeah it was tight to the framing. I don't even think you can dimple sheetrock for filling with a screw without it being tight.
#7 | |
Trade: general
Re: Never Have I Seen This...very ConfusedQuote:
The framing shrinks from being installed to green (wet), and yet the screws stay put, - - it helps somewhat to use shorter screws, - - use 1 1/4" screws instead of 1 5/8" (for 1/2" rock) . . .
#9 | |
Trade: general
I called a soils engineer and he said there was a very remote chance that there could be some peat under the mineral soil or some other anomaly. He was pretty much baffled as well. I really only came here in the hopes that one other person said "yeah, I've build hundreds of houses and that happened to me once too..." |
#10 | |
Mod / ArchiBuilder
Let us know what happens.
Nope, I did not buy that answer, My boss at the time made that call. He didn't want to blame the Drywall Contractor because it happened to be a relative. Really to this day it's still baffles me. All test were done on the lumber, moister content passed. The distributer made the wrong comment to my boss, so he used that against them.
Never heard of wet dry wall, had a batch of drywall once that was date stamped less then 36 hours old from the factory went up without any problems. No problems with the corners, wall to ceiling? no slab cracks, even small?
Trade: carpenter/remodeler
i have seen it only one time and the reason given was lumber wasn't dry enough when it was rocked. i was glad i didn't have to set all the pops. i was just the trim guy on that job.
MFWIC
Trade: house painter
Really need a bit more info but the only time I've seen sheer tearing and nail pops all at once was earthquake.
So that would lead me to believe something is moving in your underpinnings. Either drying out and moving or framed quick and fast, and too loose and settling. If it's bad dirtwork you'd have concrete cracking in the stemwalls first, and noticeable, befoer the walls showed a prob. ...Was it hem fir? r |
#15 | |
Trade: general
Doug fir, The only shear was in attic trusses but nail pops on both floors, The dirt work was done the same way on both houses, organic soil pushed off down to mineral soil, pit run hauled in, about 100 yards per lot, compacted in lifts with a roller about a foot and a half of fill total. One house is fine. I have not seen any irregularities in either foundation. |
Trade: Plumber
Poltergeist
Don't know if it'll help, but have seen similar deal when the house stood in the weather for a week long rain before it was roofed. Another time framers "forgot" to shim floor beams over crawl piers. That one you could stick your fingers into some of the cracks in the ceiling angle under the trusses, and plenty of pops on the interior walls.
#18 | |
Trade: general
#19 |
Al Smith
Are the pops near where the trusses meet the walls? Are you familiar with truss rise? when the members of a truss have unequal moisture content because of weather or other issues and drywall is applied. the members change dimensions and literally lift the bottom chord off the non bearing partitions. causing nail or screw pops. You can avoid this by using drywall clips on the tops of partitions to prevent truss rise from pulling the drywall up and causing screw pops and corner joint tears. some drywall contractors use the technique of not using screws on the ceilings at the wall junction. Unless there are serious structural issues your repairs should not be a recurring problem and you will not have to baby sit the project in the future. once the building envelope is complete and the heat or air conditions is on you shouldn't have lumber movement. You might want to ask your drywall contractors to start using glue in addition to screws.
#20 | |
Trade: general
| Confused: Why in some threads are some posts deleted | R&S Exteriors | General Discussion | 24 | 09-08-2006 06:23 AM |
| Where do I start? Confused?? | brax | Contractor Licensing | 2 | 08-28-2006 05:04 PM |
| Very confused consumer | leeh | HVAC | 3 | 07-11-2006 08:51 PM |
| paint peeling off wall? | 747 | Painting & Finish Work | 28 | 02-22-2005 12:19 AM |
| Glazed and Confused | GenConJ | Windows, Siding and Doors | 6 | 12-26-2004 11:26 AM |
