Trade: Landscape Carpentry and Construction
Need Your Help
I just picked up a mint, antique Dunlap cast iron table (tilting) saw. It is very compact and well made. The only glitch is that it has a 1/2" diameter arbor. Does anyone out there know where I can find blades for it? The blade diameter should be 7" but anywhere from 6 to 7 1/2" would work.
unlicensed hack
Trade: wood butcher
Re: Need Your Help
http://www1.mscdirect.com/CGI/N2DRVSH
A few of the cordless saws have 1/2" arbors. You might be able to find them at a home center. http://www.justsawblades.com/systima...saw_blades.htm You may be able to get a arbor reducer to fit standard 5/8" arbor blades.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. Last edited by maj; 08-28-2006 at 12:13 PM. |
Trade: Squirrel Handler
Re: Need Your Help
I have a very old Craftsman table saw (late 50's or early 60's) with a 1/2" arbor, it has an adapter so I can use common saw blades, I'm not sure if it came with the saw originally or not. But you could try Sears parts and see if maybe they have any, I know they used to have a lot of old parts. Maybe try Delta, Jet, Rigid etc. for an adapter. If you can't find one, you can make one if you have access to a metal lathe or have one made by a machinist. I think common saw blades with common arbors would be cheaper and easier to find than an oddball size, so it might be worth getting the arbor adapter.
Here's a drawing of what the adapter on my saw looks like:
