Trade: GENERAL
Need Help On A Window Install Estimate
Had A Job Drop In My Lap ,that I Normally Dont Deal With. It Is A Window Replacement Job.
What I Need To Know Basicly Is : How I Should Estimate The Job . What Rate I Should Charge ? Im In Ca. ....... The Job Is Pretty Basic, They Are Millgard Windows New Frame. Just Have Trim To Remove To Replace Them. Just Need A Base To Use For My Calculations Thank You |
Heavy Weight Champ
Trade: finish carpentry
Re: Need Help On A Window Install Estimate
I guess it all depends on how many you are doing, how big they are, and if you have to case, or do something to the window since it is a retro fit.
Real nice guys |
Trade: Custom deck builder
First you need to figure out all your overhead expenses. Insurance, license, trucks, tools, oh never mind I will waste too much time going into it all.
Here is the short of it. NO one can tell YOU what to charge. Your overhead and profit needed/desired is differant than everyone elses. You need to figure it out on your own.
Trade: painting and pressure cleaning
I would also consider bidding the job competitivly and how mutch siding etc you have to remove and rotten boards etc
Trade: Home renovations, remodeling
Greetings bkn4x4.
I'm a newbe in the construction trade. I have used the 2007 National Estimator software package from the Craftsman Book Company. It pretty much has national labor rates for the constuction and building trades. The software package allows you to choose all the tasks involved in your project. It will then itimize and list the local labor hours via zip code, material costs and equipment associated with each task. For example: Siding tear off, removal of old windows, cut/frame opening, house wrap, flashing, exterior foam insulation, new vinyl siding, interior insulation, sheet rock, spakle, paint, and finish trim. That should give you some idea of the labor hours and material costs. You then add margin and profit. Good luck. |
#6 | |
Mod / ArchiBuilder
Re: Need Help On A Window Install EstimateQuote:
http://craftsman-book.com/products/i...roducts_id=313
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Cole,
Yes that's the one. I'm not endorsing it in anyway, but for my purposes I find the functionality sufficient and it's easy to use. It produces a good estimate report. |
Remodeler Extraordinare
edited
A.W. Davis Construction Co. http://www.awdavisconstruction.com/ Your friendly remodeling contractor Last edited by A.W.Davis; 08-11-2007 at 02:00 AM. |
Home Repair Specialist.co
Trade: carpentry
Re: Need Help On A Window Install Estimate IT is realy starting to piss me off some of the replys on here are rude we dont all now it all " thats why we chat back in forth if you dont have some thing to help him out then dont say any thing MR Deck guy you sound like a young man with a big head I got over 30 years in the trade concret structual steel high rises resedential and a ton of decks give the new guys a break you wernt born swinging a hammer we all had to start some were back to your post in Cal you would go about 150.00a window if all you have to do is pull off the trim and pull the window recaulk and reset the window and trim provding you dont tear up the trim might need new trim and paint to match that price is if you are doing it your self it you have a helper add him in by the hour on top of that price and if you have to re trim and paint add 100.00 per window thats still cheap good luck Greg Nv
#10 | |
If people would use the SEARCH function they would find lots of threads that tell you all the steps needed to detirmine your hourly rate as well as how to bid a project. BTW I am a young guy and guess what?? I DONT KNOW IT ALL! not even close. But one thing I learned early on is to search before I started a new thread. I am on this board to learn as much as I can most of what I know about the business end of it came from this site and by failing on my own. I have underbid jobs and still do sometimes. Its part of the learning experiance. Look for a user by the name of Bob Kovacs and read all he has to say. This will get you on the way for learning overhead, markup, and profit. He also has an article in Professional deck builder magazine about unit pricing. This kind of pricing structure can be carried into any form of construction. It will make you more effciant and less likely to forget something or underbid it.
Trade: Project Manager
Basically Lowes charges $99 per window install.........for Vinyl repacement windows.....so if your more then that.....why should they hire you?........
#12 | |
Insert title
Trade: Doors-Windows-Decks
With the same logic, why would anyone buy expensive vodka when you can get the big store brand bottle for $8? Or every car on the road should be a Honda Civic, why would people pay more for the same thing?
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
#13 | |
ContractorTalk Flunkie
There is no possible way that I would estimate a job based on what Lowes or anyone else charges. Lowes may have a price of $99.00, but just what does that include. Just the installation of the unit, OR removing siding ( due to the fact that many windows have a flange on the exterior) Removing existing interior jamb and trim, Removing the unit itself, Installing new unit, installing new siding and exterior trim, Installing new jamb, sill and trim, not to mention insulating,caulk,paint and or stain (interior and exterior) and disposal of debris. $99.00? Now to simply set the window and walk away, different story
T.C. "Never met a man yet that I couldn't learn something from"Met a few you couldn't teach though http://remodelingncarolina.com
Unfortunatly..Im just stating facts.....so if the client has been to Lowes....and got the $99 install price......yeah you can tell them you do a much better job for $150.......but...money is money..
That's a tuff nut to crack, when Lowes give people these numbers. Thats all i'm saying. |
Trade: General Remodeling
Project
Make sure you explain to them the big box store is basic installation. Pull out old put in new. Everything Dayspring mentioned is added to the bill on site. Almost a bait and switch. They get them with a $99 price but it ends up being $250 after all the add ons.
http://www.wolffhomerepair.com " Of course I don't look busy, I did it right the first time " |
Trade: Siding
I base all my prices from home depot..... Serious!
Siding plumbing electrical u name it! |
Actually, I have found Home Depot to be a good estimator as well. I don't know about elsewhere, but in SK, I find that Home Depot is actually priced quite high, and I can make good money charging Home Depot Prices - on some items.
I have also used this rule of thumb if it is the first or second time I have bid a job - take the materials, double it and add 10 - 30 % based on my hunch. I have underbid and eaten some time in the name of learning, but I have also overbid and got the job and thought holy Sh-- that job was awesome... I am still learning as well - 2nd yr apprentice, work full time and try to do 30 hours a week of side jobs to prepare myself for full-time self employment on the day I get my ticket. I understand the logic about knowing your business numbers to determine your price, but I also believe that if your business is too expensive to run and your priced out of the market - it's not going to be good in the long run. Also - if you bid too low and leave money on the table in a busy season - you may not have enough set aside for rainy days. Just some thoughts I have learned from some old pro's I apprentice under. (I hope those old pro's don;t retire too soon...) |
#18 |
Al Smith
every job is a little bit different. some homes are a train wreck and you will have to move furniture out of the way to access the window. Some will insist that you reinstall the window treatments and not lose and or damage the existing hardware. Some will insist that you match adjacent wall coverings and or paint. Some clients will have time constraints and the stay at home wife will not want to be disturbed before nine am. You will also have to dispose of the old windows. Will you be picking up the windows or will they be delivered? So size up your job. determine how much REALISTICLY you can get done in say an hour. or two hours or half a day. than using that determine how long the job will take. than figure in how much you need for payroll or yourself. how much you need for insurance, how much for gas and truck expenses including truck insurance, license fees. tool wear and tear. A general rule of thumb is your equipment and business expenses should generate more income than it would dollar for dollar if invested in interest bearing accounts or notes. determine your free estimate costs in time as estimates are really not free, they are built into the jobs you close on. By marking up all the above 50% you will generate 33% profit if nothing goes wrong
#19 | |
Why don't you tell us about your license, bond, and insurance info? Oh, you don't have all of those things....what a shock. |
| Replacement Window Question? | Max10 | Windows, Siding and Doors | 34 | 02-27-2010 06:15 PM |
| Need Help On A Window Install Estimate | bkn4x4 | Windows, Siding and Doors | 17 | 05-23-2007 04:16 PM |
| Need Help On A Window Install Estimate | bkn4x4 | Construction | 1 | 03-11-2007 04:23 AM |
| window install in block | EDENSCAPES@DNET | Carpentry | 12 | 03-13-2006 08:41 AM |
| Just need to customer vent | IHI | General Discussion | 8 | 11-08-2005 09:52 PM |
