Need Help With Stairs
Old 06-18-2006, 05:10 PM   #1
Remodeling Contractor
N.E.Bldg&Rest.LLC's Avatar
OK here is my situation:
I have to build stairs for a deck but I can't figure the correct rise and run, I'm having a brain fart and it's driving me nuts!!! PLEASE HELP
Here is the guide lines I have to follow:
Total rise 6'-3" or 75"
Total run 5'-5" or 65" keep in mind that the run can only be adjusted by a few inches for access under deck.
2x12 stringer at that angle ends up at a 45*
2x10 treads
I have to keep a 10" step and a max of 8" rise.
"Man is a tool-using animal. Without tools he is nothing, with tools he is all."
Thomas Carlyle (1795-1881)
N.E.Bldg&Rest.LLC is offline
Old 06-18-2006, 05:37 PM   #2
Custom Builder
Glasshousebltr's Avatar
Re: Need Help With Stairs
Thats a mighty thin tread Kemosoby.
It works out to 10 risers at 7 1/2" and 9 treads at 7 1/4".
Bob
Bob
Glasshousebltr is offline
Old 06-18-2006, 06:24 PM   #3
jmic's Avatar
2x10 treads
N.E., Can't do it, you need more run distance.
Joe
jmic is offline
Old 06-18-2006, 06:47 PM   #4
Originally Posted by jmic
N.E., Can't do it, you need more run distance. Will not meet code! For 75" of height you will have 10 risers @ 7.5 inches and 9 treads @ 10" will require at least 90 " for the run.
Yes your right on Joe, it works out perfectly
Thanks
Old 06-18-2006, 10:41 PM   #5
onhitch's Avatar
Trade: deck contractor
use a spiral stair case
onhitch is offline
Old 06-18-2006, 11:09 PM   #6
IHI's Avatar
Stripper pole with OSHA approved harness would be quicker to install and acend/decend
IHI is offline
Old 06-19-2006, 12:03 AM   #7
theworx's Avatar
My original thought was a 4x8 sheet of pressure treated plywood just tacked on to the deck (no math, no cutting, etc...) just tell the customer it's one of those new fancy ramps...
theworx is offline
Old 06-19-2006, 02:24 AM   #8
Teetorbilt's Avatar
He's in NC, most of the folks there can't spell 'code'. Sorry but I have a second home there + lived there for 4 yrs, You can still get by there by making your mark and being listed in the family Bible.
Albert Einstein
Teetorbilt is offline
Old 06-19-2006, 04:07 PM   #9
NOT a good Idea my customer is a 60 year old female
Old 06-19-2006, 04:09 PM   #10
Who me Im in connecticut see
Old 06-19-2006, 06:34 PM   #11
IHI's Avatar
Tell her to practice sliding down...head first, after a few times the "anti-gravity" position will start to reverse the effects 60yrs of normal gravity...might just look like a totally different gal when your done
IHI is offline
Old 06-19-2006, 07:10 PM   #12
Soon to be senile
Shamrock's Avatar
Trade: Remodel and repair
....and your point is?
Shamrock is offline
Old 06-19-2006, 07:24 PM   #13
jack of all, master of 1
snapper21's Avatar
Trade: carpenter/roofer
can you head off a couple joists to get more run by creating an "L" effect with winding treads? Inset into the existing deck? Did I need to mention adding a post or two? Don't know if your access below is in the way of the needed supports/posts.
snapper21 is offline
Old 06-19-2006, 08:43 PM   #14
joedonuts's Avatar
Trade: carpenter
put some of that black traction tape on it too
joedonuts is offline
Old 06-20-2006, 06:44 PM   #15
theworx's Avatar
No,No, No. That would ruin the water slide effect when it rains. People pay good money to go to a waterslide park and you could use that as a good selling feature!!!
theworx is offline
Old 06-20-2006, 09:01 PM   #16
OK guys, I figured it out and hour after I posted Save all those ingenious ideas for another thread
Old 06-21-2006, 05:49 PM   #17
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
2x10 treads
A+Carpenter is offline
Old 06-21-2006, 08:12 PM   #18
Originally Posted by A+Carpenter
What are YOU laughing about??? Tell me the:
Length of total span that would meet code?
Number of treads?
Number of Risers?
Size of treads?
Size of risers?
This is for A+ or crosswinds or whatever he's calling himself today.
Old 06-21-2006, 10:36 PM   #19
joasis's Avatar
I agree with Bob, but you do need more run...a 7-1/4 inch tread isn't a lot. The rule I learned on was 7/11....especially if they are older. You may want to box a landing like snapper was talking about if you can find the room. If you are having the mental block on stairs, take the rise and divide by 7, + or - til you get a number that comes out even allowing for the top landing as a step. the run is divided by 11 or 10, or whatever works out to get a tread depth. If you have really steep stairs, then you have to work with it to see what will fit...depending on your code (if you have one) it will dictate rise and run.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 06-22-2006, 11:21 AM   #20
FRAME ON!
Number of treads?
Number of Risers?
Size of treads?
Size of risers?
This wont meet code at all the way you have the numbers posted. As far as the math it is posted above.
Dude WHAT the heck is your PROBLEM. All i did was post some smileys. I have had only 2 names on this site. AdamMieder and A+Carpenter. Im sure Nathan can validate that for you.
Complex Stairs wallmaxx Framing 4 07-09-2007 09:59 PM
ceramic tile on stairs? TaylorBuilding Ceramic & Stone Tile 6 11-26-2006 02:23 PM
Concrete stairs summertime Masonry 20 11-04-2006 01:35 PM
Are uncut stringers old fashioned for stairs? atari Finish Carpentry 2 05-30-2006 01:59 PM
How would you do these stairs? GreenEggs Framing 14 05-03-2006 07:23 AM
